Hi, yes. I installed a new O2 sensor. The heater and ground wire connector shifted in the metal bracket and shorted. It sits in the same sheath as the Coil wires and so this melted too.
I’ve made some progress but agree that dropping the motor a bit would make testing and then installing the new harness section (if I get lucky and show the rest intact) easier. How best do I drop the drivetrain an inch or two? Never done it.
While I’m at it. As I described, the O2 heater and ground shorted which in turn shorted the Coil wires. This was a hot mess for those five wires and three that are part of an unused (on my car) plug on the engine fuse box. Two questions: 1. Did I kill the Coil when the coil wires shorted? 2. Can anyone identify the plug’s use from my pictures? I can’t find it described but would like to replace the wires anyway.
Still here
https://www.pelicanparts.com/techarticles/911_partial_engine_drop/911_partial_engine_drop.htm Disconnect the shift coupler since that would lever up as the rear drops. Support the engine with the jack, loosen the engine mount bolts. There will be no or little weight on them given the jack. You don't even have to remove the entire bolt to lower the engine a couple inches. Go slow, stop if any of the hoses e.g. breather, fuel lines on the driver side or harness at the connector in front of the engine, AMHIK about that connector, are at the end of their travel ... Use blocks of wood, 4x4s are good, under the heat exchangers just in case, you can leave the engine sitting on them while you work. Last edited by pmax; 04-06-2024 at 02:25 PM.. |
Still here
Stay safe ! I never get under there without the tires resting on something sturdy, 4x4s for example.
If you're new to jacking up the 911, read this thread Car slipped off the jack stand The breather hoses are an easy disconnect so consider removing them at the oil filler tube, one less thing to worry about dislodging. On the 3.2, watch out for the brake booster contraption as well, might wanna disconnect that, one of the sections being a $200+ item. ![]() BTW have you removed the driver's seat yet and taken a look at the DME/relay end of the harness ? Also inspect the fuse panel in front. |
That plug is used to center the idle air contoller for adjusting idle and CO. Do you have a bently manual? Only 2 wires are used for that. Not sure where the other wires go.
(Good point on the Bently Manual. Ordered... Last edited by Johnr352; 04-07-2024 at 09:58 AM.. |
I did remove the driver's seat. I can see that the O2 heater wire burned almost to the relay. I haven't pulled apart to DME connector yet, but presume the O2 Heater ground wire is in there and also sad. Aside from the DME Relay Heater wire, I haven't figured out yet which pins are for the O2 sensor wire, O2 Heater ground wire, Coil Green wire and Coil Black wire, and Idle speed adjustment wires (white, Black/White), and idle speed adjustment ground (brown). I'm presuming the DME Relay is dead. I'm hoping the DME itself is not. I'm unsure if the shorted Coil wires would kill the Coil and/ or damage the DME. From what I can see, the front fuse box is ok. The impacted wires appear to be limited to the DME/ DME Relay. |
![]() Meanwhile this may help |
the other page
Can't find the other thread where you described what happened to your harness, but if I remember correctly you didn't start the engine. So you probably fried the DME relay, but the coil wires got cooked from being too close to the O2 sensor heater wire that shorted to ground. They didn't suffer from an electric issue, but only from high temp. So probably no harm to the coil and DME (ECU) itself. Hope so anyway.
If you know anybody with a 3.2, take your ECU and swap it in his car to check if it's still good.
Gilles RoW 88 Carrera coupé |
Still here
![]() Disconnect the hose if it looks like it will be strained, I borrowed that pic from another 84 ... the 87 onwards, same as mine, has a different booster setup shown in the previous pic I posted, sorry about that. Last edited by pmax; 04-07-2024 at 11:04 AM.. |
Still here
The power to the coil comes from the fuse box. Have a close look at the black wire at the top of the fuse panel at 7 and 8, pic from my 87 your 84 might vary slightly. One of them goes to the coil, part of the 173 harness.
[QUOTE=pmax;12228185]The short went thru the DME relay, power at 30 to 87b to the fuel pump, O2 sensor heating. Hopefully that and the ground wires bore the brunt of the current so the DME's unscathed.
The power to the coil comes from the fuse box. Have a close look at the black wire at the top of the fuse panel at 7 and 8, pic from my 87 your 84 might vary slightly. One of them goes to the coil. Thanks for this. So the green wire to the coil goes to DME spot #1? And the black wire from the coil goes to the fuse box up front, as indicated in your picture (7 or 8)? Makes sense, but I’m a little confused on how the black wire gets from the coil to the front fuse box. Meaning only that, from what I can tell, all of the bad wires passed through the DME harness through the firewall. How/where does that black wire get to the front fuse box? Would tge short have blown that fuse? And, to your comment on the DME relay and 87b. Do those fuel pump wires go to the fuel pump relay or directly to the fuel pump? I might have to check/ replace something there too. |
Still here
I assume you are opening up the harness from under the seat anyways. See if you can trace the wires and check for continuity etc. Post pics ! |
