-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   The project 911R something... (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/506621-project-911r-something.html)
78SCRSMAN 02-25-2011 08:16 PM
It's good to know there are folks following this... gives me motivation.
Thanks for all the positive feedback.
One thing I did get done is my "R" style tail lights. http://forums.pelicanparts.com/porsche-911-technical-forum/590693-911r-tail-lights-tech-writeup-bonus.html
I still need to buy some LED bulbs and get them wired up but they should be nice.
Here's another detail/problem solved. http://forums.pelicanparts.com/911-engine-rebuilding-forum/585467-engine-oil-cooler-block-off-henry.html
I've got the parts on hand but have yet to run a tap into the block for the plugs I'm using. They are OXS bung plugs which fit perfect!
schnellmann 03-19-2011 06:45 PM
Wow. Holy crap, my friend.
You have made an amazing amount of progress. And I have to say it looks simply awesome. I would expect no less though... I know how meticulous you can be. :D Seems everyone has to monkey with the glass bumpers to some degree to make them fit right.
Again, wow.
P.S. I've been meaning to check in to see what else has been going on... I'll email you.
Eharrison 04-25-2011 07:26 PM
What a project! I'm about two years behind you (no rotisserie yet). That color you chose is fantastic too. My wife spotted that color on a 356 at a swap meet a month or so back and really liked it. I think I'll be going that route too, but don't worry I'm on another corner of the US so we might not run into each other.
As I read through your posts I had to laugh at the wire wheel post about the wires flying off. I was in the shower after working the grinder last week and hidden in my cheek with 3 day beard was a wire jammed in. I only found it after washing my face and it jabbed my finger....some how it missed all the nerves and stayed in there for a while.
78SCRSMAN 04-25-2011 09:31 PM
Ooh, ouch!
I did most of that wire wheel stuff while it was cold out so they ended up in various parts of the jacket I was wearing but always found them with my hands.
***Update coming soon****
been working on the front bumper... still!
Headliner is also in the works.
78SCRSMAN 04-27-2011 09:13 AM
Okay, so here's what's going on... the front bumper is coming along nicely now. I added some strength to it by glassing in a vertical panel along the top and bottom. The one on top also serves as a mounting point to the front of the tub. I glassed in some bolts so all I have to do is push the bumper right on and fasten down the nuts from inside.
I'm using a 964 "smile" gasket as they're called. When on the car, the gasket front edge doesn't sit flush with the top of the bumper so there ends up being a 1/8" gap along the outer edge. It doesn't look that hot so I went and built up a ledge to eliminate the gap. The fit is much better now. I'm not quite finished with the filler work but will take some photos of what I'm talking about later.
Here's the process:
Ground down the split about 4-5 inches wide, all the way through the original glass.
http://forums.pelicanparts.com/uploa...1303924119.jpg
http://forums.pelicanparts.com/uploa...1303924242.jpg
Got the top part of the bumper glassed back in and sanded
http://forums.pelicanparts.com/uploa...1303924308.jpg
http://forums.pelicanparts.com/uploa...1303924361.jpg
You can see the difference here:
http://forums.pelicanparts.com/uploa...1303924390.jpg
78SCRSMAN 04-27-2011 09:21 AM
Here you can see the vertical strengthening strips I put in... this made the bumper MUCH more rigid. Also you can see the bolts that were glassed in from behind.
http://forums.pelicanparts.com/uploa...1303924493.jpg
Here are some closer pics of the ridge I was talking about. I used several layers of tape to create a wall for the filler to go up against.
http://forums.pelicanparts.com/uploa...1303924636.jpg
http://forums.pelicanparts.com/uploa...1303924763.jpg
Getting close to being ready for some primer... as you can see, it's a multi-step process.
http://forums.pelicanparts.com/uploa...1303924862.jpg
78SCRSMAN 04-29-2011 07:04 AM
Seriously???
Wait til' you see what I have to do to the rear bumper... It's a mess!
78SCRSMAN 04-30-2011 09:04 PM
Ok, I made some progress on the rear bumper... (at least I know what needs to be done) it goes like this. Cut in half like the front, then cut in half again on the corner. Why you ask? Uh cuz it doesn't fit right! WTF!!! It's not even close. Ugh!
