915 case replacement questions
I had my 915 rebuilt a few years ago and parked it on the shelf until my project was ready for it. This past weekend I uncovered it to measure hub flanges and discovered some ugly cracks. When I bought it years ago I was told it was a euro box as it has the oil cooler. Serial number and part number pictures below. If this is a euro case is it any different than a regular 915 case? Is there a year of case I should try and find as the best replacement? Thank you for your assistance.
Bob ![]() ![]()
The castings are the same, so replacing the case is not that difficult. The transmission differences are in the type # and gearing, and possibly the cooler.
Strange that the case is cracked like that, especially if it was just sitting on a shelf. Are you sure it was not dropped or struck during storage? The cracks should have been visible during the rebuild process, and the rebuild aborted at the time.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
My fear is the bearing were not pressed in correctly. Didn't really inspect it that closely after I picked it up. I do know it hasn't been dropped or hit in anyway.
Thanks |
That seems really odd.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Nob..
this crack would be after major impact..can you take more pictures all aorund the trany?? as mentioned above, it can be interchanged to us model case but it will require a pro to do all the measurements for you.. Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
gearhead
No matter what replacement case you get, the ring and pinion will need to be reset. You can’t jist drop everything with the current shims.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Somebody knocked it off the shelf and don’t tell you.
Has one of my kids been over there? Tony |
Can't blame the kids on this one unfortunately.
Going to go back to the builder and have a chat about the new axels and LSD installation. All custom gears and a great 8:31 R/P. A bit of a heart breaker! |
That is flash from the casting process. Inspect it closely, and you'll see that it's excess material above the surface. Here's an empty 84 Euro case with the same issue, in the same place. They're not cracks.
Jon B. Vista, CA |
Jon,
I will take a much closer look as soon as I get home. If there aren't cracks I owe you many beers! |
That would be a huge relief
This is casting flash on my case, they are not cracks. And notice how the lines on both cases match exactly.
But if you're in doubt, you can clean the area and do a dye penetrant test.
Jon B. Vista, CA |
Transmission case: is this crack going to be a problem? Is it a crack ? Crack, a big social problem....worse in a 915
'77 S with '78 930 power and a few other things. |
Jon B you are absolutely correct.....I can't thank you enough.
Pelican truly is a huge resource and a great group of like minded enthusiasts. Next time you are in Calgary Jon I will buy you those beers! Bob |
Hey, Jon, and Bleitch, I just caught up with this thread and was going to post what you wrote! Casting flashes can scare the you-know-what out of you, but they are actually harmless. Good call, Jon.
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 10-08-2019 at 07:47 PM.. |
good eye Jon B.
