Banned
Chapeau!
Old 03-30-2019, 01:24 PM
kuehl's Avatar
1/2" drive breaker bar, (3/4" is preferred) and a 4-5 ft pipe
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 03-31-2019, 04:28 AM
Banned
Yeah, that made it. 1/2in break bar and 10ft pipe.
Thanks everybody!
Old 03-31-2019, 04:32 AM
Banned
This is one of those moments when I think “why the h**** did I decide to do this?”
This belongs to a 87 Carrera.
As you can see below, I have the complete axel out and the broken boot removed. The question is, how do I disconnect the zinged plate from the black one to access the bearings?
Old 04-03-2019, 03:02 PM
Here’s a terrific albeit long thread on everything CV. I used it when doing mine. Get a beverage and have a read. Lots of great info.
http://forums.pelicanparts.com/porsche-911-technical-forum/222537-reconstructing-constant-velocity-cv-joints.html
Sent from my iPhone using Tapatalk Pro
1987 Marine Blue 930
1982 911SC
White Plains, NY
Old 04-03-2019, 03:19 PM
Flojo's Avatar
just replace the boot.
or is there an issue with the bearing?
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 04-04-2019, 01:04 AM
Banned
Where to source these clamps?
The question is, how do I get to the bearing?
In same videos I watched you can disassemble the black piece and the golden piece by removing some bolts. In this case there are no bolts, so not sure how to disassemble it.
Old 04-04-2019, 01:55 AM
Flojo's Avatar
put it upside down and gently tap it off working all araound
that's the old Version for SC and early Carrera imho up to 1983(4?).
Old 04-04-2019, 02:41 AM
Banned
Thanks for your feedback Flojo,
I’ve tried it a few times today with no luck. I’ll try again tomorrow.
Old 04-04-2019, 05:37 PM
Banned
I’ve been trying to tap it off for the last 2 days. It hasn’t moved not even 1/32 of an inch. I’m definitely doing something wrong.
Any suggestion before I surrender?
Old 04-06-2019, 02:27 PM
If I recall correctly, you cannot replace/access the outer bearing on the G50 drive shafts. Replacement is necessary if the bearing is bad. It is an ugly job. Good luck. Steve
1970 911T SOLD
1989 3.2 Carrera
2013 991 Carrera S
Old 04-06-2019, 05:22 PM
Walt Fricke's Avatar
Here is part of the deal - by the time of your '87, Porsche did not use bolts to connect the outer CV to the output shaft flange. Before that, the outside CV was set up just like the one on the transmission side - with bolts through the stack of parts. For your year and later, the CV was friction welded to the flange, which is why you had to break that big nut loose and pull the splined shaft out. On earlier cars you leave that stuff alone.
This is part of the reason Porsche switched to selling the whole axle assembly, as there is no practical way of replacing just an outer CV.
I had thought you could still disassemble and inspect the outer CV, and then reassemble if it was still good. The notion was that if, after removing the stamped steel part which holds the boot, you could move the axle into its maximum cocked position, you could get one of the CV balls out, and keep going until you could get them all out, at which point you could withdraw the center grooved CV piece from the outer grooved part. If no pits or dents in races and balls, reassemble, regrease, and reinstall.
But if you can't get that cap piece off, you can't cock the axle far enough to start coaxing the balls out. Not a problem on the older version, because like the inner, the cap piece was held on by the bolts. No bolts, need some other way to hold that piece on.
If this repair is possible, time and money are what decides if you should buy the "everything" replacement, or just regrease and replace old boots.
Old 04-06-2019, 05:43 PM
Banned
Thank you guys.
I guess I didn’t want to accept it, and kept confusing myself comparing it with the 915 transmission.
This said, what a terrible engineering solution that Porsche came up with.
Old 04-06-2019, 08:32 PM
Well, it wouldn't be my frugal cup of tea either, doing my own work.