You get what you pay for I suppose.
Anyway, here's the evidence:
A couple profile shots
http://forums.pelicanparts.com/uploa...1304225575.jpg
http://forums.pelicanparts.com/uploa...1304225614.jpg
http://forums.pelicanparts.com/uploa...1304225632.jpg
Where this is marked, I need to cut out the sliver and move arch piece closer inward and then blend the panel back in (a lot of sanding) after glassing in from behind.
http://forums.pelicanparts.com/uploa...1304225662.jpg
The license plate area wasn't quite straight so I decided to make some gussets. I use wax paper on a flat surface, wet out some mat and then cut out the shape I need. I may have covered that before but in case you missed it.
http://forums.pelicanparts.com/uploa...1304225810.jpg
http://forums.pelicanparts.com/uploa...1304226017.jpg
http://forums.pelicanparts.com/uploa...1304226034.jpg
I plan to work on the halves separately until I get them up to par and then glass the two halves back together. If you look closely at the rear end shot, you'll notice where it was cut in half, it's about an inch short of the halfway point. So yeah, I need to come up with 2 inches of bumper some how. Stay tuned!
drcoastline 05-01-2011 03:35 AM
Looks great 78scrsman. Nice glass work.
To make 2" use the bumper as a mold. Wax the surface several times with a good carnuba wax (Collinite insulator or mold release wax are best) then you can lay up the wetted matt right on the bumper. After it cures you can take a plastic putty knife and slide it between the bumper and your lay up the piece will will pop right off. You can then trim it and bond it in just like you did to the two halves of the front bumper. When you make the filler part lay it up about half thickness then when you bond it in you can lay up to full thickness that way it will be stronger and less sanding.
She is looking awesome. Great work and good luck. SmileWavy
78SCRSMAN 05-01-2011 06:31 AM
My thoughts exactly! I haven't actually done a "mold" before. I figured I would just use some car wax (I use Meguires) and just not wipe it off of the bumper. Obviously, I'll need to cut the piece I make down some as it will be slightly bigger dimensionally.
Also thanks! Glass work is actually real easy to do, it's just messy. You really can't screw it up. My "glassing tools" consist of scissors, cheap paintbrush, small plastic cup, sandpaper and a cutoff wheel. The requisite Acetone for cleanup rounds it out. All real cheap stuff. I think I'll end up having spent about $75 fixing both bumpers.
drcoastline 05-01-2011 07:42 AM
Meguiars will work just fine. You will need to do about three coats of wax to get a good build up as you said the last layer you can leave on. Your best bet would be to allow the part to stay on the mold for afew days to cure. the longer the better. Most of why glass parts are deforemed and need the amount of work they do is the part is removed from the mold to early. On your filler piece it wont be as critical but you will have much less work if you let it fully cure on the mold.
Glass work is very forgiving as long as you are not making structural parts and is very easy to make look good. To much glass grind it off, to little build up.
Can't wait for the next update.
78SCRSMAN 05-16-2011 07:46 AM
One of my pet peeves is that the arch profile doesn't seem to fit the cars profile.
http://forums.pelicanparts.com/uploa...1305560569.jpg
http://forums.pelicanparts.com/uploa...1305560597.jpg
I've seen this before in photos of others on this forum.
The trick when fixing this is not to screw up the wheel arch while altering the fender arch.
http://forums.pelicanparts.com/uploa...1305560713.jpg
http://forums.pelicanparts.com/uploa...1305560729.jpg
http://forums.pelicanparts.com/uploa...1305560746.jpg
I decided to glass in some bolts for easy install/removal
http://forums.pelicanparts.com/uploa...1305560796.jpg
78SCRSMAN 05-16-2011 07:55 AM
Making the halves whole again...
