3.2 Pulsing Idle
On a ferw occasions the car at idle has pulsed up and down quickly about 2-300 rmp. For the first time at cold start-up it is now doing it, pulsing between 1400 & 1600 rpm. I let it run fow 5 minutes until the oil temp started to move then I ran it up to 3500rpm's and it seemed to settle down. Ideas?
John
1985.5 944 GTS |
UFLYICU
See the following thread. I just fought with this problem for three weeks. I thought I had the problem fixed in the first post, but keep reading the entire thread.
Idle trouble - Time to fess up...
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Schleprock
John,
My idle sometimes pulses at startup as well. I always assumed it was the idle stablization valve (ISV) not working quite right. Mine's never that bad where I actually have some sort of problem. More of an annoyance. I think it oscillates between 1000 and 1500 rpm for 10 sec. or so, before it finally starts to subside and settle into a steady idle @ something around 8-900 rpm. If your car does this pulsing while @ operating temp., you can try to adjust your idle speed to address this issue. It's a good place to start. 3.2 Idle Speed Adjustment ???? Occillating idle 'Hunting Idle' - Warm 86 engine
Kevin L '86 Carrera "Larry" |
Zoanas
I've fairly recently cleaned or replaced many of the components you did. I figured it was the mixture, but I thought I'd throw it out there. I've played with the mixture using a volt meter, but have not had it done with the gas analyzer. I've been debating on buying an analyzer or having my p-mechanic set it. John
1985.5 944 GTS |
UFLYICU
After thinking about the sequence of events with my problem, I am convinced that I had more than one issue causing similar symptoms.
Order of events: Hunting Idle begins Change Head Temp Sensor - no change Change O2 Sensor - no change Change ICV (installed backwards) - no change Engine drop - East Bay Engine Drop Rookie Change reference and speed sensors Replace hoses, clamps, etc. Engine reinstall - hunting remains - SCWDP guys help w/Carrera engine install Remove and open AFM - noticed worn spot on potentiometer material inside, decide to refurbish Install refurbished AFM without CO adjustment - hunting reduced, but remiains Notice ICV backwards, corrected - no change At this point I could stop the hunting during cold startup with the idle screw. This is when I decided to have my mech put it on a gas analyzer and set it correctly. VOILA! I think that the worn spot on the potentiometer was causing it initially, and the mixture setting was the culprit once I got the AFM refurbished.
_______________________ Racer Rix Spec911 #5 prc-racing.com Last edited by ZOA NOM; 08-01-2004 at 09:56 AM.. |
