Senior Member
Zendalar's Avatar
Hypothetically: How much boost to 2.4T =) ?
This is theoretical...still.
I am building EFI for my 2.4T and after the EFI is complete, turboing/supercharging would be easy.
I am only wondering how much boost could one put to stock (well, SSI and EFI) 2.4T, I heard that 0.5bar is something that stock engines can handle.
It would be quite nice to have like 180-200hp on a 2.4T
The compression ratio is quite low on this engine so this would be suitable for little boost? Would it not?
Projects:
911 -72T EFI "964-look" "Smoky"
914 -71 1.7 D-JET "Rusty"
Old 03-25-2003, 05:56 AM
Senior Member
Zendalar's Avatar
hmmh..nobody knows...But wouldn't this be ideal because its such a low compression engine? What makes the engines fail if turboed, i mean people make these engines S spec and they can handle the HP just fine.
Projects:
Old 03-26-2003, 12:11 AM
start with .5 bar and watch your exhaust temp. when santa claus buys you an intercooler, shim the gate.
turbos fail from heat, the oil line coking up and bad driving. you must squeeze the go pedal. large throttle opennings at low engine speed put a side load on the pistons and make them go egg shaped. my 0.02
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 03-26-2003, 05:18 AM
Crotchety Old Bastard
RarlyL8's Avatar
I though about doing this with my old 2.4T w/MFI. The cylinders are steel so they should be pretty tuff. What I don't know is if the case and bottom end would be up for it. Seems 0.5bar wouldn't hurt.
Old 03-26-2003, 05:47 AM
dickster's Avatar
from the (limited) reading i've done pretty much any engine will handle .5 boost (think this should be 5psi).
why not get yourself some suitable reading material - "maximum boost" is good.
Rich
'86 coupe
"there you are"
Old 03-26-2003, 05:52 AM
Super Moderator
cstreit's Avatar
0.5 is still a good amount of boost... Remember the 930 ran with .8
I would start lower. How much boost can it handle? The answer is really how much boost can you afford to give it...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-26-2003, 06:07 AM
Senior Member
Zendalar's Avatar
Gotta find some stuff to read. ALthough...think about it.
2.4T EFI Turbo Intercooler
Nobody would come and say: "Ah, its only a mere T"
Projects:
Original Owner
tsuter's Avatar
A lot of details on my custom 3.0 SC turbo here.
911SC Turbo
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 03-26-2003, 06:13 AM
dickster's Avatar
oops, i believe i meant 5psi??
how much psi is .5 bar??
Rich
'86 coupe
"there you are"
Old 04-01-2003, 04:18 AM
Buy them, sell them
Adam's Avatar
0.5 bar is approx 7 - 7.5psi
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 04-01-2003, 04:54 AM
