-   -   911 engine codes (http://forums.pelicanparts.com/porsche-911-technical-forum/121529-911-engine-codes.html)
sdjaytee 02-12-2017 11:42 AM
Hey guys thanks for responding.
The info I have is that the engine def wasn't original to the car not do I think it even came from a targa. The car was restored in the late 80s or 90s and a 3l was put in. I'm not sure what 3l it is.
JJ 911SC 02-12-2017 12:08 PM
Originally Posted by sdjaytee (Post 9470714)
... I'm not sure what 3l it is.
ignoring the serial #, the 930/07 would be from a 1980 SC US/Cdn/50 State legal.
Do you have the Transmission Model #? The match would be 915/63
sdjaytee 02-12-2017 01:12 PM
I'll look for the transmission number
djpateman 02-12-2017 05:02 PM
Originally Posted by sdjaytee (Post 9470162)
Numbers from the pics
6274874
930/07
I think someone has fudged one of those numbers; that looks to be an impossible combination.
ossiblue 02-12-2017 05:14 PM
The "7" in the type number doesn't look like a factory font--note the down stroke on the left side of the top, and the angle of the full leg of the 7--much different than the 7s in the serial number. Agree, it's an impossible combination.
sdjaytee 02-13-2017 09:52 AM
interesting, ill get a better pic of the number as well
turre 02-13-2017 01:02 PM
Can someone help me with this engine nr. *909751*
JJ 911SC 02-13-2017 04:26 PM
0 Series, 1967 911 Coupe
Matching Chassis Ser # between 305101-308511
3,421 produced
turre 02-13-2017 10:57 PM
3,421 produced
Thank you! What do you mean with 0 Series?
JJ 911SC 02-14-2017 02:27 AM
0 was the original series of the 901/911, A was the 1st revision;
0: 1964-67
A: 1967-68
B: 1968-73 and so on https://en.wikipedia.org/wiki/Porsche_911
sdjaytee 02-15-2017 03:11 AM
Better pic of the serial, is it a fake?
http://forums.pelicanparts.com/uploa...1487156839.JPG
djpateman 02-15-2017 05:08 AM
I am not positive, but it does look reasonable even if the 4 looks a little different.
http://forums.pelicanparts.com/uploa...1487164056.jpg
http://forums.pelicanparts.com/uploa...1487164065.jpg
http://forums.pelicanparts.com/uploa...1487164076.jpg
ossiblue 02-15-2017 08:01 AM
Originally Posted by djpateman (Post 9474351)
This is the number that caught my attention. Perhaps you, who have much more experience than I on these matters, can comment on the "7" in the type number. That's the one that looks highly suspicious to me, but I'm not familiar with the fonts for the type numbers. I just assumed they were the same as those used for the engine serial numbers. Again, focus on the "7". Secondarily, look at the "0" in front of the 7. It also has an odd appearance--much narrower than the "0" in the serial numbers.
http://forums.pelicanparts.com/uploa...1486878491.JPG
djpateman 02-15-2017 10:06 AM
Kind of fuzzy, but they do look the same. It almost makes me wonder if the two photos are from different engines.
http://forums.pelicanparts.com/uploa...1487181945.jpg
http://forums.pelicanparts.com/uploa...1487181954.jpg
ossiblue 02-15-2017 12:42 PM
Thanks. I have never studied the type numbers closely, but from your two photos, the "7" does look consistent. Obviously, the font is a bit different than that used for the serial numbers.
Still can't reconcile the engine number with the type number on the op's engine. Seems way out of sequence for the 930/07 to be associated with the 77 engine number.
djpateman 02-15-2017 04:23 PM
I have looked at a few more images on my home computer, and if I was to guess, then I would say the 930/07 is factory stamped. The serial # has a few disturbing features: the surface that is stamped is very smooth like a later engine case, not a pebbled surface; the star seems a little larger; the 6 seems to be round not ovaled; the 4 has a much shorter leg. So, if anything, I would say the serial is a good forgery; but why make it an impossible combination.
DanDKClassicCar 05-02-2017 02:44 AM
Hi
I hope someone can help me out here.
Can you tell me the specs + year on this engine:
6302573
930/09
And this one:
It should be from a 911 Carrera RSR 1974
6660552
930/02
(Maybe it's a modified engine, but need the real/original specs)
3.0L, 6 cyl. Twinplus Boxer, 280 HP?
Thanks Danny
JJ 911SC 05-02-2017 04:58 AM
Originally Posted by DanDKClassicCar (Post 9572310)
Hi
6302573
930/09
3l from a 1980 SC
And this one:
6660552
930/02
3l from a 1977 Carrera
Thanks Danny
Since you are in the business you should get this book: https://www.amazon.com/Porsche-911-Red-Book-Specifications/dp/0760347603/ref=sr_1_1?ie=UTF8&qid=1493726217&sr=8-1&keywords=porsche+911+red+book
DanDKClassicCar 05-03-2017 01:29 AM
Originally Posted by JJ 911SC (Post 9572365)
Thank you very much. I will definitely buy this book.
I found some data by Google 6300001 (930/07) and 6660001 (930/02)
But i didn't found that the 6302573 - 930/07 was a 3.0, so thank you for that.
-6300001 (930/07)-
Engine number: 6302573
Type: 930/07
Porsche 911SC (U.S./Canada)
Year: 1980
Produced: 4.272
9.3:1 compression ratio
Oxygen sensor (Lambda sonde) fitted
Tree-way catalytic converter
180 horsepower @ 5.500 rpm
175 foot-pounds torque @ 4.200 rpm
-6660001 (930/02)-
Engine number: 6660552
Type: 930/02
Porsche 911 Carrera 3.0 (I-program)
Year: 1976
Produced: 1.093
Weight: 1.120 kg
8.5:1 compression ratio
200 bhp @ 6.000 rpm
255 Nm torque @ 4.200 rpm
Luccia at Pelican Parts 05-03-2017 09:05 AM
We have the Red Book in stock and available here as well: Porsche 911 Red Book 3rd Edition BK216896 - BK-216896 | Pelican Parts. It is a really great book with a lot of information. :)
