You need a 12 point for BBS bolts
Old 11-03-2010, 02:59 PM
Evil Genius
Rusty Heap's Avatar
PB Blaster is your friend.
but when that fails, speak softly but carry big tools:
I own full sets of 1/4, 3/8th, 1/2, and 3/4 of both 6 and 12 point.
21 Piece Metric 3/4" Jumbo Heavy Duty Socket Set
8 Piece 3/4" Drive Heavy Duty Metric Impact Socket Set
3/4" Heavy Duty Impact Wrench
This set up to 24" long fits both standard AND metric.
http://www.harborfreight.com/15-inch-18-inch-and-24-inch-jumbo-adjustable-wrenches-751.html
Life is a big ocean to swim in.
Wag more, bark less.
Old 11-03-2010, 03:01 PM
RETIRED
Joe Bob's Avatar
Dremel.....
2012 ML350 3.0 Turbo Diesel
Old 11-03-2010, 03:03 PM
least common denominator
scottmandue's Avatar
I just butter my nuts and don't worry about it.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 11-03-2010, 03:17 PM
Zeke's Avatar
Originally Posted by turbo6bar View Post
I was given one of those for Christmas last year. I haven't seen it since. So I went out to the tool box and there it was, front and center. Looks goofy to me.
I guess after 10 months I'll try it.
Old 11-03-2010, 03:18 PM
Buy 6 point sockets, 12 point wrenches.
Jim
down to jap bikes that run and a dead Norton
Old 11-03-2010, 03:21 PM
Snow tires.....
Old 11-03-2010, 03:25 PM
RedBaron's Avatar
12 Point if the bolt is tough to get to.
6 Point for normal use. I mostly use a 6 point and I always use it when I am torquing a bolt because a 12 point is more likely to strip it.
Old 11-03-2010, 03:29 PM
Shaun @ Tru6's Avatar
BFH
and so that this thread is not a total waste
Tru6 Restoration & Design
Old 11-03-2010, 03:53 PM
Unregistered
sammyg2's Avatar
And there ain't nuthin better than kroil.
Old 11-03-2010, 06:18 PM
GWN7's Avatar
Generally 12 points are thinner wall sockets than 6 point. Therefore subject to more breakage.
Bunch of old cars
Old 11-03-2010, 06:34 PM
Virginia Rocks!
VaSteve's Avatar
How much torque are you putting on the bolts?
I typically go for the 12 points first because nothing is ever easy to get to.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 11-03-2010, 06:35 PM
MBAtarga's Avatar
Try the home brew concoction of Acetone and ATF, mixed 50/50.
Mark
'83 SC Targa - since 5/5/2001
Old 11-03-2010, 07:24 PM
jyl jyl is online now
jyl's Avatar
If the ratchet on your socket wrench isn't ridiculously coarse, there's no advantage to 12 pt. For close end wrenches, I like 12 pt.
Old 11-03-2010, 07:57 PM
Originally Posted by Hugh R View Post
After you've rounded off the bolt, or nut, go to Sears and get their "Bolt out" sockets (as advertised on TV by Bob Veila). They have internal biting teeth and are really good at getting rounded nuts and bolts off.
Seconded - it's an awesome tool. Those totally saved me when I did a timing belt / water pump job on the wife's car. Steel hardware + aluminum block = all kinds of fun.
'87 924S (Sold)
Old 11-03-2010, 08:19 PM
Schumi's Avatar
12 point would only be used for 'external triple square threads' as they are referred to by the DIN.
Otherwise 6 point for any normal hex. Old 12 points will round corners off too easily.
When working on formula cars, 12 points were not allowed to be used on NAS hardware, ever.
M
Old 11-03-2010, 08:21 PM
Occam's Razor
cmccuist's Avatar
360 / 12 = 30 deg. 360 / 6 = 60 deg.
You only need 12 point if your ratchet or breaker bar can't make that swing.
Only communists and welfare recipients use 12 point.
Craig
'82 930, '16 Ram, '17 F150
Old 11-03-2010, 08:57 PM
Unregistered
sammyg2's Avatar
Color me skeptical.
Old 11-03-2010, 09:26 PM
Color me skeptical.
It works.
Old 11-04-2010, 04:11 AM
I have both. I use them where appropriate.
Old 11-04-2010, 05:31 AM
