Now to start pulling off the exhaust. Found some interesting things.
The joint between the heat exchanger and the crossing exhaust pipe on the 4-5-6 side was full of oil. Probably half a cup came out when I opened that part up. Note that my destroyed valve was 3. Taking off the heat exchangers wasn't as tricky as I feared. The inner bolts on the exchangers were actually just stacked with washers, maybe as a stand-off? Not sure how that worked. But that meant I just had the 8mm studs and then 3 nuts per side. 4-5-6 side was pretty oily, especially at 6. ![]() 1-2-3 was not as oily. Here's a video of her as she stands now. (May take a minute to be available). https://youtu.be/6zh79LVmjPE
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
Video of the from the top. Three is the boomed cylinder.
Video from the bottom.
Obviously I want to know why this happened.
Is there anything I should note, record, or measure as I take things apart to help me identify the cause? I'm trying to take a lot of photos and some good videos, but I don't know what to look for besides "the broken parts" and "lots of oil/dirt" where it shouldn't be.
PCA Member since 1988
Take pictures as you disassemble it. The valve guide is gone, so I would want to know where that went.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
Good work, Opening the chain box covers should be enlightening. I noticed in the video the sump cover is on, did you take it off to drain the oil and then put it back on ?
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Cam housing covers are now off. I need to identify the correct Porsche Tool(s) to remove my camshafts. I took some careful pictures, so that should help me identify the right ones. Then while I'm waiting for the special tool, I can clean things up. ![]() ![]()
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Engine Rebuild Subforum Thread
i know this is off topic, but how loud is that exhaust setup your're running?
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Counterclockwise?
Hi Mike. Pretty loud WOT. Burbles a bit at idle. I can drive it under the noise radar, but when I’m on it you notice me. Lots of compliments at the track on how nice it sounds especially when bouncing off a wall.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Big surprise in the engine teardown thread - the camshaft bolt was loose! Going to see where this leads...
https://forums.pelicanparts.com/911-engine-rebuilding-forum/1179839-1979-sc-chewed-valve-total-rebuild-2.html#post12493691
I think I may have located the instigating failure. The rocker shaft on the valve rocker that failed was far far out of alignment.
https://forums.pelicanparts.com/911-engine-rebuilding-forum/1179839-1979-sc-chewed-valve-total-rebuild-3.html#post12494493
I must be getting old... looking for something quieter these days
| Tags |
| 911sc , rebuild |
