Fuch wheel question? Can someone help.
I have a 1973 911E and I am considering switching from the cookie cutters to fuchs. I need to know what to look for to purchase the correct set. I do not know anything about them and it seems like I need to know numbers on the rims and sizes etc. Please inform me!
Old 05-06-2020, 04:30 AM
I'm good with tools.
AG81's Avatar
Pete, If you want a date correct set I'm no expert.
Size wise you would be looking at 15 x 7.
There should be a little caricature of a fox's head stamped on the backs of all early Fuchs.
There should be a 901****** part number stamped on the back.
THIS IS A GOOD READ----> Real Fuchs vs. Replicas
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 05-06-2020, 04:52 AM
pistolpete -- are you looking to stick with 15" diameter wheels (which have very limited tire availability these days) or switch to 16" diameter wheels (with better tire availability)?
Old 05-06-2020, 05:44 AM
Bill Verburg's Avatar
Stock '72 would have had 6x15 ET36 Fuchs w/ 185/70 tires, currently the best available 185/70 x15 is a Pirelli CN36 repro which uses modern construction and materials
7x15 ET23.3 can be fitted but you will want to keep tire od down, 205/55 is good , 205/50 also works but some don'y like the short sidewall look, 205/60 is getting too tall and 216/60 is definitely too tall especially in back
Bill Verburg
Old 05-06-2020, 09:13 AM
Rescuer of old cars
Arne2's Avatar
As Bill noted, the 6" wide is correct and the best fitment. I recently put a full set on my refreshed '72, and the fit is correct and perfect.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 05-06-2020, 10:33 AM
The tires I have on there right now are 195/65/15.
I would like to keep them. What would work with them?
Old 05-06-2020, 02:21 PM
6x15 or 7x15
Old 05-06-2020, 02:22 PM
Rescuer of old cars
Arne2's Avatar
My silver car pictured above has 195/65-15 on 6". Fit is fine.
2018 718 Cayman 2.0
Old 05-06-2020, 04:02 PM
