Monkey with a mouse
kstar's Avatar
Video: Aluminum V8 Block from Billet on 5 Axis Mill
Pretty cool video:
Advantages to cast aluminum?
FYI.
Best,
Kurt
Old 08-05-2007, 11:04 PM
beepbeep's Avatar
No advantages except you can do one-off's easier. With other words, you don't have to invest in expensive casting equipment.
Doing this in serial production would be a disaster. Imagine the cost of purchasing aluminium ingots, enourmous spillage, tool wear and tiome it takes to chew it from a solid block.
Nice demo for machine suppliers and probably a good way of making drag-race custom blocks but it's like peeling potatoes by chopping off rectangular pieces until you have a solid cube
Thank you for your time,
Old 08-06-2007, 02:10 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Interesting, although one has to wonder what one of those machines costs - probably a small fortune.
I found it interesting that some of the work/boring was done by moving the heavy piece of metal rather than re-aligning the router bit. Seems a difficult way to do it, although maybe necessary for certain shapes/angles.
Why waste the time on a V8 anyway - why didn't they go with a V12?
Black Cars Matter
Old 08-06-2007, 07:14 AM
Bill is Dead.
cashflyer's Avatar
I don't know about the Matsuura, but a Haas 5 axis VMC will run you between $100k to $180k, depending upon the size (work area) and options.
I've been considering one to make some custom spoons.
Haven't you read the Fox wheel threads?
Everyone knows that cast aluminum can't be used for anything without serious risk of catastrophic failure that would kill everyone within a 5 mile radius and leave you and your next 3 generations infertile.
Old 08-06-2007, 07:58 AM
If you're infertile, how would you have subsequent generations?
Black Cars Matter
Old 08-06-2007, 08:27 AM
In that type of operation, is all the wasted aluminum recycled and made into future ignots?
Does a mill recoup some costs from the raw materials supplier?
Randy
'87 911 Targa
'17 Macan GTS
Old 08-06-2007, 08:49 AM
Bill is Dead.
cashflyer's Avatar
You see... THAT'S how dangerous cast aluminum is. It completely screws up your entire reality when it grenades.
(Either that, or the wife would have some 'splainin to do.)
Authorities currently speculate that the Minneapolis bridge collapse was caused by a Porsche with cast Fox wheels.
Old 08-06-2007, 09:23 AM
Un Chien Andalusia
Aerkuld's Avatar
As others have said there is the advantage of not having to buy pattern equipment for making castings which makes billet ideal for one-offs or very low volume work. It also gives the manufacturer an ability to make rapid part changes mid-way through a run of parts without having to get tooling changed - so faster reaction time to potential problems. Another benefit is more consistent material properties throughout the part as you do not get the variable rate of cooling that you do with a casting so no porosity. It could help to reduce weight as you can control wall thickness very accurately, whereas a casting you would have to allow for core shift as well as allowing sufficient cross section to maintain a flow path for the aluminum during casting.
I got the impression, just by watching this, that the block they made was a demo part rather than a functional piece and for some reason it didn't look full size?
2002 996 Carrera - Seal Grey (Daily Driver / Track Car)
1964 Morris Mini - Former Finnish Rally Car
1987 911 Carrera Coupe - Carmine Red - SOLD :-(
1998 986 Boxster - Black - SOLD
1984 944 - Red - SOLD
Old 08-06-2007, 10:09 AM
Unfair and Unbalanced
Mule's Avatar
Location: From the misty mountains to the bayou country
It looked like freakin jewelry. Anybody have an idea what that's going in?
"SARAH'S INSIDE Obama's head!!!! He doesn't know whether to defacate or wind his watch!!!!" ~ Dennis Miller!
Old 08-06-2007, 11:13 AM
lm6y's Avatar
It's just a presentation piece to show what the machine is capable of doing. It's not going to be a real engine.
It's a small piece, unless that machine is gigantic. If 5-axis checks in, he can give us the details, he runs one of those.
Brent
Early85 944
LM6Y Paint Code
Old 08-06-2007, 02:46 PM
White and Nerdy
Tervuren's Avatar
I somehow doubt that that was a "tiny" engine block. It probably looks small to you due to the large work area, and lack of human reference. Heres the W16 of the Veyron.
http://www.techeblog.com/index.php/tech-gadget/video-bugatti-veyrons-w16-engine
http://www.youtube.com/watch?v=Q34xIzTj8fQ
My dad once got a 5 axis on ebay for $7,000, but had no place to put it. Worked perfectly, but had to sell as we had no workspace for it. Made a killer profit, but we'd of preferred to have had the machine.
Shadilay.
Old 08-06-2007, 03:25 PM
Un Chien Andalusia
Aerkuld's Avatar
Not as impressive as a whole cylinder block (even if it's a small one) but I thought you might like to see my own billet piece...
Old 08-06-2007, 03:44 PM
Jeff Alton's Avatar
The machines are large, they can hold upward of 120 different tool heads in them at any given time. I was just taking today with a shop that has one (a Mori) about doing blocks and cylinder heads. I will get a pick of the machine tomorrow to give you an idea of its size......
Cheers
www.turn3autosport.com
Old 08-06-2007, 11:20 PM
Monkey with a mouse
kstar's Avatar
I am curious how the internal cavities of the engine can be "hollowed" out by such a mill? Can a working engine block be made from a single billet of metal?
Best,
Kurt
Old 08-06-2007, 11:31 PM
Un Chien Andalusia
Aerkuld's Avatar
Best,
Kurt
A traditional engine block with integral liners cannot be made in one piece from billet. The only way you'd be able to do anything like this that I can think of would be to mill out access windows through which the water jacket can be machined and then seal the 'window' with a weld in panel or bolt on cover. I knew a guy who made drag racing blocks from billet but they didn't use a water jacket so he never had that problem. If you wanted a one piece billet block than you would have to have liners in the block that are inserted seperately. You would then be able to undercut down the bores for the liners to allow the water jacket to be machined before fitting the liner.
Old 08-07-2007, 05:21 AM
Mule's Avatar
Look at that thing. it has an open deck, just like your 944. Besides, the watar jackets don't need to go that far down the cylinders anyway.
Old 08-07-2007, 05:41 AM
Un Chien Andalusia
Aerkuld's Avatar
Sorry - I was trying to think of what Kurt was thinking when he asked the question. By 'traditional' I was thinking of a closed deck with a water jacket below it which would normally be cast. The open deck option is a possibility that I ignored in my haste despite watching the video. Thanks for the correction!
Essentially we are saying that it is possible to machine a water jacket in a billet block.
Old 08-07-2007, 06:22 AM
Certified Pre-Owned
BGCarrera32's Avatar
Probably a factor of 2X for the Matsuura and 4X for a Makino.
You can pull off a Haas VF3 SS with a 5th axis trunnion for under $100k.
'84 Carrera Coupe
Old 08-07-2007, 07:35 AM
The crank would still be the $$$ part. . .
Black Cars Matter
Old 08-07-2007, 09:22 AM
Jeff Alton's Avatar
An enclosed automated Cell like that one with a pallet pool and the all the goodies could be anywhere from 500K-1M or more.
Cheers
Old 08-07-2007, 09:38 AM
