LinkBack Thread Tools Rating: Thread Rating: 10 votes, 4.20 average.
Member 911 Anonymous
DRACO A5OG's Avatar
Nice CL! Break a Lego
'85 Carrera Targa
PCA/POC
Old 08-05-2011, 10:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
NOLAsc's Avatar
Thanks CL and DRACO for bringing this thread back. You remind me that I've gotta do this work at some point. Been running without highbeams (pulled fuse) for the last two years.
"... changing without pain or agony not only in bulk and shape but in color too, approaching the color of wind ...."
-- William Faulkner
Old 08-06-2011, 05:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
Chris Lovell's Avatar
Thanks to Jim and everyone one this tread for another great "fix it if you can" moment. The Lego repair worked perfectly and now low, high and flash as as good as new. I also ordered the headlight relay because I do as DRACO says, and it seems like a good idea.
A couple of thoughts on those doing this project. 1. the inset within the rubber headlight pull knob with the light graphic is fragile plastic. It can be removed successfully if you carefully pry around the sides. It can also break into 10 pieces if you aren't careful. (don't ask) 2. The pressure bar (E in the photo on the previous page) comes right out if gently pryed from the non-contact side. You need it out in order to slide it back into the slot carved into your new Lego piece.
Maybe this helps.
Thanks again.
CL
CWL
'88 Carrera Cab
Old 08-06-2011, 07:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
realgren's Avatar
Just did this fix. Took my car to Pepboys to remove the wheel. The rest is a piece of cake.
I used a short socket with an extention to remove the steering wheel. It gave me a better lineup than a deep socket.
Old 09-24-2011, 12:59 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
NOLAsc's Avatar
Fixed mine today. Finally. Set the laptop in the passenger seat with this thread open just for reference. Thanks Won!
-- William Faulkner
Old 10-15-2011, 07:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
Yep, me too! Thank you all for the great info!
'76 Coupe
Old 10-30-2011, 02:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
thanks to flatsixjunky and won , i was able to fix my problem to.
Old 10-30-2011, 04:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
steves31
Believe it or not i shot wd 40 up in there and it fixed my problem i used lots of it and was pushing the lever all over to clean the contacts
Old 01-11-2012, 01:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
DRACO A5OG's Avatar
Oh my... Please let us know if that holds up.
It really is not that difficult to remove and tweek, but heck if worked for you then all is good in the hood
'85 Carrera Targa
PCA/POC
Old 01-11-2012, 01:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
GothingNC's Avatar
Hmm, I'll have to give it a shot with the WD-40
One thing I noticed that my headlights are a bit brighter since I installed the relay kit.
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
DRACO A5OG's Avatar
Certainly, if you measured the voltage before and after you will know why
'85 Carrera Targa
PCA/POC
Old 01-11-2012, 05:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
Question
Hi: I have a 1982 ROW 930 with a low beam headlight switch problem.
I thought that I had no high beams, and now realize that I have permanent highs and no lows. That also explains why the fog lights were not working.
As per the insight on this thread, I removed the switch. The high beam contact was stuck to the centre stalk, and there was some burnt crap around the silver bar at the bottom. The centre arm is sprung / bowed toward the high beam contact with quite a bias toward wanting to stay down.
I cleaned the area up and employed the high tech toothpick test approach. Voila; low beams and fog lamps!
Now for the dumb question. If I bend the centre stalk so it is sprung toward the low beam contact, moving the high beam lever toward the front of the car does nothing. If I pull the lever through to flash I see where the silver bar at the bottom causes all contacts to close. So, when the bar is pushed forward for high beams is there something that happens in the mechanism that causes the centre stalk to move down to contact the high beams?
I am thinking my unit is beyond repair.
Old 04-15-2012, 05:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
HarryD's Avatar
DaytonaCoupe66,
I had a similar issue and first I tried to repair by bending but it was not sucessful. I ended up getting a used unit from Parts Heaven and no problems since.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-15-2012, 06:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
Dave & Tonya
darcher's Avatar
this needs to be the "102nd Project"
Old 04-15-2012, 07:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
HarryD; yep, ordered a replacement switch from our host (and relay kit) so hopefully won't have to revisit this problem any time soon.
Old 04-16-2012, 03:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
dshepp806's Avatar
Just did mine yesterday,...slight bend of the high beam contact arm (AWAY from it's intended contact point...took care of the issue. Good cleaning, and lube....she's problem free!
THANKS!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-16-2012, 04:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
The Dude abides...
bigel's Avatar
I too just implemented this fine quick fix...and without removing the wheel no less!
I had the 'sticky high beams' dilemma and this cleared it up straight away...
Thanks!
'03 Carrera 4S
Old 04-29-2012, 04:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
awesome! thanks for saving me a few hundred!!!!!!!
Old 05-02-2012, 07:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
mfyoung1086's Avatar
Seriously! This is my next project when I get back to the states, I've just been that d-bag driving around at night with his high beams on!
Old 05-02-2012, 10:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
Received the highbeam switch and relay kit from the host. Took more time than an average person likely would have so as to ensure that I didn't mess anything up with the headlight switch connections on the dash. The relay kit was a breeze to install and ranks high for clarity of instructions. Now everything works as it should!
I don't think I'd have tackled a wiring headcramp if the wealth of information on this forum had not been readily available, including responses to questions. Very gratifying to DIY, and a side benefit is all the other stuff that is found while '....in there'. Cleaned up some old wiring too.
Old 05-03-2012, 09:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