http://forums.pelicanparts.com/uploa...1305561104.jpg
Making a mold
http://forums.pelicanparts.com/uploa...1305561128.jpg
http://forums.pelicanparts.com/uploa...1305561160.jpg
Back together and yes I did this while it was on the car
http://forums.pelicanparts.com/uploa...1305561184.jpg
http://forums.pelicanparts.com/uploa...1305561233.jpg
http://forums.pelicanparts.com/uploa...1305561250.jpg
Corners are done in a similar manner
http://forums.pelicanparts.com/uploa...1305561299.jpg
http://forums.pelicanparts.com/uploa...1305561317.jpg
78SCRSMAN 05-16-2011 08:03 AM
Some final glassing...
http://forums.pelicanparts.com/uploa...1305561589.jpg
http://forums.pelicanparts.com/uploa...1305561609.jpg
Some more work I found.
http://forums.pelicanparts.com/uploa...1305561633.jpg
A couple minutes later...
http://forums.pelicanparts.com/uploa...1305561679.jpg
http://forums.pelicanparts.com/uploa...1305561711.jpg
78SCRSMAN 05-16-2011 08:07 AM
Final fitment of the front bumper before a loving block-sand then on to primer!
http://forums.pelicanparts.com/uploa...1305561910.jpg
http://forums.pelicanparts.com/uploa...1305561928.jpg
http://forums.pelicanparts.com/uploa...1305561940.jpg
http://forums.pelicanparts.com/uploa...1305561956.jpg
http://forums.pelicanparts.com/uploa...1305561968.jpg
http://forums.pelicanparts.com/uploa...1305561990.jpg
http://forums.pelicanparts.com/uploa...1305562003.jpg
Here you can kinda see why the buildup was necessary.
http://forums.pelicanparts.com/uploa...1305562021.jpg
78SCRSMAN 05-16-2011 08:18 AM
Finally done with both ends!!!
What a PITA that was. I'm just gonna say it now... If you buy fiberglass parts, consider the source. These were purchased from GT Racing. So there it is. Nuf said.
The results ARE worth the effort, don't you agree?
http://forums.pelicanparts.com/uploa...1305562369.jpg
http://forums.pelicanparts.com/uploa...1305562383.jpg
This shows the welting I will be using.
http://forums.pelicanparts.com/uploa...1305562400.jpg
http://forums.pelicanparts.com/uploa...1305562446.jpg
Arches in line like they should be.
http://forums.pelicanparts.com/uploa...1305562462.jpg
http://forums.pelicanparts.com/uploa...1305562512.jpg
http://forums.pelicanparts.com/uploa...1305562525.jpg
That's it for now. For the record, I estimate both bumpers took a total of 30 hours to this point. Another 20 hours will be about right for painting, sanding and buffing.:eek:
Now how much are my bumpers worth?
blee 05-16-2011 08:29 AM
Holy crap! Who made those bumpers? Let me guess - GT?http://forums.pelicanparts.com/suppo...leys/shake.gif It's a good thing you have the patience and skills - I would have sent them back. She's looking great Derek.
78SCRSMAN 05-16-2011 09:10 AM
Thanks Brian,
Yes, GT Racing. He did offer to return them but it would have cost me close to $200 for shipping. If I had to do it again, I would try to find some decent used pieces that you know fit well. Even with some repairable damage it would be better that what I have done.
D911SC 05-16-2011 03:16 PM
Your patience and glass work is amazing. This is one of the best projects I have seen.
Looking forward to seeing the rest of it come together.
Fishcop 05-16-2011 10:34 PM
Nice work!
Don't you find the sanding cathartic? :rolleyes:
78SCRSMAN 05-17-2011 05:36 AM
Thanks John,
Right up until my arm starts hurting anyway. The rest of the time it pretty much sucks!
jsveb 05-18-2011 05:02 PM
That is simply beautiful. Seriously impressed.
78SCRSMAN 07-19-2011 06:54 AM
Progress!
The bumpers are finally starting to look like something useful, worthy of bolting onto a Porsche anyway.
http://forums.pelicanparts.com/uploa...1311087010.jpg
http://forums.pelicanparts.com/uploa...1311087226.jpg
http://forums.pelicanparts.com/uploa...1311087261.jpg
78SCRSMAN 07-19-2011 07:13 AM
Finally I am finished painting... the body.
In the photos below the bumpers have only a couple bolts holding them on but you get the idea. Once I have the front oil cooler mounted and some brackets and such painted, I will make them more permanently installed.
