Sports Purpose 911 Driver
what does it cost to get into cart racing?
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
The current thinking on sub straps is that two are the way to go, and they go under your thigh, and out the seat at the lap belt holes. That is a 6 point system
A 5 point system uses one sub strap and it shoud prodeed down and backwards. It requires a hole in the seat for proper geometry. I need to check on this, but I *Think* the ultimate is the 7 point system, which include both versions of the substrap. Mounting points for belts cn be the stock threaded holes if they wind up in the right spot, or, a through hole backed by a thrust plate , a thrust washer, a lock washer and a bolt. Grades are speced by the requirements of the sanctioning body, but in abscence of that, but following the harness suppliers instructions is the way to go. My seat back braces is a plate about a foot wide and 9: tall bolted to the seat, with a clevis arrangement welded on. A 2" x 2" square steel tube mounts to a bar on my rollcage. I used removable pins and made things adjustable incase I want to have another driver in the car. Lower mounts are just as important!
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Underwater basketweaver
'05 R12GS '08 HP2 Sport '16 GT4 |
What a seatback brace is, for Matthew and others (hard to take a photo of mine, since it's in a dark, cramped area of the car): mine is a steel plate about 18" wide and 10" from top to bottom, shaped sort of like an angular semi-C that is angled to conform exactly to the shape of the seatback. Welded to the back of that plate is a 2" steel tube about a foot long that passes through another tube with an i.d. just a mite larger than the 2" tube's o.d. That tube bolts, via a strong bracket, to the horizontal rollbar brace. Mate the two tubes, set the plate where it exactly and firmly abuts the seatback, drill a hole through both tubes and insert a large, strong bolt and you have a seatback brace. If you hit something while spun backward, the brace prevents the seat from moving aft, assuming it's an otherwise survivable impact. A PCA Club Racing driver was killed at Lime Rock several years ago because he didn't have one and spun at the end of the main straight--it was raining. A number of PCA regions now require them.
Several companies sell readymade versions, none of which I like because I consider them too small--small enough, in fact, to potentially poke right through a fiberglass seatback. Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Administrator
Yeah, the danger to a seatback brace is that it is a fixed piece of metal pointed right at your spine. It also stops the seat flexing (and absorbing energy) when it makes contact. I've got a Brey-Krause one that I haven't installed yet. I want to put a lot of high density padding between it and the seat when I do install it, but I'm still looking for a good installation to copy.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
The high-density padding sounds like a good idea. I'm gonna try that, if nothing else put some semi-flattened semicircular rollbar padding at the angles of the brace. thanks!
Stephan
Jack, what about some interior shots of BB2?
Administrator
Perfect. I was just about to post a query asking if anybody knew a source for flat sheets, since a quick Google search didn't turn up anything.
Stephan
As a relative newbie to both these cars and DE's, I have learned a lot from this thread. I just did a DE at Pacific Raceways yesterday. A lot of us were discussing the safety aspect of all of this, what with the Carrera GT accident fresh in everyones's minds. My car currently has Corbeau Classic II seats, a fire extinguisher, and I wear a helmet of course, as required. I think a roll bar and some harnesses are in my near future; I am certainly hooked enough on DE's to want to continue to run them. With that in mind, it is worth it to me (and my wife) to significantly upgrade the safety of my car. Funny how that doesn't come to mind for a purely street car. How many folks think to themselves "I will never track it, so I don't need all of that"? The street is obviously more dangerous.
That said, I can certainly understand why there are not more stringent requirements at DE's. Any special equipment requirements as far as roll bars, harnesses, etc., would keep most folks away. I find it somewhat ironic that Porsche builds a car that will perform at a level that seems most with track experience deem to be unsafe for that very car. Why have they never installed cages, fire suppression, harnesses, and the like in their cars? It's a strange paradox when you really think about it. Like I said above, I think the street is more dangerous than the track. Especially in light of the fact that those who never track their cars still explore the limits of its performance somewhere. With that in mind, why don't the manufacturers build in race car like safety features in such high performance cars?
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" Last edited by Jeff Higgins; 06-05-2005 at 08:05 PM.. |
Because we Americans are lazy?
Errrrr, OK, that's not exactly right! LOL... The answer is that the number of cars that see the track, versus the number of cars that are sold, (In a specific model run) is small. And the fact is that most people don't want to be bothered with anything that requires effort. Witness the 20 year struggle to get the general pblic to buckle up. How hard is it to wear a seatbelt? So, airbags to the rescue. Fire systems? Too much maintenance. Roll cages?? Too much intrusion, and too much weight to kill CATE numbers for the average driver. It might be ironic that the car is fast enough to seemingly require extra safety gear, but truth be told the average high perfomance car owner sees little of the cars capabilities, almost as seldom as the average SUV driver sees mud.
Couple of thoughts come to mind.
