I asked for pictures...
Originally Posted by Shaun 84 Targa View Post
of what? the building?
Yes. Inside and outside of where you plan to bring this thing into the building, as well as the access path from there to the street.
JR
Old 10-28-2010, 04:46 AM
Bollweevil
Shaun... Seriously get in touch with a sign guy.... They will understand what you are lifting, and should treat you a helluva lot better than a rigging co.
Good advice. I recently had the mast of my sailboat unstepped and stepped. The local boatyard uses a sign company to do the work. They charged $125 each way.
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Old 10-28-2010, 05:00 AM
One thing that stands out in my mind is this:
One limiting factor is any equipment on the outside of the building has to pass through an 8 foot high tunnel.
This leads me to believe that a truck-mounted crane might not be able to get right next to the building, which might rule out using a sign company crane.
More details needed...
JR
Old 10-28-2010, 05:49 AM
Shaun @ Tru6's Avatar
Correct. Here's the building. I have the second floor. To the left (dark brick) is a moving company, can go through that building but has a small door in the back to get to the back of my building.
Going through the front would be easy with the loading dock, but I would have to open up a doorway on the inside to get the press in the back production room.
Tru6 Restoration & Design
Old 10-28-2010, 06:08 AM
canna change law physics
red-beard's Avatar
Talk to Brookside, they aren't too far away (about 1 hour on Hwy 2) and they have a good selection of lifts. You will need either a telescopic unit or a 3 stage mast. I'm not sure a 3 stage mast will fit through an 8 foot tunnel.
Forklift, Used Forklift, Forklift For Sale At MachineryTrader.com - Page 1
James
Red-beard for President, 2020
Old 10-28-2010, 06:15 AM
Okay, so to get to that parking lot shown in your picture, you have to drive under something with 8'-0" clearance? And, there's no access on the other side of the building that a crane could get right next to?
In that case, your best option is a fork lift. They can be rented farily cheaply and either driven to the site, or delivered to the site on a trailer. I've done both, depending on how close I was to the rental yard and what streets were in between.
I'd give up on the making-my-own-crane idea....
You sure the windows shown are large enough to get the press throught them? You going to be the one removing them?
JR
Old 10-28-2010, 06:17 AM
here's the roof. don't think hanging anything from this is a viable option.
Old 10-28-2010, 08:17 AM
If I can rent a forklift, that would be a good option. busy day today, one sign co. I called needs truck access. considering putting it in through the front and then angling through doors. Would only need to construct a dolly to hold the press in a horizontal position. need to take more measurements to finalize.
JR
Old 10-28-2010, 08:20 AM
vash's Avatar
geez..a rubber wheeled forklift would be perfect. like this. i've run one (for fun) it is easy. this one lifts 8 tons which is much more than you need. reach is gonna govern the one that you rent.
poof! gone
Old 10-28-2010, 08:22 AM
You do not have permissi
john70t's Avatar
Please forgive the following bluntness. It looks like this is trying to squeeze industrial equipment into office space.
I'm assuming:
1. There is a long-term lease signed that will make all these relocating costs/efforts cost-efficient over time.
2. The owner has signed off on the equipment in writing, or preferably it is noted in the original lease. Important in case the floor decides it can't handle an extra 1,000lbs+.... Also, if it is not on concrete or a solid base, movement may waste a lot of raw material. Does your business insurance cover this potential loss?
3. The costs of moving the press out later on are noted.
Redoing an interior 2x4/sheetrock wall seems like the easiest solution. Those windows may not be available anymore in case of breakage, and look like a tight squeeze. A forklift operator would probably have to pivot at full lift on the narrow dock.
Old 10-28-2010, 08:33 AM
John you would do that lift from the ground with a shooting boom lift... Not a convetional forklift on the dock...What Vash pictured would be perfect... Provided it can be gotten around to that side of the building....
Old 10-28-2010, 08:57 AM
vash's Avatar
if a car is parked there, that fork can get there.
poof! gone
Old 10-28-2010, 09:01 AM
john70t's Avatar
The second half of the move is when the crane has got the thing inside, 3 feet up in the air.
Use 2-4 engine cranes or what?
The carpet's thin and trashed, but it could bunch up at the wrong time.
I'd consider putting down 3/4 plywood to distribute the weight over the floor better, don't want a wheel punching through at the wrong time. Who knows what's under it.
Old 10-28-2010, 09:16 AM
The Unsettler
stomachmonkey's Avatar
Find a new building?
"I want my two dollars"
"Brandon Won"
Old 10-28-2010, 09:30 AM
As a matter of fact I looked at 4500 square feet of space yesterday. First floor, huge garage door, right on the beach, and it was CHEAP. First thought was a half LT and half car place, then I realized the salt air would eat away the two early cars fast (I could walk 1 minute and be in the water). So I'm going to pass on it. Where I'm located for the price is excellent. I could be out in the boondocks and pay a lot less, but then I'm in the boondocks. Part of the business model for this press is I can set up a proper silk screen shop in late spring. I've got front of house office/nice and back of house industrial/work.
This is an industrial building in which the second floor was converted to office. Floor is concrete under the carpet. Don't expect any problems with the press weight.
Old 10-28-2010, 09:45 AM
9dreizig's Avatar
Send a message via AIM to 9dreizig
Shawn, move to NH,, no taxes and MUCH closer for those "I need help from Chris" runs!!!
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 10-28-2010, 09:50 AM
Zeke's Avatar
I wonder what a machinery moving company would charge. Everyone has heard of our local machinery movers, the Dunkel Brothers. Last I read about them (just a few days ago), they were installing a large outdoor sculpture. It required a crane.
I had a lift done of a spa/tub a couple years ago. I paid the guy 400 which included a tip.
Old 10-28-2010, 10:07 AM
unindicted co-conspirator
looneybin's Avatar
how can a building with a loading dock have an 8' height restriction???
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 10-28-2010, 10:46 AM
pete3799's Avatar
I was wondering the same thing.
Pete
79 911SC RoW
Old 10-28-2010, 11:29 AM
different buildings.
my building has no door in the back at all. building next door does.
Old 10-28-2010, 11:32 AM
