Vibration when coasting
Does anyone have any idea why when coasting in my 01 tacoma 4x4 I get a weird vibration that I don't feel when the truck is under a load.
I am really at a loss on this. |
Rear end, how many miles on the taco?
Pinion bearing? Last edited by 911boost; 03-17-2015 at 04:36 PM.. Reason: Adding more |
The whole truck vibrate or is it coming from the front or rear?
Check for a bad u joint.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
I can' t tell if it's front or rear. It seems to be the entire truck. It's not a huge vibration but it is noticeable. |
Does it have a 2 piece driveshaft? If so, the carrier bearing may be hosed.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Did you get the memo?
Sounds like a u-joint to me.
Two piece drive shaft. I will check the carrier bearing. Thanks all
SCWDP- Shock and Awe Dept
Tire(s)?
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
Muffler bearing.
You do not have permissi
Coasting uphill or downhill?
Registered Cruiser
2nd the ujoint diagnosis.
Under load the ujoint will have no free play. No noise. Last edited by jorian; 03-17-2015 at 11:01 PM.. |
My F250 4x4 does this if I leave the Warn manual hubs locked in on dry pavement. A slight, but noticable vibration.
Wait!
Maybe your wife had the vibrator seats installed and forgot to tell you!
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
It only vibrates when she is coasting. Errr I mean when I am coasting.
When you're coasting is exactly when the vibrator is needed!
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
A Rear tire out of balance can also vibrate the car while coasting
Tires to be rebalanced to hopefully eliminate the bad vibe
