Help Removing Flywheel Seal
So I've tried the method below to no avail. If I pry any harder the screwdriver will break. The seal is as hard as a rock. Any suggestions?
Thanks, John
1985.5 944 GTS |
I used one of these. I call it a crow's foot, but I think it is listed in the Snap-on catalog as a close quarter prybar. Its about 6" long. It pulled my seal out on the first try and more importantly, it did not leave a mark on the end of the crank. Just make sure you do not insert it too far or it will scratch the seal surface on the case.
I know alot of people do not use the Snap-on trucks, but I'm sure you can find something similar to this at a tool supply store. Or maybe online?
Weaver '88 911 Targa '03 911 Turbo, X73 Susp. '13 Panamera GTS PCA member Central Indiana |
Only thing I can think of is to apply a little heat with a small propane torch. I'm not speaking from experience but I can't think there is anything else you will damage by heating up the seal just to soften it up a bit. I just put my case together with a new seal. Anybody else have any ideas?
Steve F 69 911 71 911 87 Carrera 2004 RAM 1500 4x4 "Hemi" |
John - I just did this last week. The method you are trying didn't work for me either so I took a screwdriver and drove the tip (gently, with a rubber mallet) into the small opening at about 1:00. This pressure deformed the seal enough so that I could then pull it out.
Doug '81 SC Coupe |
Look here:
P234 flywheel seal tool
Current: 07 S4 Avant, 06 Volvo S60R Sold: '74 911, 01 986, 93 Volvo 240 |
Air Medal or two
just run in a course screw and put the slide hamor on it,,,,,if its real stuborn do it in a couple of places.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
I see you already tried to crush the seal at the "open slot" on the right hand upper side. Take a hammer, a screw driver, and deform the seal some more at that slot (indent, or what you call it). When there is enough of an opening for a flat end of a screw driver or seal puller, stick it in, pry it out carefully, and it will come out.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
This helped:
Sorry to revive an old thread here, but this really helped me with a stubborn flywheel seal.
The picture shows the tip of an extractor/slide hammer tool. I inserted a wood screw in the back end of the tip, screwed it in and then tightened the tip with a hose clamp. It did not work to secure the screw with the hose clamp alone, it needed more of a mechanical barrier. I think it also helped that I crushed the seal lip at the 1 o'clock position.
1981 Pac blue SC 3.2L |
Read the link in post 5.
John, i have the same tool since ever..it does the trick;-)
ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I bought a seal removal tool from HF, works really well.
nothing worse than scoring the side of the case. its just like the one JW posted in the link.
