randywebb's Avatar
Can we look forward to ones with the stock lenses on them?
- I'd like to lose 8-10 lbs. but the gaps from where the FG housing mounts to the body have always bothered me....
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 01-10-2005, 10:58 AM
Air Medal or two
afterburn 549's Avatar
Idea;if 5 or so buy at once can we get a grupee deal??????????
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 01-10-2005, 11:12 AM
WHERE CAN I GET THESE LIGHTS FROM?
Williamknightperformance.com
Perfectpower.com
Old 02-20-2005, 01:44 AM
Contact Ray 911s
Old 02-20-2005, 04:20 AM
Ray:
Is there a way to get these as front turn signal lenses for a short hood (74-89) car?.... meaning.....something very small that would allow that space to be mostly "open" to allow air to come in?
I'll try to post an earlier inquiry of mine to illustrate, when I find it...
EDIT, here it is--> Brake/oil cooling ducts via turn signal lites
...either to replace the side marker light ( with enough "frontal" illumination) , or simply to replace the front TS light with something smaller.
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-20-2005, 10:27 AM
Ray 911s's Avatar
Yes, actually there is. I will look up the photos and post later. I'm in the garage now trying to stuff the engine back into my car.
1977 911S
1973 Alfa Romeo GT Veloce
1997 Lotus Turbo Esprit V8
2016 AMG C63S
Old 02-20-2005, 10:54 AM
Ray...simply bumping this so it doesn't get too stale....
When you get out from under the car and have a few moments.....we'd like to see what you have available.
Not a big hurry.....
Wil
Wil Ferch
Old 02-22-2005, 06:17 AM
gumba's Avatar
I made this one for our race car. I used an Audi side marker light. I drilled a 1/2" hole above the light and mounted an led light for the turn signal.
Old 02-22-2005, 08:09 AM
Air Medal or two
no reply on groupee deal??
Old 02-22-2005, 08:32 AM
Gumba:
That looks nice.....does it provide adequate visibility to on-coming traffic? I ask because this seems to be a race car application to satisfy ( maybe) rules......would like to know how this really works on the street.
Wil
Wil Ferch
Old 02-22-2005, 09:41 AM
Im in for a group buy too
Perfectpower.com
Old 02-22-2005, 10:13 AM
Contact Ray 911s
Order them from Wayne is my tip.
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_lenses_pg6.htm
For all who forgot this forum is sponsored by Pelicanparts
Peter
Old 02-22-2005, 12:02 PM
thrown_hammer's Avatar
Pelican Parts doesn't offer the LED lights.....for all who forgot.
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 02-22-2005, 12:14 PM
gumba's Avatar
Will,
It works fine for the street. The led is the turn signal and reads well. The car is licensed for the street and I occasionally drive it on the street. I use a cooler in each fender. The front of the coolers are enclosed to capture all the air from the turn signal openings. At the track the temp is in the 190-210 range.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 02-22-2005, 03:47 PM
My low-buck version of R taillights.
The brake light (red area) is a low-cost LED-array bulb with about 12 LEDs. The others are still stock incandescents. More efficient (and brighter) bulbs are available with 48 and even 60 LEDs in a cluster for the 1157 socket.
Incandescent bulb on left; LED bulb on right
Sherwood
Old 02-22-2005, 04:15 PM
randywebb's Avatar
Sherwood - does that use the metal housings?
BTW - at least one race catalog offers LED "rain lights" for 12 VDC.
Old 02-22-2005, 04:25 PM
Originally posted by randywebb
....does that use the metal housings?
Factory housings. Just an insert for effect.
Sherwood
Old 02-22-2005, 04:35 PM
Ray 911s's Avatar
This approach is similar to Gumba's, but for a stock mid-year bumper. The stock front lens is retained, but the side lens is removed for oil cooler air flow. Both lenses could be removed using this concept with lamps mounted on brackets behind the expanded metal grills.
From the frontal views you can see the path of the cooling air. The next photo is more from a side view to show the visibility of the lamp.
Since the lamp is recessed behind the grills and basically hanging in space, any configuration of LED lamp assembly could be used.
edited to correct spelling
1977 911S
2016 AMG C63S
Old 02-22-2005, 05:33 PM
Send a message via Yahoo to Lukesportsman
Why does PP list their parts for applications 74-89? Or was that just a factor of "where" it was listed in the catalog? These were originally used, obviously, on pre 74's so why are they sold as a post 73 part?
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 02-22-2005, 05:35 PM
Not sure whether much air would find its way inside the bumper. I understand the "air scoop" that PParts sells is more at higher speeds. I wonder if anyone makes a mini-NACA duct for this application? :-)
Sherwood
Old 02-22-2005, 05:44 PM
