Navin Johnson
TimT's Avatar
I have a chefs choice machine, a few diamond stones, regular whetstones, and a Japanese waterstone, plus afew steels and a leather strop. Also a lanston? system etc..
My pocketknives, and kitchen cutlery are always super sharp.
'69 911 GT-5
'75 914 GT-3
and others
Old 12-26-2008, 11:11 AM
canna change law physics
red-beard's Avatar
Do you know what the model number is?
I have been looking on the web and Chef's choice makes a couple of three stage sharpeners.
Here is a link to pdf comparison chart from the manufactures site:
http://www.chefschoice.com/docfiles/qrfelec.pdf
I have a 130
James
Red-beard for President, 2020
Old 12-26-2008, 11:21 AM
Originally Posted by charleskieffner View Post
with my lan-cay m-9 bayonet
this is normal for a high rockwell hardness blade.
The LanCay M9 is NOT a high Rockwell hardness blade, which is why it became dull quickly for you. It's less that 60 Rockwell, which is (pardon my French) crappy.
High Rockwell is 62, 63, not 59, 60. Don't assume that your "high Rockwell" knife will dull faster than a "low" Rockwell knife.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 12-27-2008, 11:00 PM
304065's Avatar
John,
I use a device called the edge pro. It is better IMHO than other systems which require the operator to distinguish between 22 and 18 degrees. I cannot do that by eyeballing. The Edge Pro has a system by which the BLADE is fixed to the jig and the STONE moves on a rod, thus maintaining the angle. I have used this with great success, you simply start with the coarse stone (a japanese water stone mounted on an aluminum bar) to develop a nice burr, flip it over and do the same on the other side, then move to the fine stone, then cut off the burr and you are in business.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 12-29-2008, 06:48 AM
911 user
Milu's Avatar
Another vote for the edgepro. The edgepro is the best sharpening system made. The Spyderco sharpmaker is great for quick touch-ups. The idea of using a powered sharpener makes me queasy.
Where once the giants walked now Mickey Mouse is king.
My other car is also a Porsche.
Old 12-29-2008, 07:52 AM
jyl jyl is online now
jyl's Avatar
I've been learning more about how to use a steel.
I used to just go "swish swish", steeling quickly, with the knife-steel angle held at the at the angle of the edge (20 degree, let's say).
Now I'm learning to move the knife on the steel slowly and deliberately, "feeling" for the rolled-over parts of the edge. Starting close to zero degrees, repeat until don't feel any rolled-over spots. Then increase the angle slightly and continue steeling slowly, until don't feel any rolled-over spots. Continue increasing the angle and steeling slowly.
I'm getting a much better edge this way.
Old 07-27-2009, 11:41 AM
Banned
m21sniper's Avatar
I have one of those "as seen on TV" sharpeners. It works great. No idea what the blade would look like under a microscope, but after just 1 or 2 pulls a knife is plenty sharp for my needs.
Old 07-27-2009, 12:18 PM
jyl's Avatar
I concede that I'm getting a little obsessive about sharpening the cutlery.
My other frustration is that I can't get the tip of some blades (the last 1") as sharp as the belly of the blade. Problem seems to be that the blade tip flexes so that the angle on the stone is wrong - I think. Doesn't make any real difference but, well, you know - sometimes I feel under-armed when confronting an angry onion that needs dicing.
Old 07-27-2009, 01:04 PM
Banned
m21sniper's Avatar
I have the same tip of the blade problem, and yes, it annoys me too. IMO that's the part that should be the sharpest.
Old 07-27-2009, 01:05 PM
alf alf is offline
alf's Avatar
Nice post!
For stones, i find that Japanese water stones work great. Not cheap and you need 2 or three in different grits to get best results.
88 Carrera Coupe
Pelican Since 2002
All Zing, No Bling. ok, maybe a little bling.
The Roach
Old 07-27-2009, 03:10 PM
myamoto1's Avatar
This has been an interesting thread to read. I appears that many are confusing HRC with the grade of steel. Or more importantly not using both to factor the quality of the blade. In very general terms, a high carbon, high HRC blade will hold the best edge. However you will have a blade that will be very brital. The key to any good knife is finding the balace between carbon content and HRC. The best all around blade in my opinion is a damascus blade. Especially one with a high carbon insert for the edge. This allows you to take advantage of the best aspects of several types of steel, while still maintaining a very sharp edge. Here's a great resource for some futher reading:
http://zknives.com/knives/articles/index.shtml
Josh
85 M491 Coupe - "Fat Bastard"
Old 07-27-2009, 03:17 PM
Now in 993 land ...
aigel's Avatar
I got the chef's choice 130 after reading this thread. Does an awesome job. And fast too. I don't have time to fiddle with knife sharpening and elaborate systems. I am busy using knives mos the time! This really does the job well and I can not say that the machine is tough on the knives if you stay away from the coarse stage until the knife really needs it - like after de-boning a whole large critter.
