Me like track days
Craig 930 RS's Avatar
Exclamation * Interesting 3.6 engine build coming up *
1991 3.6:
MAF
3.8 P&C
The pistons are very unusual; not the usual 3.8 pistons. These are almost 12:1 Mahles, special ordered.
Wildest cam grind I've ever seen installed in a 3.6. More info coming -
Chip burned for race gas only
Since I had 280 RWHP - my guess is that from the compression increase, cams, and displacement increase that it will approach if not slightly exceed 300 RWHP.
Stay tuned,
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 01-22-2005, 03:22 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
I've got my popcorn sitting right here next to the computer. This should be interesting...
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 01-22-2005, 03:35 PM
Send a message via Yahoo to Lukesportsman
Consider this thread subscribed
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 01-22-2005, 04:58 PM
austin552's Avatar
Front and center....
Show time?
1974 911s
Old 01-22-2005, 07:47 PM
Licensed User
Shuie's Avatar
Pray tell
Old 01-22-2005, 08:08 PM
Friends of Warren
911teo's Avatar
I would guess even higher than 300 rwhp. On displacement only you should get 295. Plys higher CR plus wilder cams. And since you say the chip is custom programmed for racing I guess the peak power will be somewhere around 325 rwhp.
Keep us posted
Matteo
Warren RIP
www.impactbumpers.co.uk
Old 01-24-2005, 07:31 AM
Registered Loser
What kind of intake manifold are you going to use? Stock varioram? Individual throttle bodies?
Owner of a wrecked 944
Old 01-24-2005, 07:54 AM
Me like track days
Matteo -
I do think it will be higher than 300 RWHP on this dyno many of us in the Seattle area use. I'd gues 303. Stay tuned - I have some pics coming up. The pistons are a sight to see.
Stock plastic 964 manifold
Old 01-24-2005, 08:01 AM
Friends of Warren
911teo's Avatar
Is that for the law of diminishing returns? 3.6 to 3.8 = 105%...
280 x 105% = 294.
Plus increase in CR, plus wilder cams, plus racing chip.. Yeah maybe 325 rwhp is silly, but I would have thought a little more than 300... Either way it's going to fly.
Matteo
Warren RIP
Old 01-24-2005, 08:07 AM
Senior Member
Bill Verburg had a special 3.6 upgrade built for him last year. Do not believe that it was as "warmed over" as yours sounds like it will be but it was far from stock either.
Hope he chimes in here, sounds like a interesting engine!
JoeA
Old 01-24-2005, 09:19 AM
you might want to check this out:
http://www.instant-g.com/Products/36Conversion/38.html
my engine was the last one described.
2016 GT4
Old 01-24-2005, 10:22 AM
Bill Verburg's Avatar
Hi Bill! How's it running?
and mine was #5
please take all these #s w/ a grain of salt, a factory sprint 3.8RSR was rated ~380
Bill Verburg
Old 01-24-2005, 12:24 PM
Crusty Conservative
silverc4s's Avatar
Count me in at >320 rwhp
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 01-24-2005, 01:09 PM
Me like track days
Here are the pistons:
Old 01-24-2005, 02:28 PM
Crusty Conservative
silverc4s's Avatar
Craig,
It looks as though these pistons are coated. Is that Teflon? or can you tell us more about that.
Thanks.
Bill
Old 01-24-2005, 02:34 PM
Me like track days
The skirts do appear to have a coating - but I'll be damned if I know what it is.
Old 01-24-2005, 02:35 PM
david914's Avatar
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 01-24-2005, 02:41 PM
Me like track days
Going in this tired 66k 3.6 engine:
Old 01-24-2005, 02:46 PM
Those look like my pistons, if so they are 102mm, 12:1 Mahles, the coating is 3 - 4 mm Grafel coating
You didn't show the trickest part which is the tapered wrist pins
993RSR mahle on the left, 2.7RS(JE) on the right
Bill Verburg
Old 01-24-2005, 03:04 PM
Me like track days
Yes, 12:1 pistons Bill. The wrist pins are indeed tapered - think megaphones on each end - big end outwards.
Old 01-24-2005, 03:06 PM
