dozer's Avatar
Brake upgrade! 1978 SC with dp motorsport engine
Hi
I will need new brakes for my SC. It's gonna end up with a whigt around 1000 KG witch is about 2000 pounds
I have a dp motorsport engine - puting out about 430 BHP.
What would be the right upgrade ...... remember im on a budget here so ceramic isn't what im looking for
Would 930 after 78' do the job? S4 brakes? 993tt ?
Where can i do a good deal on theese items?
Thanx
"It gets a little bit louder above 5,000 RPM so you can't hear the passenger scream"
Porsche 911 Turbo
Old 10-29-2005, 05:48 PM
H20911's Avatar
try a search. there are probably a thread about this if you you look hard enough.
try here too
993 Caliper Mods- Grinding and Drilling
good luck
h20911's V8 Homepage
www.home.earthlink.net/~sdfranco/index.html
Old 10-29-2005, 06:08 PM
Crotchety Old Bastard
RarlyL8's Avatar
You don't necessarily need new brakes. You may just need to optimize your existing brakes. When I put the modded 930 engine in my SC everyone told me I needed big brakes. What I found out is that sense I almost never track the car the brakes are just fine (for the street).
Put on some realy good pads and give it a try before you spend the big bux.
Old 10-29-2005, 07:32 PM
I installed 79 930 floating rotor brakes in my SC. My car weighs around 2900 lbs. I love the brakes. They work perfectly and they look good also.
I think if you installed a set of those they would be fine for your car. I don't know where to get a deal, they are kinda expensive.
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 10-30-2005, 06:28 AM
Bill Verburg's Avatar
probably, S4 would use the same rotors so not much better,
Next step up is either Brembo Big Reds or GTP
I just noticed that Stoptech appears to have a 911 kit as well, but I have no info on it
Bill Verburg
Old 10-30-2005, 06:29 AM
dozer's Avatar
Thanx
Annyone got what i need?
Don't mind buying used... but it has to be in good shape.
Porsche 911 Turbo
Old 10-30-2005, 12:20 PM
You might start your search here
Bill Verburg
Old 10-30-2005, 01:02 PM
dozer's Avatar
I know Bill... but im more interesed in a complet set ..even need a 23mm master sylinder.......
Porsche 911 Turbo
Old 10-30-2005, 04:11 PM
