High beams on all the time is fixed thanks to this thread! Also installed the head lights fuse, new head lights and the headlight relay kit. Thanks for the info!
************************* Socbum '88 911 Coupe |
fixed mine as well..... thanks. soooo nice to have lights working better than originally designed...
76' 911s Signature Edition |
Add me to the list.
Fixed my problem of high beaming people when I was signaling. Fantastic thread indeed. Thanks!
2007 Cayman 1986 Carrera coupe (sold) 1979 911 SC targa (sold) |
Hi,
my car just passed the Vehicle Inspection thanks to this thread. I went out and tested all functions an hour before the inspection (risky, yeah....), and the high beam did not work. Figures. So, did 5 min of searching on PP, found this thread, and two hours later the car was inspected and passed with the high beam working. Great thread indeed! Thanks and regards, Johan
-14 Cayenne S Diesel, DD -92 964 C2 convertible, RS -92 look and feel😃 -73 T US MFI Targa, restored -70 T Coupé Hot Rod, painted waiting for assembly -72 T Coupé, US numbers matching under restoration |
Had this same issue with my 88 911. Searched for the issue and came across this thread - issue fixed in 10 minutes! Saved some $, but more importantly, I'm not flashing the beams every time I signal to change lanes. Thanks!
Ed 88 911 Carrera Coupe |
registered woman user
awesome job, another pelican save. i'll tackle this, this weeekend. turn signal switches are not cheap. thanks again,
Hehe. Good to see this thread come up from time to time. I was one that fixed the issue without removing the steering wheel back in '06. To date, no problems. I also had added the relays to offload the current to the turn signal stalk.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
83 Targa
Great thread and a very easy project as I had the wheel off for stitching. Thanks!
Another huge thanks for this post. Fixed both my high low beam operation and on the other side my wipers not parking issue, both with the same technique.
-- 1974 Porsche 911 Targa w/ 3.2L 1989 Porsche 964 Carrera 4 |
Thanks...10 minute job saved me a ton of money! Replaced my turn signal switch last year for this problem thinking it was just an old worn out unit. New switch started acting up after only a year of being installed. Found this thread...saved money!
Add me in too, easy fix thanks to this thread.
Bump to the top. This thread saved me $125, gave me a little better understanding of how my 87 911 cab works...
Same here, same problem with the turn signal switch, and fix on Pelican technical forum got my switch to work like new again!
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Wow - going to continue this excellent thread.
I am working on my '89 Targa, and wondering if the Steering Wheel must come off for this fix. I cannot get the plastic covers off, the 2 small screws securing them have been removed. I can pry them apart, but not enough to get in there to see what the contacts look like. Any advice would be greatly appreciated. Happy 4th of July, 2013. Thanks! Michael G |
dagersh:
Yes you need to remove the wheel as there are screws holding the cover under the steering wheel.
HarryD,
Thanks. I have been looking around, how do I pull the horn pad off of the wheel? Is a simple pull carefully until it releases? Or is there harware I am not seeing? Thanks - I can't drive the car at night until its fixed. Michael G |
No hardware.....just give a yank on it.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
I think you just pull it off but since my car has a different way of attaching the horn ring, I am not 100% sure. They changed it in 1974 and my car is a 1973. If you do a search here, you will find posts by those with your style of horn button to verify the correct procedure. Try the search terms "remove horn" and find this thread: '87 Steering Wheel removal?
New Switch
I went ahead and replaced the switch with a new one over the weekend but the new switch will not click in to place to make a right turn. Any suggestions? Has anybody else had this problem? Defective switch? Thanks, John
John St. Louis: Did you try out the new switch in all positions before you installed it. If it was working correctly before you installed it you should recheck your installation, maybe redo it with care. If it was not working correctly before installation you got a bad switch, I think.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold Last edited by porwolf; 07-08-2013 at 10:50 PM.. |
