OsoMoore's Avatar
A generous friend brought over his engine mount, yoke, and extra-high jack stands.
His yoke is a generic HF adjustable one, and I'd be more comfortable with a solid Porsche one that has a larger contact surface. So I'm looking around to see if I can get one used.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 06-26-2025, 01:48 PM
The porsche yoke is definitely optimal and also has the advantage of being able to split or assemble the case on the stand, remove the flywheel etc.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 06-26-2025, 03:42 PM
OsoMoore's Avatar
Ordered a porsche yoke, drained the oil, and jacked it as high as my 3 ton floor jack will take it. Now time to unscrew, disconnect, and decouple things for an hour or two. Engine drop planned for Saturday.
I guess I need to revisit engine drop strategy videos, it has been a while. Last times I did it with two jacks under the engine, bringing it down onto a big piece of cardboard. Then slid it out and used a 2x4 to ratchet it up onto my furniture dolly.
Also repairing a bicycle tube for my daughter.
Old 06-26-2025, 05:49 PM
OsoMoore's Avatar
Picked up a HF motorcycle jack this morning, I've seen it recommended and used in various threads here. I think I'll need to fabricate a cradle from some wood I have around.
Old 06-27-2025, 06:50 AM
Counterclockwise?
Does the handle clear the bumper?
Rod
1986 Carrera
2001 996TT
Old 06-27-2025, 06:53 AM
OsoMoore's Avatar
I don't have time to give it a try until Saturday. I'm already considering removing the bumper in order to save the 3-4 inches of extra drop distance.
So I'm not sure about the handle.
Old 06-27-2025, 08:23 AM
OsoMoore's Avatar
Engine is out! Minor complication as I found the motorcyle lift was not great for the drop - couldn't slide far enough in to be under the center of gravity. So I swapped to the two-jack method.
It might work fine if you drop engine-only.
But now I've moved onto the pair of moto lift and small jack under the transmission, and after I split the case I think the moto jack will be fine for moving it around and getting onto the engine mount.
Next step - split of the transmission, and start into the Rebuild book.
Old 06-28-2025, 12:19 PM
Counterclockwise?
Well done!
I see lots of cleaning in your future as well. If that’s your thing.
Rod
1986 Carrera
2001 996TT
Old 06-28-2025, 01:10 PM
OsoMoore's Avatar
Well done!
Definitely lots to clean. I cleared the transmission very well a few years ago, and the CIS when I rebuilt it. But the rest needs it badly.
Old 06-28-2025, 02:18 PM
Sorry if I missed this… but is this your first time dropping a 911 engine? The pace of progress makes me feel like a slacker for not dropping mine yet to do some stuff.
Old 06-28-2025, 02:47 PM
OsoMoore's Avatar
This is my 3rd or 4th drop (same car). I rebuilt the transmission some years back, as well as doing the clutch and rebuilding the CIS.
Old 06-28-2025, 06:05 PM
OsoMoore's Avatar
I need to figure out the best general purpose cleaners to use for external areas as I go. Just Simple Green and a bunch of paper towels? Much of this is very filthy from oil leaks accumulating dirt.
Old 06-28-2025, 06:24 PM
I use Simple Green Pro HD (purple) diluted 4:1 in my parts washer. It is safe for all metals (when used as directed) and breaks down grease really well.
1990 928 S4
1998 Boxster
1978 911SC coupe
Old 06-28-2025, 07:01 PM
OsoMoore's Avatar
Status so far!
  • Engine dropped
  • Transmission split
  • Tools reorganized
Some other repairs I've found that I need to do, probably while waiting for the yoke which takes a week to arrive:
  1. Repack CV joints (one large split boot, one small split)
  2. Repair cold start injector wire
  3. Repair thermotime switch wire
Other activities:
  1. Clean engine
  2. Bag and box the parts already removed
  3. Better organize the removed spark plugs for analysis when engine is open
  4. Remove CIS
That all starts with buying various tools and supplies today, such as a magnetic bowl and sturdy rubber gloves for cleaning.
Old 06-29-2025, 05:57 AM
Counterclockwise?
Your first post you made it sound like you were a rookie
Rod
1986 Carrera
2001 996TT
Old 06-30-2025, 06:22 AM
OsoMoore's Avatar
I am feeling rookie-ish. Opening the big box is going to be a challenge, and I don't know what sort of costs I'll find inside.
Old 06-30-2025, 11:14 AM
OsoMoore's Avatar
I discovered (rediscovered?) that you don't store your transmission on its end, because it will slowly leak out of the fill hole. Store it flat in the normal orientation as in the car. So that was a small mess, and now I have to remember to re-top it off.
I did begin removing the CIS. The EGR system is a big pain in the butt, but I was able to get it off and get to all the intake header bolts. So mechanically the CIS is separate.
I need to decide if I'm leaving all the electrical stuff on the engine, or taking half of up it with the CIS. I was going to keep it intertwined with CIS, but now I'm thinking I'd rather keep it below. Not sure.
I guess it all comes off eventually anyway, so I could just take it off now. Taking lots of videos!
Old 06-30-2025, 06:50 PM
NOLAsc's Avatar
Subscribed...
"... changing without pain or agony not only in bulk and shape but in color too, approaching the color of wind ...."
-- William Faulkner
Old 06-30-2025, 07:40 PM
OsoMoore's Avatar
CIS Removal went along without any issues. I removed EGR and all the intake bolts, detached all wiring from it. Lifted it off solo with a little bit of wiggling.
Wiring came off along with the shroud, as the wire for the fan goes through the shroud. Noted a few of the shroud bolts are slightly longer, but all seemed the same thread/head. Not sure that matters.
The area behind the fan where the big oil tube comes up was quite messy, possibly a leak source. The fan itself was a bit hard as I couldn't rotate the belt off as normal with the engine unable to turn. I loosened the fan strap, tilted it forward, and was able to slide the belt off the engine's pulley instead of the fan's.
Valve covers came off next and looked pretty good except of course #3. Pictures in next post.
Old 07-01-2025, 04:57 AM
OsoMoore's Avatar
Side-note, several cylinders were flooded with oil, as seen when removing the intake manifold.
I think it was 2, 4, 5, and 6. Will double-check later.
Old 07-01-2025, 05:00 AM
Tags
911sc , rebuild
