HarryD's Avatar
Originally Posted by OldSpool87 View Post
Harry-
Who makes this container you use?
I bought it a very long time ago from a place that is no longer in business.
There are no markings showing the manufacturer name etc
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 07-19-2018, 08:01 PM
HarryD's Avatar
Originally Posted by '76 911S 3.0 View Post
I bought one very similar to Harry's from a PepBoys, albeit it is black and red, not green and white.
Edit: Found it online at AutoZone. One thing I do remember now it I drilled out the drain port on the pan because it was a series of small holes. I used a stepped drill bit and made it one large hole. Works perfectly.
https://www.autozone.com/shop-and-garage-tools/oil-drain-pan/flotool-16-qt-drain-container/700706_0_0?cmpid=PS:3:3:1&s_kwcid=AL!5142!3!193245103672!!!g!296308263339!&ef_id=WgIZxAAAAFqE-nxO:20180719221459:s
Under the white cover of mine is an opening the size of the cover with a screen to catch the drain plug.
Harry
2020 MB E350 4Matic
Old 07-19-2018, 08:03 PM
sugarwood's Avatar
I use a $1 flexible cutting board to deflect the stream into a $2 bucket
Works perfectly. Just spread a towel underneath to catch any spill.
1986 Bosch Icon Wipers coupe.
Old 07-19-2018, 08:54 PM
If you jack the car using the Pelican insert to the jacking port, don't max out the jack & place a jack stand under the torsion bar cover at the rear. At a big enough angle the torsion bar cover, with the weight of the car, can "squirt' the jack stand out of place allowing the car to fall and create much mayhem as the car will fall down on the displaced jack stand. There is a photo on this board somewhere where the jack stand gouges a hole in the body panel. Just beware.
Old 07-19-2018, 09:30 PM
HarryD's Avatar
I have done this numerous times with no bad outcomes.
I have noticed that at times as I SLOWLY lower the car onto the jack stands, they become angled. I merely raise the car back up and adjust the stand position appropriately and lower SLOWLY again. I repeat this until I have the car on the stand and the stand is firmly placed squarely on the floor.
Can you find the picture?
Harry
2020 MB E350 4Matic
Old 07-19-2018, 11:03 PM
Bill Verburg's Avatar
If you do lift the car use something to distribute the load over a wide area, you can use wood blocks, hockey pucks etc
I use these
try not to lift on the pinch welds but if you do, use a slotted block
be extra careful of the oil line
I use 2 low profile pans a small one for the cc and a larger for the tank, I find that straddling a swale in front of the house is convenient as it provides a little more room under the cc.
A lift makes it really easy, but it's certainly not necessary
13mm socket and a 6" extension for the tank plug
put a rag under the filter when you loosen it. I cut up an old plastic milk container does the same thing.
Bill Verburg
Old 07-20-2018, 05:58 AM
tobluforu's Avatar
Make yourself some ramps with a couple 4x4s and a 2x8 on top. I have a set of 4 of these. I work on alot of cars and more than half the time dont need to jack them up. Its alot faster and safer for you and the car. They are still a bit low for working under the porsche but it even helps to use them when jacking the car up because you arnt lifting it at an angle or as high before getting the stands under it.
This! I made these last year, use them for all my cars when all I need to do oil, etc. Plus, since all of my cars are lowered, it can be a pain getting the jack under the damn cars. Roll up on these, presto, then use jack to your heart's consent. I also use what Bill posted which is a pinch weld adapter, that works awesome for the two other cars I have, in a pinch. Hardy, har, har.
Old 07-20-2018, 07:50 AM
My oil pan of choice for the 911 is a plastic concrete mixing tub I found at Home Depot. Low, cheap and very heavy polyethylene. Catches lots of oil in a hurry.
Old 07-20-2018, 08:38 AM
I jack '73911 with a floor jack with a 2x4 on it in the center of the transmission. Jack stand at the jack points for safety and drain.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 07-20-2018, 02:54 PM
zje zje is offline
I use the factory jackpad with the rear wheels on cribs. If you want a product vs. making out of wood, our host sells them:
https://www.pelicanparts.com/catalog/shopcart/TOOL/POR_TOOL_RCERMP_pg13.htm
Someone mentioned the thread about the car slipping off torsion bar covers, I believe this thread (post 6) has the pictures you were looking for:
Lifting Car Sequence
83SC Targa US
2001 VW GTI VR6
Old 07-20-2018, 03:45 PM
Banned
Great thread...thanks!
Old 07-20-2018, 04:50 PM
Discseven's Avatar
... believe Fumoto now sells this with a safety. Couple of different configs available.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-21-2018, 05:20 AM
sugarwood's Avatar
I've never needed ramps.
Rear. Jack using side adapter then jack stand on the torsion bar cover.
Front. Jack using jack point wheel well then jack stand on a-arm
Old 07-21-2018, 06:09 AM
Fumoto's are nice but you can just put a shop vac on the fill port to slow the output down. Personally I just get the oil to about 100F and use the plug to slow it.
Old 07-21-2018, 06:34 AM
