My green and black wires are actually solid blue and blue/white. They run the the motor
I cant believe it!!! The connector to the body from the door on the passenger side had come loose. I reached in and pushed it back on and now all the windows work perfectly
Analog Air Cooled
Awesome... Yep..I had the same thing on a different electrical gremlin. Look out for oxidized pins on connectors too.. shine em up and presto!
86 Targa 91 964 13 6 SPD Cayenne |
I am so happy for you! That is fantastic news!!! I am glad you found it.
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things. |
Sweet! The free and simple fixes are always the best
2000 Boxster S and 2016 Audi A6 |
YESSSS!!! Great news
Give it a shot of Deoxit or similar switch cleaner to clean it properly.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Can you Edit and Copy the resolution post into the #1 post of this thread?
This will help people in the future
1986 Bosch Icon Wipers coupe. |
Reiver
Enjoy your windows....
De Oppresso Liber Strength and Honor 5th Legion |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Connector.
Is the pass window feed all window switches as per the CKT I sent you.
Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Jd21476 -- see in the pic above (post 62) that there's an open hole in your door jam below the top door hinge. That hole should contain a pin switch that turns on/off your interior light when your passenger door's open/closed.
Do you have a functional pin switch installed on the driver's side? Reason I ask is that, at least on my '86 targa, the pin switch also triggers a relay in the power window circuit that, if not triggered, can cause your battery to drain. Specifically, the relay's designed to leave the power window circuit active/powered between the time the ignition is turned off and a door is opened. If the door pin switch isn't working (or isn't there), the relay disabling the window circuit won't trigger and the window circuit will remain energized and pulling just enough of a load from the battery to drain it within a week. Fortunately, easy to check -- with the ignition off, open the driver's door and see if your power windows still work - if they don't (but do work with ignition on), you're in good shape -- however, if the power windows continue to work with ignition off and door open, something (else) to get working |
I'll check it out. I also have power mirrors but for some reason they are disconnected. I cant seem to find the wires within the vehicle but there are wires coming out of the mirrors and the control mechanism in the drivers door is still in place.
Wildman Emeritus
Been having some intermittent pass window issues and have a new switch which I planned to install on the driver's door. Saw this and gave it a try then took a test drive. May have been the real issue as the connector may not have been fully seated after bare metal, disassembly repaint. Never even considered this connector. Time will tell.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
