LinkBack Thread Tools Rating: Thread Rating: 3 votes, 2.33 average.
I like it when on the last threads out...the hot plug slips out of your hand and then you get to fish it out of the drain pan.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 03-31-2022, 05:20 AM
My wife's Macan has a plastic drain plug. I guess I need the plastic magnet version?
Old 03-31-2022, 06:00 AM
Gon fix it with me hammer
svandamme's Avatar
the non OEM magnetic plug i stuck in my cayman isn't metal either.
not sure what material it is, but it 's weird looking like a hard plastic or ceramic
Stijn Vandamme
BIMDIESELBMW116D2019
Old 03-31-2022, 06:08 AM
I see you
flatbutt's Avatar
No fear of cross threading that sucker must be nice.
I wonder if the flexy shafty thing would work on a MC drain.
Old 03-31-2022, 06:11 AM
^^^ I think it would because it only grabs two sides of the nut...making it fit any size nut.
(As long as it was unscrewed with the wrench a full turn or so.)
98 Honda Prelude
22 Honda Civic SI
Old 03-31-2022, 06:18 AM
fastfredracing's Avatar
As long as you can still get hot oil over all your sweatshirt , I am all in .
No left turn un stoned
Old 03-31-2022, 07:06 AM
Rick Lee's Avatar
Mrs. Lee's X1 has a plastic drain plug with a female Allen bolt. Inserting a male Allen bit and twisting that when it's good and hot just turns it into Play-Dough. God, I hate that car. It's all plastic.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 03-31-2022, 07:11 AM
So I have to ask, how easy is it to clean off the tool once it does its job?
If it's not easier than pulling off a nitrile glove and tossing it in the trash I'm not sure it's worth it.
Scott
'78 SC mit Sportomatic - Sold
Old 03-31-2022, 08:02 AM
svandamme's Avatar
what will happen to manhood in the age of the EV?
I think i'll start storign my used oil for future use and market it as
"essence de Porsche PetrolHead
Mobil1 Full Synthetic Body Lotion
for real men"
Stijn Vandamme
Old 03-31-2022, 08:05 AM
^^^ Scott
The shank is a flexible steel cable and the rest of it is plastic and metal.
Should wipe off easily.
I'll be trying it out soon...the Prelude is due for a spring oil change.
98 Honda Prelude
22 Honda Civic SI
Old 03-31-2022, 08:06 AM
canna change law physics
red-beard's Avatar
Sounds like an easy fix. Find a steel plug to replace.
The 901 transmission originally had a female plug. There were aftermarket male hex head replacements.
James
Red-beard for President, 2020
Old 03-31-2022, 08:12 AM
What good is that tool when drain plug is on the bottom of the pan? Oil will run down the flexi shaft all over your hand, sweater sleeve or better yet, down your arm if you’re wearing short sleeve shirt.
Old 03-31-2022, 08:15 AM
^^^ It has a flexible cable for the shank. Just hold and turn it with the cable curved.
98 Honda Prelude
22 Honda Civic SI
Old 03-31-2022, 08:19 AM
for real men"
The smell of burnt electronics is still kind of manly
Old 03-31-2022, 08:34 AM
Information Overloader
I've never fished a plug out of the drain pan. I have one of those round ones that slope to a hole in the center. I just put the pan under the let the plug fall in and wait for the oil to drain down the hole.
Old 03-31-2022, 08:36 AM
^^^ I do also for the 911's....but it's a big pan.
I use a smaller reg pan for the Hondas because I need the room under the car.
98 Honda Prelude
22 Honda Civic SI
Old 03-31-2022, 08:40 AM
svandamme's Avatar
we shouldn't have to give it up and defo not without a fight !
Stijn Vandamme
Old 03-31-2022, 08:48 AM
You do not have permissi
john70t's Avatar
Warm up engine with reving but don't get it too hot,
Wear nitrile gloves, have rags handy,
Keep pushing in gently while unscrewing the bolt until it clicks,
Use a quick flip to the side of the stream when it lets loose,
Discover the drain pan is not lined up and the wind is blowing it sideways,
Call EPA for superfund cleanup.
Old 03-31-2022, 09:12 AM
I have always driven the car until it's fully warmed up....I wonder sometimes if that's necessary.
And yes...the pan is almost always not far enough over to compensate for the first part.
98 Honda Prelude
22 Honda Civic SI
Old 03-31-2022, 09:17 AM
Counterclockwise?
I'd spend more time cleaning the tool than my hand that is holding a rag.
Rod
1986 Carrera
2001 996TT
Old 03-31-2022, 09:18 AM
