Originally Posted by Rawknees'Turbo View Post
Nathan, you know what you need to go along with those sweet Turbo flares - a manstyle boosted engine topped with a yuuuuggggeeee intercooler (your favorite, engine bay look)!
Yeah just what I want when you open the decklid, a giant aluminum brick blocking my view of a beautiful piece of machinery. someday I’ll build a turbo and do some sort of trick dual intercooler set up. Can you get sufficient enough cooling with a well engineered methanol injection system?
Old 11-12-2019, 05:31 AM
Quick visit on the celette to make sure that there’s nothing funky going on
Old 11-12-2019, 05:38 PM
Let the slow and tedious process of shaving and smoothing out the rear tub. Lots of brackets and holes to fill not to mention odd asymmetrical areas that I want to look more symmetrical.
Old 11-12-2019, 05:51 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
At least one guy in the turbo forum has a very highly modded one and is only running methanol injection - works for him. Obviously, that requires far more maintenance than an intercooler, and the system needs some kind of monitoring safeguard to alert when the methanol tank is low, or if the system stops working for some reason, but it definitely removes the aluminum slab that you don't like.
Old 11-12-2019, 05:59 PM
Yeah fail safes, plural would be a must as you say
Old 11-13-2019, 06:52 PM
Sneak peek of what’s next although I must warn you that it’s not exactly what you think
Old 11-13-2019, 06:55 PM
LJ851's Avatar
I like this thread already. Fantastic work, keep it up!
Old 11-14-2019, 06:45 PM
Thank you. Much appreciated.
Old 11-14-2019, 07:06 PM
nene's Avatar
Just getting started! Can’t wait!
Old 11-14-2019, 07:23 PM
Ruf reported that the portion of the rain gutter next to the windshield caused an enormous amount of drag so they removed it. However they went ahead and removed the entire gutter as others have done like Jimtweet on here. I wanted to do something different so I eliminated the portion that created the drag and contoured the rest. We actually did quite a bit of modification to the remaining portion by taking off the upward turned portion and also changed the angle at which it lays relative to the body. The original gutter is almost 90 degrees or perpendicular to the roof where mine now angles closer to 55 degrees. Gave it a neat little brow at the front which we may see as a reoccurring design detail in the future on this project. It’s kind of ironic that this little line detail that gives an illusion of speed quickly became one of my favorite thus far being that I called this portion of our company Speedline. I couldn’t be happier with how it came out. What do you guys think?
Old 11-15-2019, 09:21 PM
. . . What do you guys think?
I think it's absolutely kickass - the turbo powwwaahhhhhh of rain gutters! Very very cool!
Old 11-15-2019, 09:26 PM
LJ851's Avatar
I think the modified gutter looks really good! Did you still have to weld the gutter after removing the folded portion of it and if so, was that less painful than full gutter removal ?
Old 11-16-2019, 04:24 AM
Yes you still have to weld it and depending on your equipment and skills I think it is easier to weld than complete removal. One of the tricks is opening and cleaning out the crap in between to the 2-layers
Old 11-16-2019, 07:32 AM
Lol thanks Hawkeye
Next up are the trim panels. Cleaned up and simplified. Front door cap’s profile depth wise was significantly reduced so that it lines up better with the custom dashboard.........to be continued along with a rear trim panel cap
Old 11-17-2019, 06:02 PM
Eva
911SauCy's Avatar
OH MY LANTA!!!
These are the nip-tuck details that only the true enthusiast will be able to acknowledge on the final product...yet they will make the car so dramatically different than all others.
Tremendous.
Also, popcorn in the micro. Waiting for MOAR Progress
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 11-18-2019, 07:16 AM
I sold my 930 nearly a year ago. I miss the shape, the power and the presence. I don't miss how she was a PITA and refused to steer ... I ran sticky 315 R888Rs in the back! Great stance, but ... understeer. Then again she stuck like glue!
Old 11-18-2019, 12:40 PM
You calling the gutter mod "LA gutters" or "Hollywood gutters"?
Old 11-18-2019, 08:03 PM
Originally Posted by 911SauCy View Post
OH MY LANTA!!!
Tremendous.
Thanks man I appreciate the encouragement
Old 11-18-2019, 08:48 PM
Lol yeah I tried but those were both trademarked
Old 11-18-2019, 08:51 PM