I plan to continue to post my progress here but it's gonna be slow going now... the $ faucet has slowed to a trickle! ;)
Overall, I'm extremely happy with the final result. It turned out way better than I expected but was a tremendous amount of work. It's finally starting to sink in... I have a Porsche 911 sitting in my garage!
I LOVE IT!
Thanks all for following along and stay tuned for further updates as I get closer to turning the key. Got 3 more years to spare?
http://forums.pelicanparts.com/uploa...1311088082.jpg
http://forums.pelicanparts.com/uploa...1311088142.jpg
I must admit, I was a bit concerned about how the "R" taillights would look on a short hood but I think it works well on this car. I think the reflector delete is the key.
http://forums.pelicanparts.com/uploa...1311088187.jpg
http://forums.pelicanparts.com/uploa...1311088393.jpg
Fishcop 07-19-2011 03:44 PM
First class job!
I'm very close to laying down colour now too. I hope it turns out as nice!
vas930 07-19-2011 04:14 PM
That thing is just a HONEY.
Well done. Great job.
911lvr 07-20-2011 05:48 AM
very nice work.
blee 07-20-2011 06:50 AM
It's all "down-hill" now brother. Throw on the shiny bits and off you go. Well done.
78SCRSMAN 07-23-2011 07:48 PM
Thanks for all of the support, it really keeps me going. I'm very glad to be moving on to something else. The other day I began applying the hand glaze and WOW, what a difference. The surface was smooth before but now it totally has the wet look to it. It also feels very soft to the touch now.
I'll keep the updates coming every few months or so just to show my progress. My upcoming plans include: front oil cooler and lines, front and rear lighting, more wiring, some new vinyl for the interior (A and B pillars etc.), fuel tank mods and oil tank install.
Mikey83835 07-24-2011 09:18 AM
Looking better all the time Derek, I wish I had the skills, (and patience, heeh) to put one together from pieces,
78SCRSMAN 09-27-2011 07:27 PM
Quick update: I've got the front bumper finished now (How do you like my splitter?) and the rear is next for lighting and license plate bracket. I also have some suspension bits installed and am working on the interior vinyl and dash. The chassis is gaining weight now and is getting harder and harder to move around. It won't be long til it will need to be on the ground.
Cheers
http://forums.pelicanparts.com/uploa...1317180417.jpg
merbesfield 09-27-2011 07:39 PM
Very nice!
Fishcop 09-27-2011 08:14 PM
Looking great!
My market never got the 'sugar scoops', so I find them odd...
Hey Mark, how's your resto coming along?
drcoastline 09-28-2011 04:01 AM
Wow really nice work. Looks great.
DaddyGlenn 09-28-2011 09:22 AM
This is gonna be one of the nicest cars out there!
D911SC 09-28-2011 03:34 PM
I've said it before - this is one of the nicest projects I've seen.
I really love the front end, there is nothing I don't like about it.
What really makes this car special for me is the choice of color, especially the slightly darker stripes.
Pity I am on the other side of the globe, love to see it in person.
CarlP 09-29-2011 11:47 AM
Great Stuff
I'm not a big fan of grays, but this car is gorgeous! I think it even looks better than the factory special. Keep up the great work.
IMR-Merlin 09-29-2011 03:08 PM
First time I saw this thread. Great work and the fact that you are doing it yourself makes it that much greater.
I am doing all my work on my project, including paint, in my garage.
Keep up the progress pictures.
Is your rotisserie just 2 engine stands, modified and bolted together?
Brendon
78SCRSMAN 09-29-2011 04:19 PM
Brendon
Yes, the rotisserie is two stands and some scrap steel.
Thanks, BTW. After calling some different locksmiths around, I even decided to re-key my own locks. With only a few exceptions, I will have done it all.
I really appreciate all of the positive feedback Pelicanites. Thanks!
IMR-Merlin 09-29-2011 04:37 PM
Here's the basis on my project http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/567389-new-member-930-project.html. I will be jumping in on it soon, about finished with the house projects and fall is here.
Looks like I need to pick up a few engine stands first. ;)
