Monkey with a mouse
kstar's Avatar
Radical Innovation: Direct Exhaust Injection (DEI)
This came up on the "Corvette" thread.
It deserves its own thread.
Originally appeared here:
http://www.gmmodernmuscle.com/forums/viewtopic.php?t=2779&postdays=0&postorder=asc&start=0
edit: From the original post at the Corvette forum:
Ok. I didn't want to mention it but I was thinking about turbo charging my Vette. I got to thinking about it and how in efficient even turbos are (compressor efficiencies of about 80% at best).
Since a turbo's function is to pressurize incoming air and force it into the upper motor, and turbos are driven by high pressure exhaust gas created from the combustion process, couldn't I just bypass the turbo altogether and route my headers back into the throttle bodies?
Since I have CFI, I could balance the DEI (direct exhaust injection as I just coined it) by feeding one header into each throttle body. Yes, the charge air wouldn’t be that cold, but it would be under a hell of a lot more pressure.
I attached a quick sketch below:
There are still a few things I need to work out:
1) How do I get the CFI aircleaner to fit in a way that hides this plumbing?
2) Does anyone make a V-band clamp that will bolt an exhaust header to a CFI throttle body?
3) What pinion angle should I use in my rear-end? I’m sure there will be a noticeable difference in torque output.
What do you guys think?
Best,
Kurt
Old 11-09-2007, 04:26 PM
Zeke's Avatar
Perpetual energy.
Old 11-09-2007, 04:28 PM
Not as good as the gererator.
Does anyone want a free gererator?
Old 11-09-2007, 04:56 PM
canna change law physics
red-beard's Avatar
Ya canna change the laws of physics
James
Red-beard for President, 2020
Old 11-09-2007, 05:14 PM
Did you get the memo?
onewhippedpuppy's Avatar
This just confirms so many stereotypes........
‘07 Mazda RX8-8
Old 11-09-2007, 05:35 PM
Banned
Normy's Avatar
What's an EGR?
Old 11-09-2007, 05:40 PM
pwd72s's Avatar
Originally Posted by Normy View Post
What's an EGR?
A power robbing device forcibly installed by government mandate...
Old 11-09-2007, 05:56 PM
Driver
Noah930's Avatar
Here's another genius idea:http://www.mx6.com/forums/2g-mx6-forced-induction/194308-turbo-mod.html
1990 Black 964 C2 Targa
Old 11-09-2007, 07:12 PM
sudo apt-get purge 930
equality72521's Avatar
Looks like something you'd find here: http://kalecoauto.com/index.php?main_page=index&cPath=1&zenid=853e35073067939d160b4370bcb89f50
--clutch-monkey
Old 11-09-2007, 07:19 PM
Reminds me of the guy on this forum who wanted to blow the air from his AC into the fan of his air cooled motor to keep the temp down.
They probably laugh at that one on the Corvette forum.
1979 911 SC Silver
2002 996 race car
2005 Ford Excursion
Old 11-09-2007, 07:30 PM
That's like the old joke about the guy that carries a car door around with him so if he gets hot he can roll down the window.
--clutch-monkey
Old 11-09-2007, 07:41 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Make sure you suck in some silica sand first to clean out the cylinders and exhaust valves.
Black Cars Matter
Old 11-10-2007, 05:21 AM
I forget whose sig line this is, but clearly, "stupidity, like hydrogen, is one of the basic building blocks of the universe"....
66 911... no more
90 mazda miata
76 unimog 406
Dune Buggy!
Old 11-10-2007, 07:02 AM
Unregistered
sammyg2's Avatar
Seriously think of the gas mileage, you'd never, ever have to fill the gas tank
Old 11-10-2007, 07:20 AM
Gon fix it with me hammer
svandamme's Avatar
i like how he wrote "the charge air would not be that cold"
think of the even bigger increase in power he'de get if adds a massive intercooler inbetween his DEI and his Manifold, and ITB's with EFI, coupled with a MAF
the MAF wont' need current as the wire will heat up automatically, it will actually generate electricity, so you can also dump the alternator, which then means better power/weight ratio
All in all, only thing left on this thing is a TPS report generator with the new style coversheets...
Stijn Vandamme
BIMDIESELBMW116D2019
Old 11-10-2007, 07:29 AM
red-beard's Avatar
Actually, the idea of a cold charge coming from A/C does actually occur. In large gas turbine power plants, they can run A/C systems to sub cool liquid at night, during times where the power price is low, and then run this cooling into the inlet at peak times to sub cool the air producing more output at higher effciency.
James
Old 11-10-2007, 07:25 PM
Unregistered
sammyg2's Avatar
Ya know what the funniest thing is? Lots of them genius vette owners (and a few porsche owners too) didn't realize that post was a joke. They took it serious.
POWNED!
Old 11-11-2007, 08:05 AM
svandamme's Avatar
POWNED!
not really, since there are tards out there that will come up with such stuff
Stijn Vandamme
Old 11-11-2007, 08:12 AM
Unregistered
sammyg2's Avatar
Yep there are, but I read it closer and checked out a little deeper, it was a joke.
Old 11-11-2007, 08:23 AM
