Pelican Parts Vendor
UROParts's Avatar
Hi everyone, good news - the current estimated restock date for URO Parts wide-lip Windshield Seal 911 541 225 03 is the end of July 2024.
Originally Posted by David Liam View Post
I recently put a URO front windshield seal in and I noticed the outside lip had noticeably more length than the Porsche brand one, which can help on corners, etc. One improvement that would help is more length on the inside on the top. The much thicker aftermarket headliner could have been causing issues too. Overall they work well, especially if you are having difficulty with other manufacturers. The Porsche brand rubber seems different than 10 years ago, smaller or something...
Thanks for the report David, your suggestion is noted!
Tags: 91154122503, 911 541 225 04, 91154122504
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2
Old 06-25-2024, 09:06 AM
WOOHOO! I've been waiting/watching patiently
Old 06-27-2024, 02:24 AM
proporsche's Avatar
i guess no news about the seal without the trim...?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 06-27-2024, 03:47 AM
UROParts's Avatar
In my experience every car is a little different and each rubber fits differently. The orientation of the rubber on the glass makes a huge difference when you are trying to fit the trim. I use a thin nylon ish rope (2 mm or so, no too thick) with soapy water in a spray bottle. The windshields often go in low if you are not careful. I like to use little foot long sections on each side to center the windshield before the final pull. I have never used the "Porsche Windshield Glass Spacer - 91454190710 " but I recently purchased some for next time, I hear they help.
Thanks again for your suggestion regarding the inner lip width David, our engineering team has been advised! More width would also help cover the transition line between UV-faded headliner material and the original color that was shielded from sunlight behind the original seal lip. Using thin 2mm rope is also a good idea, it's probably easier to pull through the tight gap between the seal and glass.
Haven't heard about using Windshield Glass Spacer 914 541 907 10 on a 911, could you direct us to a thread(s) about it? We've heard that it's easy to accidentally position the glass too low, so spacing up the glass makes sense. Found two related threads on 914World:
Tags: 91454190710
Old 07-16-2024, 11:14 AM
UROParts's Avatar
Ivan
Hi Ivan, sorry, no plans for it at this time.
Old 07-16-2024, 11:27 AM
proporsche's Avatar
seal
thanx for the update
Ivan
Old 07-16-2024, 12:46 PM
Tags: 91454190710
Now that you mention it, a longer lip on the inside would be ideal.
PCA Member since 1988
Uro: Thanks for your responsiveness and efforts to improve the product. I have had my seal in for 5 years, and so far no cracking or shrinking or loss of pliability.
I may be preaching to the choir, but please also ensure that the material quality is maintained or improved. We know from experience that stuff made in China will get cheapened with lower quality material over time, especially when the Chinese supplier thinks the customer isn't watching. Rubber products are among the worst offenders. Otherwise, keep up the good work.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-16-2024, 02:29 PM
UROParts's Avatar
Ivan
Hi Ivan, this might not be accurate, but we've heard that it might be possible to use 1989-1994 Windshield Seal 964 541 225 00 with a 964 windshield on 1965-1989 cars to eliminate the trim.
Can anyone confirm?
Thanks Pete! You are absolutely correct, it's very challenging.
Old 07-16-2024, 03:27 PM
kfosburg's Avatar
Send a message via AIM to kfosburg Send a message via Yahoo to kfosburg
Is this still on track for late July 2024? I really, really could use one right now!
Thanks,
Karl
Old 07-22-2024, 10:27 AM
UROParts's Avatar
^ Hi Karl, updated ETA is mid-August, so still mostly on-track!
Old 07-22-2024, 04:24 PM
'87 Targa
I'm watching this thread. I will need one in the next couple months.
Old 07-28-2024, 08:47 AM
kgieg's Avatar
My windshield is waiting, looking forward to it.
A fair exchange is no robbery.
Old 07-28-2024, 04:12 PM
Waiting with baited breath!!!! Whats the best way we can find out they are available, to snatch them up ASAP....before they are NLA again?
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 08-09-2024, 08:46 AM
kfosburg's Avatar
Any update? Several of us are pretty desperate with giant holes in our cars...
Odd that I don't see that part number listed on the URO website...
Thanks,
Karl
Old 08-12-2024, 09:39 AM
UROParts's Avatar
Hi guys, our warehouse currently has "URO Parts 911 541 225 03" available for retailers to buy or drop ship. Not sure why Pelican isn't currently listing our seal, maybe because it was out of stock for quite a while. We'll ask them to make the item live again.
Retail orders can't be placed on our website because we only sell wholesale, but the application data is here: https://apaindustries.com/parts/17716
Old 08-12-2024, 09:49 AM
So Pelican doesn't have it. Sierra Madre says it's out of stock. I REALLY need 2 of these ASAP and cannot find a vendor. So frustrating!
Old 08-12-2024, 12:28 PM
UROParts's Avatar
Thanks guys, we're putting the word out to our customers, thanks for your patience.
Old 08-12-2024, 12:44 PM
I'm ready to purchase. Def need a seal ASAP
Old 08-13-2024, 02:19 AM
Try Summit Racing
Old 08-13-2024, 03:45 AM
