msmall215's Avatar
LSD-friendly trans fluid: what are you running these days?
'82 915 with a factory ZF 40% LSD going in, mated to a 3.6. Car will be largely street use with a few track days a year.
What are folks running for transmission fluid?
Mike
'85 3.2C
IG: @msmall90 | @zuffenphilly | @ruchlosrallye
Old 01-12-2021, 05:16 PM
Red Line Service
Marc Bixen's Avatar
Kendall 80w-90 w/ LSA
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 01-12-2021, 05:35 PM
Titanium User
Same. 3.6 w/ 915 LSD.
Buy some Titanium Lug Nuts!
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html
ig: @ti_porsche_products
Old 01-12-2021, 06:39 PM
Rescuer of old cars
Arne2's Avatar
That's what I ran in my 915 with LS as well. '84 3.2.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 01-12-2021, 06:52 PM
msmall215's Avatar
And our host sells it...well, that was easy, thanks to all!
Mike
'85 3.2C
Old 01-12-2021, 07:05 PM
Racer
winders's Avatar
I never understood why anyone that wants their LSD doing LSD things would put an oil in their transmission designed to cause the LSD to be less effective.
I would recommend Swepco 210....with no LSD additives.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 01-12-2021, 07:37 PM
I like the Kendall without the additive. Put up with the minor groan on turns.
206 637 4071
Old 01-12-2021, 08:04 PM
Instagram:@blacklistracer
RagingBull's Avatar
I use Mobilube 1 SHC 75W-90 and have a Guards GT2 Pro LSD in my 3.2 G50.
Bolt-on Turbocharged 1987 911 3.2 Carrera G50 - Stock Engine (10.3:1 P&Cs), GT3582R Turbo at 0.5bar, Protomotive Intercooler, Protomotive Headers, Protomotive Fuel Pressure Regulator, Titanium Exhaust & Resonator, Titanium TiAL F46 WG Pipe, Titanium Air Filter Plumbing, RUF Speedlines, RUF Strut Brace, RUF Steering Wheel, KEP Turbo Clutch, Koni Adjustable Shocks, 23/29mm TBs, WEVO G50 Shifter, 996 Turbo Brakes.
Old 01-13-2021, 03:31 AM
scumbag
I currently have Torco RGO 85w-140 in my 915 w/Kaaz 1.5way.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
AchtungKraft #009 - IG: @doktor_b
Old 01-13-2021, 06:16 AM
Mutha66's Avatar
+1 for Kendall
Old 01-13-2021, 06:25 AM
LSD additives do indeed diminish LSD chatter, however when used in a transmission
with gear sets included in the case which includes the LSD, the friction modifier
can compromise the syncromesh operation of the gearsets.
This from a gear oil manufacturer :
However, there are some exceptions to these guidelines. Unfortunately synchromesh does not like friction modifiers. They make it slip when it is trying to grip, and could cause the gear change to become difficult. Hence a problem arises in some front wheel drive cars where the synchromesh gearbox shares the same oil as a plate type LSD.
However, on my 3.6 with a 915 LSD trans, I did use Kendall w/LSD additive and
have had no shifting problems, but on my next change I will use Kendall without
the LSD additive.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 01-13-2021, 07:09 AM
The G50 is a different beast from the 915. It likes synthetic gear oil so your choice is fine, but for my 915 I stick to the non-synthetic stuff.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 01-13-2021, 08:18 AM
Bill Verburg's Avatar
Delvac for G50(used to be called SHC
Swepco for 915, factory calls for 75w-90 so I use 201 or 202,
no additives in any of the above
Bill Verburg
Old 01-13-2021, 08:57 AM
Swepco 201 for the 911/01
Motul 75w140 in my gt3rs and 964 LSD boxes. No additives.
I've run Delvac with good results in the above 2 cars.
Old 01-13-2021, 09:43 AM
Racer
winders's Avatar
Swepco 210 (80w140) is a better 201. It flows better in the cold (check the spec sheets) and handles heat better too. Paul Guard is the one that turned me on to Swepco 210. Well, I was trying to find a better oil for the 915 and Swepco 210 look best to me on paper. When I chatted with him about it he agreed that is was the best choice. I also found out that Swepco 210, not 201, was the Swepco oil that was finally able to get the 935 ring and pinions to live over 24 hours.
Scott Winders
PCA GT3 #3
Old 01-13-2021, 10:19 AM
This thread started with question about LSD in a 915 transmission.
I appreciate the comments about G50s, but their syncros are not affected
nearly as much by the LSD friction modifiers as the 915 with Porsche syncros.
Back the 1940/50s, the Porsche syncro system was State of the Art, and highly
praised. As we all know, the Borg Warner syncros which came along later and now used in most modern transmissions such as the G50 are highly superior, unfortunately we're stuck with the Porsche system in the 915. The 915 syncros need all the help they
can get to keep our gears from grinding and LSD friction modifier in the gear oil
certainly won't help the situation.
Old 01-13-2021, 10:22 AM
MotorWorks's Avatar
Swepco 201 in my 915
Matty
1979 911 SC RoW Slicktop
Old 01-18-2021, 04:11 PM
(man/dude)
Jonny042's Avatar
Swepco 201 is widely regarded as a top contender for 915 use. Given the cost of trans rebuilds, even though it hurts to spend that much money on 3 litres of oil I regard it as money well spent.
The TDS for 201 from Swepco states is has "Limited Slip Differential Additive • Limited Slip Differential Additive Insures proper frictional characteristics to eliminate chatter, shudder"
https://www.swepcolube.com/sites/default/files/package_inserts/swepco_201_multi-purpose_gear_lube_sales_brochure_j03567.pdf
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 01-18-2021, 04:41 PM
Johnny at Transaxle Engineering in Chatsworth CA sold me the Swepco 201 after he rebuilt and an install of a Porsche factory LSD in my '80 915.
Always take the high road, it's far less crowded - Charlie Munger
Old 01-18-2021, 06:38 PM
RETIRED
Joe Bob's Avatar
I’ve been using the 201 since my first change back 89. Used similar Swepco products in VWs starting in 69.
Old 01-18-2021, 07:11 PM
