Any reason to have a chip mode/non-chipped mode?
Any reason to have a chip mode/non-chipped mode at the flick of a switch?
I thought I had seen this in the past, just cant find it.
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
I think the reasoning was for performance on one side, and stock on the other. The stock would be better for fuel economy and for emission inspections.
The one you are referring to is likely the "no bad days" (sp?) chip. I think Ingo and MikeZ might be involved somehow.
'83 SC Coupe- Blk/Blk '03 Daughter- 10fingers/10toes |
Certified Pre-Owned
I don't have the luxury of a switch, but I did have a chip burned with a 2800 RPM rev limiter if it ever needs to go to the body shop. Should keep the car in the parking lot...
'84 Carrera Coupe |
Hilbilly Deluxe
Smog checks and fuel quality immediately come to mind.
Tom |
Is it a good "makes sence" idea for the sake of fule economy, or is it easier just to swap chips for emissions since fuel economy wont bemuch different?
I've seen this offered for 944's.
A "plug" is insertd into the motherboard and a cable with two receptacles 'hangs out" outside of the box. Something like that. Wouls make chip change-out easy w/o opening th box. Emissions, etc. as stated would be another influence.... --Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Certified Pre-Owned
'84 Carrera Coupe |
Administrator
I have the NBD chip, with the switch. I only run the performance settng with 94 octane fuel. My concern would be the risk of pinging with poorer fuel, which is all that's available in California. I don't believe there's a two-position chip available for 3.2's, which is a shame, since there's no knock sensor on those motors. In my opinion, NBD and Steve W should get together and make this happen.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Jack:
The conceptual problem I have with the switch is what do you do when you have a "blend" of fuels ? You typically don't run either case to a "dry" tank condition. What's really needed is a dynamic system that adjusts automatically, by retarding timing and "X"....when there is imminent pre-detonation...like today's modern cars....going back up when higher octane fuel is sensed. Wil
I am hoping Steve chimes in with some "good news"
Original Owner
I have an electronic "chipswitch" on my key fob for the VW NB. Three installed programs: Race, Stock, Valet.
Anyone got teen age drivers?? You figure it out.
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
Irrationally exuberant
The multimap 3.2 chip is "known technology" to Steve W and other the DME hackers on the board.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
I have the steve w chip in my 3.2 and no problem passing emisions.
I'm no DME hacker, but it seems like it would be very easy to do, really. The chip for a 3.2 DME is what - a 27C64? Get a 27C128, burn both maps in it, and toggle the A13 line with a buffered switch. Whether on nor you should do it is another question.
Chris M 1985 911 Carrera w/ 3.6 |
-Chris
no! in short if you bought a Steve Wong chip, you have a better running car so why would you want to go back.
Keith Epperly 87 turbo look carrera cabriolet opps forgot slant nose! |