George
81 SC (sold)
Old 07-27-2009, 08:22 PM
red-beard's Avatar
Typically, Stage 1 gets used after the wife has abused knives. Otherwise, nothing but stage 3 and a quick job with the steel.
James
Old 07-28-2009, 02:30 AM
jyl's Avatar
I found an interesting knife website. http://zknives.com/knives/index.shtml
A lot of information on different knife steels. http://zknives.com/knives/articles/knifesteelfaq.shtml Sharpening. http://zknives.com/knives/sharpening/index.shtml And reviews of different kitchen knives, mostly Japanese. http://zknives.com/knives/kitchen/index.shtml
Now, the guy is clearly a Japanese knife bigot, but even so I thought this info was worth reading. I wish I had a bunch of $600 hand-made Japanese kitchen knives to test.
I noticed his comments on Shun knives. His comments are lukewarm, but that is in comparison to some fairly rarified (in the US anyway) hand-made Japanese knives. Looks like he considers them better than practically anything else you can get at Sur La Table etc.
Edit: oops, I see this site has already been posted by myamoto. Sorry.
Old 09-18-2009, 11:01 AM
Freybird's Avatar
My middle school shop teacher swore by Alllen Wrench steel to finish his sharpening.
'86 911 Coupe Corner bal track aligned
'09 JCW Mini Cooper '94 Suzuki Carry 4x4
'07 BMW 530xi 6spd '11 Rancilio Silvia w/PID
'79 280zx ported, rally cam(sold) '87 and '95 300Ds, (Sold)
Wisdom begins w/ calling things by their real names; A is A.
Old 09-18-2009, 05:34 PM
where do you buy the varying grades of sharpening stones?
This thread has me fascinated. My wife could care less about our expensive kitchen knives and never, never uses the sharpener. She is tipping fresh green beans as we speak with a dull ass knife. Can you say cut finger?
'82 911
previous:
'86 951
'72 914
Old 09-18-2009, 07:09 PM
jyl's Avatar
I don't know where you get Japanese water stones, probably the Internet. Regular oil stones you can get at a knife store, or online, and they usually come in coarse, medium, and fine. And of course sharpening machines, sharpening stocks, and steels can be found at most any kitchen supply store. I'd like to know where to get the stropping stuff and the abrasive films. I've never tried those.
Old 09-18-2009, 08:55 PM
MBAtarga's Avatar
Woodworking supply stores carry water stones - Rockler and Woodcraft are two B&M retailers that I know of. They also have web sights - as well as Highland Hardward (popular woodworking supply store in near-to-me Atlanta.)
Mark
'83 SC Targa - since 5/5/2001
Old 09-19-2009, 06:30 AM
jyl's Avatar
Dredging up this thread because I took some photos that might be interesting.
They show the micro-serrations on knife blades.
This is a Victorinox serrated bread slicer, pretty new, never sharpened. You can see the factory sharpening is rough (intentionally, I think), and leaves tiny serrations on the wavy edge.
serrated mag 1
Here is a more magnified photo. It is hard to focus at this magnification, I didn't do a good job, but even so the micro-serrations are clearly visible.
serrated mag 3
By contrast, here is an old (50 y/o?) carbon steel slicer, about 14'' long, that has been re-sharpened and honed on a waterstone, the last time maybe a couple months ago. Even at lowest magnification you can see the edge is smoother, with minimal micro-serrations.
carbon mag 1
This more magnified picture again shows the relative smoothness of the edge. It also shows that I need to clean my knives better, I think that's a tiny (not really visible to the naked eye) bit from the last meat this slicer cut.
carbon mag 3
I was just given a Chef's Choice 120 sharpener for Christmas. I think I'll re-gift it back to the giver (they won't be offended - they bought me something they'd want for themselves) because, while it seems like a damn good machine based on some brief playing around, it sharpens to a 20-25 degree bevel which is not the angle I use on my knives.
I'm going to first try to take some pictures of a knife that has been sharpened on this machine, to see how the edge looks. The manual says that it produces a triple bevel with coarse micro-serrations, fine micro-serrations, and then a polished final bevel. I want to see if it actually does as advertised. First I need to go to a secondhand store and pick up a $5 knife to use for this test, because I don't want to sharpen one of my knives to 20-25 deg and then have to re-grind it to 15 deg.
Old 12-26-2010, 08:14 PM
Now in 993 land ...
aigel's Avatar
What's the advantage of the 15 degree edge? It must be sharper but not last as long? I have that machine and really like it. I do a lot of butchering and use knives in the field as well where I appreciate a durable edge. And I haven't even mentioned the other cooks in the family ...
George
81 SC (sold)
Old 12-26-2010, 11:50 PM
