Senior Member
Hypothetically: How much boost to 2.4T =) ?
This is theoretical...still.
I am building EFI for my 2.4T and after the EFI is complete, turboing/supercharging would be easy. I am only wondering how much boost could one put to stock (well, SSI and EFI) 2.4T, I heard that 0.5bar is something that stock engines can handle. It would be quite nice to have like 180-200hp on a 2.4T ![]() The compression ratio is quite low on this engine so this would be suitable for little boost? Would it not?
Projects: 911 -72T EFI "964-look" "Smoky" 914 -71 1.7 D-JET "Rusty" |
Senior Member
hmmh..nobody knows...But wouldn't this be ideal because its such a low compression engine? What makes the engines fail if turboed, i mean people make these engines S spec and they can handle the HP just fine.
start with .5 bar and watch your exhaust temp. when santa claus buys you an intercooler, shim the gate.
turbos fail from heat, the oil line coking up and bad driving. you must squeeze the go pedal. large throttle opennings at low engine speed put a side load on the pistons and make them go egg shaped. my 0.02
72 911t grey/black mine 74 914 2.0 black/ tan hers 02 g500 black/black womanproof 01 f250 psd dirty the mule 60 correct craft starflite cool 69 correct craft torino hauls butt 72 correct craft ski nautique fun 66 vw 1500s will finish someday |
Crotchety Old Bastard
I though about doing this with my old 2.4T w/MFI. The cylinders are steel so they should be pretty tuff. What I don't know is if the case and bottom end would be up for it. Seems 0.5bar wouldn't hurt.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
from the (limited) reading i've done pretty much any engine will handle .5 boost (think this should be 5psi).
why not get yourself some suitable reading material - "maximum boost" is good.
Rich ![]() '86 coupe "there you are" Last edited by dickster; 04-01-2003 at 04:19 AM.. |
Super Moderator
0.5 is still a good amount of boost... Remember the 930 ran with .8
I would start lower. How much boost can it handle? The answer is really how much boost can you afford to give it...
Senior Member
Gotta find some stuff to read. ALthough...think about it.
2.4T EFI Turbo Intercooler Nobody would come and say: "Ah, its only a mere T"
Original Owner
A lot of details on my custom 3.0 SC turbo here.
911SC Turbo
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
how much psi is .5 bar??
Rich ![]() '86 coupe "there you are" |
Buy them, sell them
0.5 bar is approx 7 - 7.5psi
1931 Oakland Eight Special Saloon 1985 BMW E28 525e (Euro 528e) 1989 911 Carrera Sport 3.2 G50 Cabriolet |
