North Coast Cab's Avatar
3.2 Pulsing Idle
On a ferw occasions the car at idle has pulsed up and down quickly about 2-300 rmp. For the first time at cold start-up it is now doing it, pulsing between 1400 & 1600 rpm. I let it run fow 5 minutes until the oil temp started to move then I ran it up to 3500rpm's and it seemed to settle down. Ideas?
John
1985.5 944 GTS
Old 08-01-2004, 08:42 AM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
See the following thread. I just fought with this problem for three weeks. I thought I had the problem fixed in the first post, but keep reading the entire thread.
Idle trouble - Time to fess up...
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 08-01-2004, 09:28 AM
KTL KTL is online now
Schleprock
KTL's Avatar
John,
My idle sometimes pulses at startup as well. I always assumed it was the idle stablization valve (ISV) not working quite right. Mine's never that bad where I actually have some sort of problem. More of an annoyance. I think it oscillates between 1000 and 1500 rpm for 10 sec. or so, before it finally starts to subside and settle into a steady idle @ something around 8-900 rpm.
If your car does this pulsing while @ operating temp., you can try to adjust your idle speed to address this issue. It's a good place to start.
3.2 Idle Speed Adjustment ????
Occillating idle
'Hunting Idle' - Warm 86 engine
Kevin L
'86 Carrera "Larry"
Old 08-01-2004, 09:29 AM
Zoanas
I've fairly recently cleaned or replaced many of the components you did. I figured it was the mixture, but I thought I'd throw it out there. I've played with the mixture using a volt meter, but have not had it done with the gas analyzer. I've been debating on buying an analyzer or having my p-mechanic set it.
John
1985.5 944 GTS
Old 08-01-2004, 09:35 AM
UFLYICU
ZOA NOM's Avatar
After thinking about the sequence of events with my problem, I am convinced that I had more than one issue causing similar symptoms.
Order of events:
Hunting Idle begins
Change Head Temp Sensor - no change
Change O2 Sensor - no change
Change ICV (installed backwards) - no change
Engine drop - East Bay Engine Drop Rookie
Change reference and speed sensors
Replace hoses, clamps, etc.
Engine reinstall - hunting remains - SCWDP guys help w/Carrera engine install
Remove and open AFM - noticed worn spot on potentiometer material inside, decide to refurbish
Install refurbished AFM without CO adjustment - hunting reduced, but remiains
Notice ICV backwards, corrected - no change
At this point I could stop the hunting during cold startup with the idle screw. This is when I decided to have my mech put it on a gas analyzer and set it correctly. VOILA!
I think that the worn spot on the potentiometer was causing it initially, and the mixture setting was the culprit once I got the AFM refurbished.
prc-racing.com
Old 08-01-2004, 09:50 AM
