adomakin's Avatar
thanks blokes. by the way, just bought some dodgy looking mag called excellence or excellent or excitement or something that had a tatty old black 911 in it..................................not bad jack!
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 12-17-2003, 11:07 PM
Administrator
Jack Olsen's Avatar
Thanks.
Now try to imagine adding a full inch and a quarter, or five centimeters, to each of those rear tires.
You're talking wide.
Old 12-18-2003, 12:14 AM
adomakin's Avatar
are them lights an RSR spec light jack or your own breed?
Andy
Old 12-18-2003, 11:42 AM
Bill Verburg's Avatar
You're talking wide
and you're talking camber, how much are you using? It looks really radical for a street car.
Bill Verburg
Old 12-18-2003, 12:36 PM
Administrator
Jack Olsen's Avatar
The lights are 911R style. Not correct for a 911 RSR.
I think the camber is about 3 degrees, maybe less. I'll have to look it up. The big wheels and the shape of the flares make it look more exaggerated, I think.
Old 12-18-2003, 09:23 PM
adomakin's Avatar
going back to the big tyre issue, the inner offset on my banded 11x15 fuch's is 121mm. does this mean that i should be able to use 345/35/15's?
Andy
Old 12-19-2003, 01:42 PM
Crotchety Old Bastard
RarlyL8's Avatar
With only 4 and 3/4 inches of backspacing you need to measure from the mounting surface on the hub to the suspension arm bolts and see how much room you have.
Yokohama 345s are 3/4 inch wider than Pirelli 345s. Makes a big difference in this tight fitment.
Old 12-19-2003, 06:07 PM
