Banned
m21sniper's Avatar
Opposing piston engine
http://engineeringtv.com/blogs/etv/archive/2008/07/01/opposed-piston-opposed-cylinder-engine.aspx
Very cool. New type of piston engine.
Old 03-13-2009, 04:50 PM
Zeke's Avatar
The CEO said 40% efficiency? Is that gonna work in the long run? The second chap said 3 HP per cu. foot? I hope he meant per cu in.
Old 03-13-2009, 05:02 PM
TheMentat's Avatar
gotta love the first question from the reporter after a rather technical description:
"sooo you have one cylinder for two pistons, right?"
Silver '88 RoW Carrera
Grey '06 A4 Avant
Old 03-13-2009, 05:19 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Junkers tried this with a 2 stroke diesel engine in the 40's
Old 03-13-2009, 06:03 PM
canna change law physics
red-beard's Avatar
My former company has 2 compressor designs which has horizontal opposed cylinders, to reduce the force couple. It used a 3 rod design, of which 2 were split. They were considering going to a 4 rod, double split design, so that more of the parts would be common.
The real savings is in the foundation for a compressor, since you don't have to deal with that force couple from the offset crank. It would also help in a car engine, with the reduction in weight of the block and in the less vibration transmitted to the frame. I'm not sure why they think the design would be 40% thermally efficient.
James
Red-beard for President, 2020
Old 03-13-2009, 06:05 PM
Looks like a cool idea if they can keep it funded and get it more maistream. Add some fins to that baby and make an aircooled Diesel!
Old 03-13-2009, 06:07 PM
abit off center
cgarr's Avatar
I still don't like engines whos parts have to stop and change directions.
______________________
Craig
G2Performance
Old 03-13-2009, 06:16 PM
I believe Fairbanks-Morse had an opposed piston, two cycle diesel locomotive engine back in the '50's.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 03-13-2009, 06:29 PM
Navin Johnson
TimT's Avatar
Really?
Like a two stroke or a four stoke engine where the pistons instantaneously change direction? The piston reaches apogee, then changes direction at some point the pistons motion did stop... even if for micro seconds..
Flywheels and multiple cylinders smooth things out..
'69 911 GT-5
'75 914 GT-3
and others
Old 03-13-2009, 06:34 PM
Navin Johnson
TimT's Avatar
I have seen that... I also seem to remember some tri engine with opposed pistons... may have been a marine app.. drawing a big crs blank now
'69 911 GT-5
'75 914 GT-3
and others
Old 03-13-2009, 06:36 PM
AutoBahned
RWebb's Avatar
"extremely lightweight"
yes!
Old 03-13-2009, 07:07 PM
abit off center
cgarr's Avatar
This is the one I like::
Craig
G2Performance
Old 03-13-2009, 07:28 PM
The Puff.
Mr.Puff's Avatar
http://www.rotoblock.com/howitworks.shtml
ROTOBLOCK FTW!
'70 CT1B
'11 GTS 300 Super
Old 03-13-2009, 08:36 PM
Banned
m21sniper's Avatar
Yeah, he meant per CID. :-P
Old 03-13-2009, 08:47 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Internal combustion engine efficiency is WAY less than 40% today.
Black Cars Matter
Old 03-13-2009, 09:12 PM
The RX-7 fanbois call them "boingers".
For pure simplicity, adaptability, and power per pound, you don't get more better than a rotary turbo. Want more power? Add a rotor.
Or...go newfangled:
http://auto.howstuffworks.com/quasiturbine.htm
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 03-14-2009, 07:29 AM
Unregistered
sammyg2's Avatar
I wonder how they are going to deal with the unburned fuel and cylinder lube in the exhaust, which is why the 2 stroke died in the first place?
Old 03-14-2009, 08:03 AM
red-beard's Avatar
HP per pound, it is hard to beat a turbine. Making a turbine work well in a car is another matter.
But then again, on a thurst per lb of weight basis, it's hard to beat a ram jet!
James
Old 03-14-2009, 09:07 AM
AutoBahned
RWebb's Avatar
yeh
I also wonder about those super long conn. rods on the outboard pistons...
well, we'll see what happens with it
Old 03-14-2009, 02:18 PM
Air Medal or two
afterburn 549's Avatar
Dodge tried in a Monaco about 1966........guess it worked out not LOL
At least they tried
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 03-14-2009, 04:50 PM
