pass side window not working
yesterday the pass window went up and down today it does not!
driver side works fine. obviously not the fuse.. or driver side would not work. i tried to jiggle driver side switch for pass window and pass side switch… jiggling had worked in the past, ultimately I replaced switch on pass side. again when i parker the car yesterday everything worked, today not! |
I had a similar problem and wasted a bunch of time replacing the switches since they are notoriously unreliable. I finally figured out that the passenger side wire that goes from the body into the door had a kink in it and would randomly lose connection.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!! |
Had same problem with the Ford150 passenger window, turned out a well-hidden $5 relay was the culprit and testing it confirmed.
solved! loose wire in the door. mirror tilt should be that simple!!
| Tags |
| window motor , window switch |
