(man/dude)
Still trying to figure out if this is a functional improvement over the WEVO or if incorporates some sort of gating system in the shift tower.
Anyone know how it works?
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
that's why WEVO has the gate to implant INSIDE the 915
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
(man/dude)
I agree that the WEVO gateshift is a great solution.
Schleprock
WEVO initially tried the gate field in the shifter (similar to a typical Ferrari gated shifter base) and decided it wasn’t entirely successful. So they moved it to inside the transmission
G50 has an internal gate similar to what WEVO devised for the 915. Take a look at the PET parts diagrams for the G50 and you can see it very clearly
Kevin L '86 Carrera "Larry" |
I have installed the Stealth shifter. I had to have the base plate machined to accept the heater lever. I also have threaded the shift rod extender to accept my early screw in shift knob. The threading is cocked and I need to do it over. I also installed the Stomski coupler. I also replaced the completely worn out gearbox and motor mounts. The gearbox has stock bushings. The motor has Wevo black.
I need work on the adjustment, it is not optimized. Overall shifting is completely different. I am having to relearn shifting. There is no vagueness which confuses me. It is not obviously in gear because it enters the gear so quickly and positively. I think it is an improvement but it has changed the character of the car. Too soon to tell if the character is improved or not. I have a long drive planned for tomorrow so I should have a better assessment ![]() ![]() ![]()
1966 912 to 2.7 Frankencar |
Mo money = mo parts
Greg 86 Coupe (stock - pretty much like Butzi designed it) 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
I think there is less slop over my worn out OEM shifter. I also installed the Stomski coupler at the same time. I still need to adjust it. Sometimes when downshifting from 4 I hit 5 instead of 3. The other thing I did was replace the trans mount bushings and engine mount bushings.
I was hoping to get a dramatic difference and that did not happen. I might have been able to replace the worn parts and got a similar result. Further adjustment is on my long to-do list. I really want the 4-3 shift to be more precise.
ChrisHoover - how is the Stomski shifter working out a year later? Does it help the 1st to 2nd shift at all on the 915? Do you notice the shortened shift in all shifts, or just the forward and up shifts (3 & 5th)?
I have a 902 gearbox. I think the improvement is marginal. I have to hunt for 3rd. I often land on 5th. That’s probably is an adjustment problem I need to fiddle with.
the shifter
I have tried them all.This just works.I just bought the great bushing from J Novak.I installed his bushing on a stock car and it was a nice steady improvement.My Stromski is the best as are all his creations.We are lucky to have talented people like this in our midst.Ciao
Best shifter out there, I worked my way up to it and then I hit the home run..
Yes you should do all the other bushings and mounts first or you're wasting time, then the home run is unicorn tears. I tried Swepco, very good stuff, I liked the Amsoil synchromesh better, then I found this, https://www.amazon.com/gp/product/B000NUES82/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&th=1 Genuine Ford Fluid XT-M5-QS Full Synthetic Manual Transmission Fluid - Silly price but it is a game changer on my 915 with 300k on it.
I'm not picking my nose..I'm porting my upper intake manifold. |
Anyone using Numerick?
I am looking at the Wevo and then found Nermerick. Anyone have any history with this shifter? the coupler comes with the kit?
Are you referring to the Stomski Stealth shifter? Thread got a bit confusing. Sent from my iPhone using Tapatalk
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
Racer
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
I'm back with Swepco for this go round, Check back in a year..
I forgot to say the tranny is rebuilt now and I used a nice 5th gear from Matt Munson. Zoom zoom.
Thread Tools | |
Rate This Thread | |