Locally at PIR I have seen a car totaled almost every open track day sponsored by the track's school that I have attended. Some close enough to me that I wondered how I drove through it unscathed . You can't mandate common sense. There are many folks at any track event that obviously (or not) shouldn't be there either because of a lock of common sense or a lack driving skills or both typically. No reason what so ever for anyone to bend a fender at a DE day. Many, many 911s burn up on the street from fairly common problems. Just as common on the track. Fire equipemnt should be something we all have available. Jeff mentions it above. More of us will be injured on the street than ever will on the track. After a few years of on and off trakc days I had a car built. It has a halon fire system, a roll bar, steel valve stems, race seats and a fuel cell. I maintain the car at a high level and intentionally continue to better my driving skills and education. Good tools/cars/equipment will only keep you out of half the trouble. Gaining the skills and experince to use the tools we have is the other half or more of staying safe. Old saying, "beware the Indian not the arrow". |
I stopped driving my Audi on the track and bought my 911 when I realized the last time I was at the Glen that I was dramatically overdriving the safety my car could provide. 135 entering the bus stop was normal for me, as was the high 120's on the front straight. Not much room for error there. The thing that always bothered me at driving events was running in lower green and yellow run groups with inexperienced drivers in extremely powerful cars (part of the problem running with an Audi organization). Modded S4's with 350hp, and 9 inch wide sticky rubber on all four corners was very common even in the novice green group. These people were dangerous on the track, and I was nervous on every run group until I was soloed on all the tracks I drove on, and was running with instructors and other experienced drivers. It came down to predictability -- these people driving extremely high powered cars were unpassable on the straights but would screech down to near stop in the corners causing backups around them, wouldn't give pointbys causing red haze among all the other drivers. They drove unpredictably which made it dangerous for everyone else. I think whats needed for the best safety in a driving organization is a few things: 1) a licensing system. People have to prove they can drive safely at a given level to drive with those run groups. People can't be bumped up because there is no room. Be firm on those. Don't automatically take people's word about what level they were at in another organization (perhaps a SCCA DE certification here? They do amateur and pro racing licenses, why not DE?) 2) Strict modification and power limits in each of those classes. The fact of the matter is most people doing DE's are doing it in their street cars. DE's as an inexpensive way to get your feet wet in motorsports would be killed by mandatory safety equipment requirements. People have the right to do what they want to their cars, but DE organizers have a right to keep the other people on the track safe as well. People may not like it, but if you're a novice, bring your Saab wagon to learn on, don't push the limits of your new midlife-crisis Z-06 until you know what you're doing, otherwise it'll be an endlife-crisis car. 3) Restrict driving with instructors to lower class cars. Instructors are human beings and can make errors in judgement about getting into cars that aren't safe. These aren't professional instructors either. 4) Liberal use of the black flag. If someone is a bottleneck on the track, tell them sorry. Slow cars and slow drivers don't need to be a hazard, but people need to give pointbys, and be honest with themselves that someone else in a slower car may be faster. That was a real big problem with the Quattro club with very fast A4 drivers, and ego-driven S4 drivers who wouldn't give them the pointby. (Hell, personally I prefer chasing those people -- I always gave my friend in his A4 the pointby because he was a much better driver than I was, I drove better chasing him than leading!) Give a few "slower traffic" flag warnings, then get the person off the track. If an instructor is in the car, reevaluate the appropriateness of using that instructor in the future. That last time I was at the Glen, a modded 5-series in the green group managed to do an endo off a tirewall and pancaked itself, with an instructor in the car. Everyone was okay, but took a trip to the hospital. That car shouldn't have been in the green group, and a number of people in that group, from what I'd seen, should've been shown the door long before that happened. I think there's room for class-based licensed non-competitive motorsports. Everyone will be safer, and its an even better path to getting people into real competitive motorsports.
1968 911L 2004 Dodge Dakota SLT Plus |
James,
Thinking about this thread kind of reminds me of the different approaches to airline security-- one school of thought says search for dangerous STUFF, one school of thought says search for dangerous PEOPLE. Requiring that everyone have an SA95 and a fire extinguisher and a tech inspection is OK, however, what I think will ultimately prove more effective is greater control by DE organizers. Also, stringent equipment requirements can be a financial and logistical deterrent to having more participants in the DE. In my opinion, there's nothing wrong with having someone who just bought a bone-stock Carrera 4S (I was driving my Uncle's this weekend) take it out on the track, WITH a helmet, WITH natural fiber, long-sleeve clothing, and most importantly, WITH an instructor for guidance AND to rein in the student's enthusiasm. It's up to the club's instructors and leadership to WATCH what's happening on the track and to COMMUNICATE with the radios if someone is driving too aggressively for their particular group. Guys with big-horsepower cars who gas it on the straights and become a rolling chicane in the corners will get taken aside, WITH their instructors, and lectured about energy management and closure rates. There should be no reason, for example, why someone with a car with speed potential of 150 on the track should be able to use the DE as the opportunity to drive that speed IN THE BEGNINING GROUPS. A graduated speed limit-- Green, 90; Yellow, 100, etc. Also, we could have progressive levels of mandatory safety equipment, e.g. when you get to the unlimited speed group, it's a full cage and fire suit. Anyway, the good DE's I've been to all emphasize that it's NOT racing-- and yet there are inevitably folks who get too enthusiastic. That's a perfectly natural reaction, that must be ANTICIPATED by the DE organizers, and MANAGED for the participant's enjoyment and the safety of everybody. Unfortunately, that's a hell of a lot harder than saying you have to have a roll cage. But it's the only thing that will really work.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
MBruns for President
A fish rots from the head.
