just me
dansk exhaust headers vs b&b headers
which are better for a 3.2 carrera motor?
From what I have seen if you want to go the Dansk route, I would get the SSI's instead. They appear to be of better quality. However, they are a tad small for a 3.2, but I have them on mine. The B&B headers, at 1 5/8 are a better size. Just do not use their mufflers.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
just me
so maybe a combination of b&b headers and some other exhaust?
are the headers bad quality or just the mufflers from b&b?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
B&B headers are too big for a stock 3.2 motor. My 3.2 with 1 1/2" headers and my own exhaust gets 219rwhp. plus I have a nice torque curve(see below). B&B mufflers have a 100% failure rate so I would steer clear. Let me know if you have any questions.
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood. Ayrton Senna 1993 964 RS |
just me
thx James, what about the dansk headers and mufflers? are they too small for a 3.2?
Paul, Dansk makes great stuff. Do you know what size their primaries are? Also, what do you plan on doing with your car, track, DE street?
Cheers, James Ps. Are you a CVR member? I am. Hope to see you at Limerock!!
just me
James, I have no idea what primaries are. sorry, I am not much of a mechanically minded person. so far as i know the motor is stock 3.2 carrera. it was not the original motor in my car though. i have this 1975 911s that I am going to make into a RS clone. I definitely plan to take it out on the track and hopefully can make some of the cvr meets at limerock as well. I have been a club member since september when i bought the car.
Paul, Nice car! Sorry about the tech stuff. The primaries are the tubes that run out of the motor and back to the muffler. I will see if I can dig up some infor on the Dansk ones and I'll let you know.
Definitely plan on doing some DE's. CVR runs a great event and the folks who go are super nice. Watkins Glen is another great track so keep that in mind since the LRP events fill up fast!! Cheers, James
just me
I just talked to my mechanic about the b&b headers. what if we used those headers and had a different muffler for them?
maybe a dual outlet straight out the back?
Administrator
I use B&B headers with a Flowmaster muffler. It's great for a 3.6, but would be too big for a 3.2. Why aren't you running the Carrera exhaust? The 3.2 motor doesn't benefit a whole lot from the commonly-available aftermarket headers, unless you're modifying the motor. The hot setup for Carreras is to change to the Euro premuffler and put in a chip.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
just me
euro premuffler? I am putting a chip in as soon as it arrives. probably tomorrow or the next day. I had no idea that the b&b headers were too big for my motor.
The B&B's will kill the midrange on a stock motor as I said before due to their size. Many of them also had fitment problems where they wouldn't allow the valve covers to be removed. This made valve adjustments a real PITA. It sounds like you still want heat so full headers aren't an option. PM me if you have any questions.
Cheers, James
As has been mentioned B&B 1.75" will be too big for a street 3.2, they do makke a 1.625" which would be appropriate. B&B make good headers, the problem is they use a proprietary spacing which means you need to use either their cr***y mufflers or a custom one like many of us have.
I agree w/ Jack that unless you have better cams a euro premuffler would be a better solution. Lots cheaper too.
just me
thx for all your input.
