WiFi System Recommendations
House size 2200sq ft, 3 levels.
Whose system would the Trust recommend? Google. Netgear. Other? Thanks in advance.
Mercedes SL450 1979 Mini Cooper S 2017 Honda Ridgeline 2017 |
Pricey, but ease of use and performance is beyond reproach: Apple.
Ideally you would have ethernet ports in each level, but if not, you will need to figure out if the Extreme is strong enough to send to higher levels and then use an Express to repeat the signal via Wi-Fi (with a significant decay in performance). For a more robust operation, look at Ubiquiti.
Now: 2013 Cayenne GTS Ex: 1999 C2, 2004 Cayenne Turbo, 2002 C4S, 1999 BMW M Z3 Coupe, 2013 Audi RS5 |
I am leery of any product sold by Google. Period. Just my opinion.
I have a Apple router and it is pretty reliable. I put a Netgear router in for my Mother-In-Law. it has been flawless for many years.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Ubiquity. Get solid non wifi router and then you can add access points as/where you need them. Enterprise class for the home.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Fleabit peanut monkey
You clearly have a reason. Is it integrity/continuity of the signal?
1981 911SC Targa |
Takin' hard left turns
I've installed Orbi and couldn't be happier. Dead simple to set up and administer, and coverage is consistent.
Hmmm, I've been thinking of upgrading my gateway router as well. Spectrum supplied me with this Arris TG1672G (if I remember right). It works well, but doesn't cover 2500 sq ft.
I've also noticed my home office gets horrible speeds too... believe one of the walls is blocking the wifi.. Instead of getting 300 mbps, i'm only getting 40mbps. I'd like to fix this problem if I buy a new router.
23 Macan GTS 97 240SX 94 Land Cruiser Too many Miata's to count. |
I installed a Eero system (Hub + two Beacons) in my house, works wonderfully, inconspicuous, and took 5 minutes to setup.
House is basement 1000 sf, ground and 2nd floor each 1000 sf, 3rd floor 600 sf, wood frame. Somewhat noisy environment with my existing Apple Airport Extremes broadcasting two separate networks and the cable modem broadcasting a third network, plus a couple of neighbors' networks. Hub is at one corner of the ground floor (where the cable modem is), one Beacon is at the opposite corner of the ground floor, other Beacon is in stairwell between 2nd and 3rd floors. Strong signal everywhere. I get 70 Mbps at the cable modem (Mac wired to modem) and 45-50 Mbps on all wireless devices connected to the Eero.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
If you are using wifi for a laptop that doesn't move much it doesn't matter much. Personally, I would do the no wifi router and spend another $65 on a second Ubiquity access point at that location.
I've had really good experience w/ Netgear
current is an AC -2600 which works great streaming 4k content across the whole house But they do have higher and lower rated products, I love that they are easy to set up If security is an issue the Norton Core security Router might be worth looking into
Apple probably has almost as much time and money in big data as Google does. My wife was just on the phone getting her free 1 hour of training for her new watch the other day, and I heard several innocuous questions that I suspect were definitely for very specific data gathering purposes.
The difference is that you'll probably end up spending more, but the better service and lack of frustration will be worth it.
Most wifi devices are designed to send a signal horizontally, with a little vertical. You may be able to get by with a good quality wifi device in the middle, or if that doesn't work, or isn't a viable option because the entry point is on the bottom floor, then you may want to plan for having something on the 1st and 3rd floors. The second floor will probably see enough overlap that you should get a decent signal there. Obviously, if you go that route, you'll need cabling between the 1st and 3rd.
At 2200sqft and 3 levels, I assume your place is fairly small per level, and maybe kind of a long skinny-ish rectangle of 3 floors? You may have better luck with having the antennas laying horizontal aligned with the short side of your place, so the signal spreads up and down and front to back (assuming side to side is the short side).
There are two major routes (other than using one combined WiFi/router):
1. Setting up enough wired Access Points to cover the house. 2. Using mesh AP's to do the same, without running Ethernet to each. First option can be made arbitrary easy or complicated (PoE, Ubiquity, home-made OpenWRT etc.) but is the most robust. Second option is slightly slower but plug and play. If you are only accessing Internet and do not have fibre, it is plenty enough. (I helped neighbour to set up Asus Lyra mesh system. It works fine.) Wired AP's are the best solution, but overkill in most cases. I use four former 801.11ac Internet routers as Access Points (re-flashed with custom Linux OS, customized as dumb AP's, with quick roaming enabled) and one central router. I have 500Mbit WiFi link speed everywhere for 200 bucks but have spent lot's of time fine-tuning. Ubiquity kit does the same, but with hefty price markup (obviously). P.S. Also, use Ethernet cable for everything that is not moving and has Ethernet jack. WiFi is meant for mobile stuff.
Thank you for your time, Last edited by beepbeep; 01-11-2018 at 03:46 PM.. |
Thanks gentlemen.
Vulnerari Praesidio
"Wisdom is knowing what to do next; virtue is doing it." - David Starr Jordan |
Driver, not Mechanic
I would personally try to make sure I could get Ethernet to any TV or any other Internet-connected device that doesn't move. Then the WiFi could be reserved for truly mobile devices and other "smart" devices that can only connect via WiFi.
I found that even with an advertised "250Mbps", I can only get close to that speed while on Ethernet, and would be useful for consuming online video services. I have not needed to try any of those "extenders" or "mesh" type of devices so can't help you there. Though a podcast I've been listening to has been advertising "eero". Last edited by wildthing; 01-11-2018 at 08:13 PM.. |
Did you get the memo?
I installed a Google mesh type system in my in-laws’ 6000 sq ft 3 level home. It seems to provide consistent strong coverage throughout, where before their service supplier’s router would not reach many points upstairs.
At home I do not have Ethernet wiring in the walls so I am using Powerline adapters to our desktop and son’s PS4. It transmits internet through the electrical cables and gives the full 100 MBPS that I pay for consistently.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc Last edited by onewhippedpuppy; 01-12-2018 at 05:04 AM.. |
