I did not see anyone here with a G50 tranny carrera (except for the patient). I think Zoanas better make a post asking for that one trick it takes to separate the G50 from the 3.2L engine. It is not the same as the 915 tranny.
And if you wanna take out the axles, better have a big a$$ socket (what size?) 3/4 inch breaker bar (I got one), and an 8ft pipe (Vash must have one).
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-11-2004, 03:03 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
I'm thinking of dropping the tranny with the motor - bad idea?
I have the socket for the axles, and I think a breaker bar somewhere. I've removed them before.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 06-11-2004, 03:12 PM
I am thinking of dropping the tranny too, but you still need to know how to separate the two. There is a trick with the 915, I don't know about the G50.
Old 06-11-2004, 03:19 PM
UFLYICU
ZOA NOM's Avatar
Oh, OK. I have plenty of hammers.
prc-racing.com
Old 06-11-2004, 03:37 PM
buttjoint's Avatar
Ya have to pull out the shaft that holds the t/o bearing to seperate the two. Any problems just ask some one here.
Old 06-11-2004, 04:48 PM
DanTheCat's Avatar
Originally posted by ZOANAS
I know, I'll make a list of chores for the folks not wrenching or drinking...
Oh, um, you know, I just realized that I need to, um, wash my hair, or something. Yeah, that's it...
Actually I need to work on my tan, maybe I'll just bring my speedo and hang out with toby at the pool.
Um...
(no, i don't own a speedo, i'm kidding. sheesh!)
Dan
'78 SC "foxy brown"
'69 Datsun "qt"
'91 Civic SI "the stereo"
Old 06-11-2004, 04:56 PM
UFLYICU
ZOA NOM's Avatar
Thanks, buttjoint
Dan, my pool is a "no speedo zone". That means the speedo limit is 0.
prc-racing.com
Old 06-11-2004, 05:35 PM
Not a bad idea, in fact you have no other choice! The Bentley manual is very good for the G50 cars and I would recommend having it there. Think of the engine and transmission as one unit suspended by 2 bolts on opposite ends.
Why do you want to mess with the Axle stubs? Installing new CV's? If not, just remove the 6 bolts from the transmission flange carefully and pull them out of the way. Me and my brother reinstalled my engine in my 89 coupe Tuesday night. Any questions about the G50 removal/installation, I would be glad to help.
Old 06-11-2004, 06:04 PM
Randy Webb's Avatar
3 guys better than 2
young, strong, flexible guys better than old, stiff, cranky, weak guys
You need:
1 or 2 jacks
some rubber pads/lots of cloths
a plate to hold the engine on the jack
3 jack stands
2 concrete blocks
beer + pizza but not before
Old 06-11-2004, 06:13 PM
Registered abUser
TerryH's Avatar
If you do the beer first, you won't need the rest of that stuff like tools, etc.
Wish I could join in and get some hands on experience, but alas, I'm out of the area.
'81 911SC Coupe SOLD
Old 06-11-2004, 06:38 PM
Randy Webb's Avatar
A lift can help -- this also shows a way to support the engine balanced on a jack with jack stands for support. The concrete blocks are below just out of the foreground.
Old 06-11-2004, 08:17 PM
Now in 993 land ...
aigel's Avatar
I pulled my engine by myself. Put it back with 3 guys total. It can be done all by yourself. Don't forget though, putting it back = gravity not on your side.
George
81 SC (sold)
Old 06-11-2004, 08:51 PM
jyl jyl is online now
jyl's Avatar
I'd like to drop by, but if it's overcrowded already then maybe I can get in on the re-install.
Either way, you're welcome to use any tools I have. I have an ATV jack and miscellaneous other tools. You can hold on to the jack for the reinstall too.
The ATV jack is very useful. I dropped and re-installed the motor/tranny from my '89 G50 last year, all by my lonesome. My garage is too small for even two people - see pic. The ATV jack really helped.
Old 06-11-2004, 09:40 PM
UFLYICU
ZOA NOM's Avatar
Quick update - June 26-27 is a go. I've PM'd 11 of you guys that have offered to come by, and JYL, I just saw your last post. The ATV jack sounds like it would really help. I have a couple of small floor jacks and one large one, but no more than that. What are some of the methods and configurations for the jack/pallate/engine cart, etc.?
Also, I'd like to hear some suggestions for the "while it's out" list. Just the budget friendly stuff. I plan to replace the sound pad, and do a thorough cleaning of the bay, but there are probably lots of little things that would be nice to do with the motor out.
prc-racing.com
Old 06-15-2004, 05:30 PM
Randy Webb's Avatar
dropping the tranny with the motor = easiest way, IMHO
search on while & out & engine -- you'll find a lot of stuff. A repaint of engine comp. might be a good thing. At least detail it. Wax will help you keep it clean (until the wax is all gone in a year or two).
Old 06-15-2004, 06:14 PM
UFLYICU
ZOA NOM's Avatar
Thanks Randy
prc-racing.com
Old 06-15-2004, 06:44 PM
Talking ATV jack
Just bought an ATV jack at Kragen on sale for $59.95. My guess is that you could borrow one.
Might also thing about borrowing an engine stand to help with cleaning.
I would enjoy seeing one pulled but sound real crowded.
Good luck..... Think about R&R of engine mounted thermostat.
Old 06-15-2004, 07:46 PM
jyl's Avatar
Zoanas, sent you a PM.
It's pretty trivial with the ATV jack, no fancy balancing.
- Cut a piece of plywood to sit on the jack,
- jack up the car,
- loosen (just a little) the two bolts that mount the engine and the two that mount the tranny,
- slide the ATV jack under the engine (the balance mount is right at the join between the engine and tranny), because of the ATV jack's geometry you don't want the engine all the way "back" on the jack or the muffler will interfere with the ATV jack, by the way the engine can sit on the heat exchangers without damaging them,
- lower the car as much as you can and still reach the mounting bolts,
- raise the ATV jack to meet the engine, remove the bolts,
- then raise the car and lower the engine, checking every inch or so that you're not fouling or damaging any lines,
- eventually, when the rear of the car is jacked up really high (I forget the exact measurement but the rear bumper was about the height of my solar plexus), you'll be able to roll the ATV jack out with the engine on it,
- some people remove the rear bumper/valance, I'd rather just jack the car a bit higher
- one way you can jack the car is with a floor jack under the rear edge of the floorpan (use a length of 2x4 to spread the load) and jackstands under the jacking points by the rear t-bars, by alternating jacking and repositioning the jackstands you can get the car very high, if your jack doesn't lift high enough some sturdy wood blocks help, the floor jack handle has to come in from the side (since the ATV jack blocks the rear) which makes the car move sideways as it is lifted, this is only slightly irritating
Hope this makes sense. Sent you a PM on the ATV jack (did I already post that? getting senior.)
Old 06-15-2004, 08:24 PM
UFLYICU
ZOA NOM's Avatar
$59.95 at Kragen sounds painless. Might be a "must own" item.
prc-racing.com
Old 06-15-2004, 08:29 PM
oneblueyedog's Avatar
This is like morphine for the pain. I love it. My friends do too since none are mechanically inclined. Wish I had had it when I dropped the engine. I put it back in in 45 minutes.
Got it from the host.
Lee 78SC
Old 06-15-2004, 08:54 PM
