Banned
Tex3's Avatar
opinion on these headers
Anyone know if these would fit my 81sc 3.0 with no problems???
Old 09-16-2005, 03:01 PM
Bill Verburg's Avatar
Should be no problem.
Bill Verburg
Old 09-16-2005, 03:05 PM
Banned
Tex3's Avatar
Say Bill,
Dont they look different than the european headers. seems like the black ones are shorter. or is it just me??
Old 09-16-2005, 03:13 PM
You just need different length extension pipes to get to your muffler.
The shortys are designed that way to leave room for a cone type stinger.
like this
Bill Verburg
Old 09-16-2005, 03:27 PM
Banned
Tex3's Avatar
anybody know where you would place the oxygen sensor? drill and tap??
Old 09-16-2005, 03:38 PM
DW SD's Avatar
I'd drill a hold and then weld a bung in an appropriate spot on the header. If your stock O2 sensor is before the collector in an individual primary pipe, then weld there. If it is after the pipes merge (collector) then weld there. It should be in an analagous position.
Drilling and tapping won't work the tube wall thickness is not enough to tap.
Doug
1971 RSR - interpretation
Old 09-16-2005, 03:50 PM
just weld a bung in the collector
Bill Verburg
Old 09-16-2005, 03:51 PM
Banned
Tex3's Avatar
thanks Guys didn't think about the bung until yall metion it
Old 09-16-2005, 03:53 PM
Banned
Tex3's Avatar
last question you think 280.00 is too much for these??
Old 09-16-2005, 04:54 PM