One of my favorite sayings - and one that I take to heart. When I look at track days - I look at who is running the event. If they take an active role in the management of the event - then good for them, but even better for me. I've been to DE's where the chief track instructor went out in borrowed cars and drove different run groups jut to make sure everybody was playing by the rules. You need that, and you need someone with a backbone that is going to send people home that don't leave their ego at the door or drive beyond their level. Which brings up another point where my saying fits. It rots from my head too - I don't drive my car at 10/10ths. In fact more like 7/10ths with the occassion at 8/10ths. I keep it within my comfort level - screw anybody else. As far as I am concerned, I am in charge of my own safety and is one of the key reasons that I do a majority of the work on my own car. Sure I have the tech inspection done at my own wrench - but I go over everything 2-3 times before it hits the track.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Wow John - I was writing that just as you were posting yours.
I'll also agree with you on the high HP cars. Just because the car can hit 165 doesn't mean it has to. I think this is going to be more and more of an issue with some of these big HP cars out there.
Jeremy,
Great minds rot from the head at the same time! That is a great saying, I have adopted it into my personal lexicon. I like John Luetjen's idea about chicanes, also. The skill in DE is managing the braking, cornering, and acceleration part of it, not holding the throttle to the floor-- I'd LOVE to see more chicanes on the courses (maybe just one straight or two-- I actually use these to RELAX during a race)
I think we need to break this problem down further.
Earlier in the thread, I separated "racing" from DE's. Now I suggest we define "What is a DE?" This form of recreation is exploding in popularity, and we don't get a handle on it soon, I think there will be some pain. In addition to the obvious pain of bent metal and bones, insurance costs will increase, dragging track fees with them. To the layman, a "Driver's Ed" event sounds like someone driving a beat-down Neon with a plywood "Student Driver" sign on the roof. In reality, it's matrix of cars and drivers. The drivers can be anywhere from someone who hase never seen a track other than watching the Indy 500 on TV, to accomplished race car drivers. The cars range from rental cars, to full-on race cars with 800+HP. Unfortunately, the skill-to-car ratio is not linear; I've seen track virgins driving extremely well-prepared cars, and instructors driving rented econoboxes. The biggest challenge for a DE organizer is how to reconcile this matrix. To date, this has been done by separating cars into run groups based on skill level, and dictating passing rules accordingly. From what I've read on various DE-related threads on various forums, is that California seems to have some of the most liberal (if you'll excuse the redundancy) DE rules, with the exception of PCA, which seems to keep people more reigned in. I wonder if California events are more or less safe than others? I don't have stats handy, but until this recently, incidents at NorCal tracks seemed rare, yet I read that at some events elsewhere, bent metal is common. Is it because California tracks tend to be more 'open' with liberal runoff room? Is there a source for these numbers? I think we need to step back and ask "what is the purpose of a DE?" At face value, it would appear that the intention is to allow people to drive their cars on a race track in order to learn better car control, hence the "education" part of the name. I think this is actually true for a certain percentage of attendees; these people do one or two events in their (usually) mostly-stock cars, and usually under instruction. Ok, that was easy. Where it starts to get interesting is when people start getting deeper into the sport. When you've moved up into the intermediate or advanced group, is there still "E" in DE? One could argue "yes," but the educational model evolves from 'formal' education with an instructor to 'self study.' In reality, I have seen behavior that could be construed as racing. Sometimes the stewards catch it, usually they don't. Regarding slowing cars down: SCCA does a 'street school' DE at Thunderhill (and I'm sure other tracks) and they put a chicane near the end of the front straight, so you have to all but stop to get through it; I pull into my garage faster than I was able to get through it. Great idea from a safety standpoint, but I haven't know anyone to attend one of these street schools twice. Ok, so trying to work in one window and type this in another window obviously isn't working...
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
There was a chicane at the Texas Motor Speedway DE I did at last year's parade. Even then I was almost at 140-145 before braking in my buddies C2. My closure rate on a Boxster was approaching the "scary" side - my internal warning bells were going off and I slowed a little on the subsequent laps
...That being said - I noticed the rules, especially the passing rules being much more lax at that DE vs our region in Southwest Florida.
