Help finding thermo time switch
car is a '69 E with a '72 T engine. A real pro said I need part #911-617-117-08
but I can't seem to find this anywhere. does this make sense? Any suggestions?
thanx. steve
Steve Meltzer
'69 911E/bastard
Old 10-24-2020, 07:36 PM
ROW '78 911 Targa
timmy2's Avatar
MFI engine? Carbs?
Not aware of them being used on cars that early.
74 and newer CIS engines use them for the cold start injector.
Installs in drivers side chain case, two terminals stick out.
See photo
https://www.pelicanparts.com/More_Info/91161711700.htm?pn=911-617-117-00-INT
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 10-24-2020, 08:04 PM
MFI equipped cars have the thermo-time switch mounted to the oval shaped engine breather cover in the center of the motor towards the front.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 10-24-2020, 08:32 PM
E Sully's Avatar
Try part# 911-617-117-00 for the thermo time switch.
The 73.5 listing for a thermo time switch is incorrect.
The MFI and 74 on CIS used a thermo time switch, but the 73.5 first generation CIS did not.
Ed
1973.5 T
Old 10-25-2020, 07:14 AM
This might be a good place to mention that I finally got frustrated with the thermo-time switch operation on a couple of MFI inducted cars (mine and my son's). It just doesn't seem to work all that well, often vastly under-priming a "lukewarm" car, like one that has sat for just an hour or two. It seems to get "confused" and shuts off the priming flow too early.
I went ahead and removed them and installed later breather covers without the hole for the thermo-time switch. I then wired the bypass solenoid to a momentary contact switch - a push button - that I installed in the dashboard. This gives the driver full control of the delivery of the priming charge. Both cars start much, much better now, when in that "semi-warm" state. And, well, just better overall.
Jeff
'72 911T 3.0 MFI
Old 10-25-2020, 03:27 PM
thanx guys ( i assume) it's MFI and the first mechanic did bypass the TTS...straight to
the solenoid....adn yes i have a push button system, as Mr. Higgins suggest, but still seems semi-reliable. Not a CIS car. thanx steve
Steve Meltzer
'69 911E/bastard
Old 10-25-2020, 07:18 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
I eliminated the thermotime switch as well. Put a switch on the rear tunnel cover. When in the on position, the starter would send power to the cold start solenoid. Worked perfectly (sort of like a choke on a carbureted car).
Chris
73 911 E
Old 10-27-2020, 09:39 AM
I may need to revisit this to make sure the switch I have is sending all of the electrons.
thanx again steve
Steve Meltzer
'69 911E/bastard
Old 10-27-2020, 09:51 AM
You can always call and talk to the humans at Pelican Parts. Tell them what you are looking for. They can help you.
Old 10-27-2020, 10:52 AM
I've called them before and gotten excellent service....i think i even wrote the guy's name in my database...but never thought of it, since I had pro helping. thnx steve
Steve Meltzer
'69 911E/bastard
Old 10-27-2020, 11:33 AM
