Thanks for reminding me to get mine in before the dew falls. Was using it this evening, a Rigid 12" compound.
I'm an industrial mechanic by trade & used to Rigid pipe wrenches & pipe machines for threading pipe & conduit. Rigid benders work well, too. Seveeal years ago I bought reconditioned Rigid, hammer drill, sawzall, & compound miter. Had to get the drill worked on under waranty, bought a battery for the sawzall. I would recommend Rigid,
drew1 wife has 924 turbo |
Unconstitutional Patriot
Nesting the crown between the fence and base is the way I do it. Miter with saw and then cope with jig saw and Bosch 144/244 blade.
masraum, definitely go with dual compound. If you're only doing base, crown, and casing for doors/windows, one could make the argument for saving money and going with a plain miter saw. Once you get your feet wet and decide you're going to be doing this often, then spring for the $500+ sliding miter. choc, the Harbor freight saw looks alright. I'd have to play with one before putting down the cash. |
I haven't used the coping foot, but I plan to buy one soon. I've seen the angle grinder method, but haven't tried it. The biggest problem, for me, is coping where the crown goes to horizontal. You have to remove so much material and it's tough to get a clean joint.
I do agree Bosch jigsaws are great machines and a bargain for the price. I don't do for-hire work, so the only trimwork I do is on rental properties or small projects, pro bono, for friends and family. I truly enjoy trim carpentry, as it matches my perfectionist tendencies. Unfortunately, I don't get to do much trim, because our projects encompass many types of work, and currently, we (brother and I are partners) only hire out painting. However, I plan to go crazy on the next house I build. masraum, here's a link to the coping foot, Gary Katz Online, coping foot. If you plan to do much crown, you should consider it or a jig like the Easycoper, EasyCoper tool for coping crown molding cuts. I recommend you stick with the better branded saws and budget for extra doodads to make the work easier, quicker, better. good luck,jurgen |
Wow, very cool! The wife already thinks I take too long to get stuff done, I can just imagine if I started doing that.
Platinum Member
I bought a Dewalt 12" double compound to replace the 12" Rigid I had been using, which was stolen. Frankly, I liked the Rigid better, it had a slightly larger capacity, more convenient fence, and angle adjustment was smother. I typically cut crown inverted rather than using compound angles. If a wall isn't 90 degrees, it's easier to tweek a 45 cut than a compound cut. Having said that, I bought a sub$100 Ryobi to trim my vacation house. It cut almost everything I had to do. And be creative with molding choices. Instead of 7" crown, you can use a smaller crown, with base & basecap to create a larger profile. |
I purchased that coping foot product for my bosch saw from the inventor at the IWF show in Atlanta several years back. I haven't gotten around to using it yet.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
How's that IWF show in Atlanta? We get to go to Vegas here. What business are you in? |
What the heck am I typing here. I am doing it half asleep. sorry fot the typos.
jeff |
I have an older version of this and the wife didn't pay anywhere near that (x-mas gift
):Shop Hitachi 10" 12-Amp Sliding Miter Saw at Lowes.com After years of using a saw similar to the Delta vwbobd posted - I couldn't ever go back. However, for your needs, you probably don't need a 12" and don't need sliding, unless you're doing some really wide material.
Josh 85 M491 Coupe - "Fat Bastard" Last edited by myamoto1; 03-19-2010 at 12:46 PM.. |
You do not have permissi
I bought my first $100 Sears 10" a few years back. Seperating the lightweight base from the saw for transportation is only a couple screws/nuts, but they are a little tricky. Don't know if I'd want to do that twice a day.
I also promtly burned up the bag/lazer cutting outdoor pavers. It was dusty but it worked. That said, any saw is a true timesaver. After climbing off the ladder and making the same 4th or 5th cut you'll thank yourself. Using the right blades makes the biggest difference. The 10" is fine for trimwork, but it doesn't work so well on 2x8's. Depends if you need to spend a couple hundred more for something you'll only pull out of storage every five years. |
I'll probably also eventually do some flooring and would like to be able to do larger cuts than just the shorter molding size that most of the 10" models cut, so I figured either a 10" sliding or a 12". I think a 12" in that price range will probably be a better made piece than a 10" sliding, so I think I'm going to go with a 12" compound.
I was thinking about a Bosch. I can get a factory refurbished 12" compound Bosch for $279 with free shipping and no sales tax. I've read the reviews. Most were good, but there were about 6 out of 39 on Amazon that were bad (1 or 2 out of 5). Some of the bad reviews seemed legit. My other option is a Dewalt. There's a 12" single bevel (DW715) for $299 at Lowes, but HD will beat the price by 10%, so that puts it down to $269. Then another $50 for a Freud Diablo blade (same as my stacked dado blades for my table saw). There's also a dual bevel 12" (DW716) at Lowes for $339 (or $305 at HD after the price match). Checking the reviews for these, I think it was 3 bad out of 44. One of the bad reviews was "Amazon is charging too much, it's cheaper at Northen Tool & Equip". Another bad review was "the blade that it came with wasn't good enough." There was one other review of "the motor burned up in 4 months." That last one is the only one that seems legit, and even then, was it a factory defect, or was the guy trying to force the saw or in some other way misusing it? So the Dewalt seems like the way to go to get a quality part. I find that interesting, because I've heard/read a few folks over the years poo poo the "yellow power tools". I guess that like anything else, some companies excel at making certain products and may not have the same quality across all of their products. I don't know.
For wide pieces of wood a sliding saw in mandatory, compound is always nice. A friend and I did a huge(80' x 80' x12" w/ octagonal gazebo extensions at the corner) L shaped deck w/ a 10" Dewalt compound sliding saw, it was barely big enough for some of the diagonal cuts in the 8" wide planks when I renovated my house I bought a cheap 10" compound slider at Lowes, big mistake, now that is just used for trash cuts. I subsequently bought a very good Makita 10" compound slider to do the bulk of the work, It was perfect for doing molding and such. A key accessory is going to be the stand for the saw, The steel Ryobi is nice but the aluminum Dewalt nicer. You do need one of these or something similar. If the light is right I do like the laser markers but when you are set up out doors ambient light often obscures the laser line
So why do you need a miter saw table? If you've got a table/bench with enough space, would that do? Or what about making your own? I assume it just has to be sturdy.
Yes. if it lives around the garage, I put casters with stops on it. We have 2 sets of Sawhelper and their fence systems for the guys to use in the field. I like it a lot. It is durable and really tough and it sets up in minutes. actually in 30-40 seconds. The best part is that it stays accurate. In the shop, we have a slider, Festool, set up on a small rolling table with a short fence and a stop. We made our own. The reason for a commerical unit is portablity and a stop that allows you to make repeated cuts without having to measure every piece. Stops are much more accurate for that purpose. Easier for storage as well. jeff |
It depends on what you are doing but you need a lot of room for lots of projects, so you end up setting up outdoors, 10' or more on each side isn't too much. And a stand has long extentions that support the end of the board well away from the cut. If you are lucky and have a huge workshop w/ fixed bench thats fine, most of us dont have that luxury
gduke2010
Sounds like you have alot of projects planned. I would recomend a good qaulity saw and stand. Also, you might be able to find another brand like Dewault or Mikata on Craigs List for a couple hundred bucks. |
gduke2010
I ment to say 12" instead of 10". The 12" can handle most crown and base dimensions on a typical home. For example, you would be able to cut 4 1/2" crown or base without laying the blade over on a 12" compound mitre saw if you to mitre or cope the pice.