But it would be interesting to compare costs using a paid mechanic. The outer six bolts are harder to deal with than the ones on the transmission side, so one big nut vs six bolts. If Porsche says you have to replace the bolts, there is a cost savings there for the outers (I don't replace them, but I don't have customers, and a boss who might say do it by the book). Pulling the CVs off the axle and putting new ones back on takes some time, though not much, especially if you have the right tool to spread the clips and the CV isn't too stuck on the splines. Even something as simple as taking old boots off and replacing them takes some time. And greasing two new CVs takes some time and care, though you could probably make a fixture sort of like a bearing greasing tool with a grease nipple to speed that up. And getting the CVs to seal on the flange side, using the factory gaskets, is not as easy as it might look given the proximity of all that grease. With the grease there is some clean up time. So when you add in labor and other costs, which comes out ahead?
Who knows, maybe some day one of us will be having a beer with Hans or Ludwig or somebody who worked in Stuttgart in the '80s and knew why Porsche made this change, and we'll find out. Was it bean counters (save production line costs) or gripes from dealers or just the eternal urge of engineers to make things better (which may depend on the point of view)?
Old 04-08-2019, 09:08 PM
Ctopher's Avatar
Originally Posted by Walt Fricke View Post
Here is part of the deal - by the time of your '87, Porsche did not use bolts to connect the outer CV to the output shaft flange........
Does anyone have recommendations on cleaning the out joint since you can’t disassemble? Would I be ok with spraying it out with brake cleaner, letting it dry and repack? I don’t see any references in the manual about necessarily cleaning but just to repack. Any suggestions for those that have done it?
It’s great that this thread came up as I had ordered all new boots and was going to clean and repack both inner and outer but hadn’t noticed the distinction of the outer not able to be dissembled on 87+ cars.
Ctopher
Old 04-09-2019, 10:13 AM
I've cleaned mine so I could inspect them, so this was never an issue (nor is it at all difficult to clean them when disassembled).
Brake cleaner and an air gun should get most of the old grease out. If the boot was intact, Will be messy with when using the air gun, but I think essential - you can't count on the cleaner to turn all the grease to the viscosity of, say, water.
I can't see any reason to worry about some old grease remaining. What is worrisome with torn boots is sand, salt, or who knows what, in addition to loss of the lubricating grease.
You can buy what look like large hypodermic needles which have Zerks on them. Perfect for this application, where you can't get at both sides. Get the long kind so they can be slid deep into any spaces where they will go, and buy the grease in a cartridge to go in your grease gun.
Old 04-09-2019, 02:31 PM
Banned
After 2 weeks playing with this my conclusion is that is not worth it, at least for models +MY 86.
I ended up ordering new axel assemblies, and my wife complaining for the garage mess.
Old 04-09-2019, 06:33 PM
Ctopher's Avatar
Didn’t know they made needle tubes with zerks on them. I did buy 2 different sizes to attempt this exactly, planning on using Swepco Moly 101 grease. My driver does have a outer torn boot so will see if it’s dirty or not. It only appeared to separate when on the quickjack with the wheels hanging so I’ll see soon how clean (fingers crossed) it is inside.
Thanks for the info.
CTopher
Old 04-09-2019, 08:08 PM
Here is another thought on this friction welded deal: assuming you can't pry the outer cap off, so can't disassemble that CV to inspect, use your inspection of the inner CV as a proxy.
If there are any pits, or wear grooves you can feel with the finger (just shiny is normal), or the cage is broken, replace the whole thing on the assumption that the outer is as bad.
It used to be said that if the cage doesn't hold the balls nicely (they just fall out, and don't click into place) you should replace the CV. Whether or not this ever was true, lately (couple of years ago) I've seen brand new CVs where the balls were loose right out of the box. No choice of suppliers here, so just reuse. I'd never discarded a CV for a loose cage anyway, and didn't come to regret it.
Old 04-10-2019, 08:04 PM
