bigrubberjeep's Avatar
Any reason to have a chip mode/non-chipped mode?
Any reason to have a chip mode/non-chipped mode at the flick of a switch?
I thought I had seen this in the past, just cant find it.
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 09-02-2004, 09:13 AM
magilla's Avatar
I think the reasoning was for performance on one side, and stock on the other. The stock would be better for fuel economy and for emission inspections.
The one you are referring to is likely the "no bad days" (sp?) chip. I think Ingo and MikeZ might be involved somehow.
'83 SC Coupe- Blk/Blk
'03 Daughter- 10fingers/10toes
Old 09-02-2004, 09:17 AM
Certified Pre-Owned
BGCarrera32's Avatar
I don't have the luxury of a switch, but I did have a chip burned with a 2800 RPM rev limiter if it ever needs to go to the body shop. Should keep the car in the parking lot...
'84 Carrera Coupe
Old 09-02-2004, 09:21 AM
Hilbilly Deluxe
emcon5's Avatar
Smog checks and fuel quality immediately come to mind.
Tom
82 911SC Coupe
GTI Cup #43
Old 09-02-2004, 09:22 AM
Is it a good "makes sence" idea for the sake of fule economy, or is it easier just to swap chips for emissions since fuel economy wont bemuch different?
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 09-02-2004, 09:26 AM
I've seen this offered for 944's.
A "plug" is insertd into the motherboard and a cable with two receptacles 'hangs out" outside of the box. Something like that. Wouls make chip change-out easy w/o opening th box.
Emissions, etc. as stated would be another influence....
--Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 09-02-2004, 09:50 AM
Certified Pre-Owned
http://frwilk.com/944dme/
Click on dual EEPROM adapter
'84 Carrera Coupe
Old 09-02-2004, 10:03 AM
Administrator
Jack Olsen's Avatar
I have the NBD chip, with the switch. I only run the performance settng with 94 octane fuel. My concern would be the risk of pinging with poorer fuel, which is all that's available in California. I don't believe there's a two-position chip available for 3.2's, which is a shame, since there's no knock sensor on those motors. In my opinion, NBD and Steve W should get together and make this happen.
Old 09-02-2004, 10:42 AM
Jack:
The conceptual problem I have with the switch is what do you do when you have a "blend" of fuels ? You typically don't run either case to a "dry" tank condition.
What's really needed is a dynamic system that adjusts automatically, by retarding timing and "X"....when there is imminent pre-detonation...like today's modern cars....going back up when higher octane fuel is sensed.
Wil
Wil Ferch
Old 09-02-2004, 10:58 AM
I am hoping Steve chimes in with some "good news"
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 09-02-2004, 11:00 AM
Original Owner
tsuter's Avatar
I have an electronic "chipswitch" on my key fob for the VW NB. Three installed programs: Race, Stock, Valet.
Anyone got teen age drivers?? You figure it out.
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 09-02-2004, 03:08 PM
Irrationally exuberant
ChrisBennet's Avatar
The multimap 3.2 chip is "known technology" to Steve W and other the DME hackers on the board.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-02-2004, 03:34 PM
buttjoint's Avatar
I have the steve w chip in my 3.2 and no problem passing emisions.
Old 09-02-2004, 04:27 PM
I'm no DME hacker, but it seems like it would be very easy to do, really. The chip for a 3.2 DME is what - a 27C64? Get a 27C128, burn both maps in it, and toggle the A13 line with a buffered switch. Whether on nor you should do it is another question.
Chris M
1985 911 Carrera w/ 3.6
Old 09-02-2004, 07:07 PM
Bingo. You can even have 4 maps with a 27C256. They don't even buffer the switch (which seems a little odd but apparently works).
-Chris
Old 09-02-2004, 07:51 PM
-Chris
I personally would be uncomforable with that. For me, I'd wire the switch into the input of a D flip-flop and hook the clock input of the f/f to a R/C delayed rising edge. Capture the switch state at power on and keep it that way until power down. I don't like the idea of maps randomly changing while driving. But that's just me.
Chris M
Old 09-02-2004, 08:02 PM
no! in short if you bought a Steve Wong chip, you have a better running car so why would you want to go back.
Keith Epperly 87 turbo look carrera cabriolet opps forgot slant nose!
Old 09-02-2004, 08:29 PM
That's the point of my question.
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 09-02-2004, 09:05 PM
