Missing CVJ Spring Washer
In replacing the CV Joint Boot on my 911SC, found the 901.332.311.10 Cup Spring (aka spring washer, joint spring, etc) is missing. Looks like they are NLA. Any thoughts as to what to replace it with, or what will happen if I leave it out? Not sure how long it ran this way, but doesn't seem to have caused any problems -
TIA
Old 07-09-2022, 02:11 PM
You’ll have to buy used, try dc auto. If not I might have one
Old 07-10-2022, 05:48 AM
You can use the Schnor washers instead, AND drill the bolts for safety wires. They never come out then.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-10-2022, 07:48 AM
Just use Nord-Lock washers and be done with it. No safety wire needed.
Old 07-10-2022, 08:19 AM
Thanks for the replies. To clarify, this is the spring washer (or Belleville washer) that fits on the axle below the CV joint. I assume this absorbs shock and takes up some of the slack between the CV joint and circlip. Seems like there is some debate as to whether or not it's really required. I can see where it might be important to retain it.
I've dug around trying to find a suitable replacement, but nothing I can find comes close. Too small, too thick, etc -
Old 07-10-2022, 09:23 AM
you need that ...
Old 07-10-2022, 11:42 AM
If it's what I think it is, check McMaster Carr assuming you have one to measure.
Old 07-11-2022, 05:32 AM
Post a WTB ad in the classifieds.
I have mailed CV small parts for free to several people over the years.
Unfortunately for you, I moved a few years back and chucked out my big box of cvs and parts and axles and have none to send. Fortunately for you, there are probably hundreds of guys on here with the same box of parts.
Old 07-11-2022, 07:00 AM
While it appears from their on-line catalog that out host does not carry them, there are "axle flange" or "CV joint boot with flange" kits available that do include this belleville washer. A quick search revealed several sources. A phone call to our host may reveal they actually do carry them, there are many parts that either do not show or are very difficult to find on their catalog site.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 07-11-2022, 08:13 AM
It appears that our host shows that the belleville washer for the 930 (901 332 312 00) fits the SC. I will give that a try -
Thank you to everyone for their replies and help on this!
Dale
Old 07-11-2022, 10:10 AM
Dashman0
Pelican has them # 901 332 312 00 cost $8.00
Old 07-11-2022, 10:50 AM
Earthling
Brian Cameron's Avatar
Hey Dale, did the 930 cup washer work for your SC axle?
I've run into the exact same issue on my CV rebuild and if it worked for you, it should work for me (better than $500 plus for a whole axle assembly)
thx/Brian
1996 Porsche 993 C4. His
1979 Porsche 911SC - sold... and now BACK again! Hers
2021 Volvo V60 (foul weather drive)
2024 Volvo XC60 (spousemobile)
Old 07-24-2022, 04:29 PM
Earthling
Originally Posted by ClickClickBoom View Post
This is my solution:
Nord-Lock NLX
Sent all the unused extras out, but they are easy to source. Mine have stayed tight as a drum!
Umm please see post #5: this is NOT the washers for cv bolts.
It is the gigantic washer for the AXLES. Goes on the axle, then the cv joint assembly goes on the axle, then the c-clip holds the above in place.
Old 07-24-2022, 07:18 PM
Fortunately (but embarrassingly enough), I found the washer. Dug through the trash and pulled out the old boot, and found the washer buried in all the grease at the bottom. Hopefully, Pelican is correct that it will work, and will probably be ok. Let us know what you find (or if you find it!)
Dale
Old 07-26-2022, 04:04 AM
Earthling
Lol, sounds like something i would do. In this case the axle was rebuilt by a previous owner and i was rebuilding again due to a torn boot when i discovered the missing c-washer. So it is long gone.
Anyway i have ordered the 930 version from our host and will update here when i get back to this job.
Old 07-26-2022, 07:16 AM
Earthling
Update: the 930 version was too big for the axle on my 79SC unfortunately. Maybe it would fit some of the later model years, not sure.
However as Jeff noted above, our host sells a CV boot kit 923-332-037-00-M60 which includes the elusive washer! Ordered that just for the washer and it fit perfectly.
Plus the included CV gasket was a godsend when one of them got contaminated with grease and fell off during installation of the axles.
Old 12-31-2022, 02:56 AM
