For my waterfall, I have a catchment basin of 30 gallons. The filter discharges into the basin, then the overflow creates the waterfall.
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
That's how mine works also...except my basin is about 5 gals.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Evil Genius
My Project is currently in the layout phase.......still placing and angling ponds setting elevations.
Scored a cool LARGE fiberglass waterfall off craigslist for up on the deck, then cascading through several ponds to recirc.
Life is a big ocean to swim in. Wag more, bark less.
. My 550 at the Salem Pond.
What sort of water pump does your 550 use?
^^^ It must have the Porsche diverter valve in it.
Home of the Whopper
In our systems we reduce flow by: Bypass with valve - pump puts out 100% flow but some bypasses back through pump. Valve after pump - increases pressure drop of system decreasing overall flow. VFD - varies pump speed electrically Sometimes we use all 3 depending on application. In your application, valve after pump. Make sure you keep it cracked about halfway.
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S |
Well, I have updated my pond situation. I added a ball valve to slightly restrict the flow. This did not have any effect on the pressure at the waterfall because the restriction is increasing the pressure to the inlet of my biological filter, but the output is just a gravity feed once the water level reaches a certain point. A couple of pics below:
From Pond Pump>to Anti-backflow valve> to Flow Control Ball Valve> to UV Filter> to Biological Filter> to Waterfall. Pond is on other side of the fence. The valve is only restricted 25-30% ![]() My Baby Pond:
