durn for'ner
Quick question DME control module
About to order a chip from SW. He asked me to provide the number on top of the stock chip.
In order to access the chip I need to disconnect and pull out the DME control module (silver box). Here is this weeks most stupid question: Is it necessary to disconnect the battery before I disconnect electric cable harness from DME box ?
Markus Resident Fluffer Carrera '85 |
A good rule of thumb is to ALWAYS disconnect the battery when doing anything related to the electrical system. This would be especially true with regard to the sensitive DME. Don't take any chances -- disconnect the battery.
1984 Targa |
I can't remember if I went that far, but it's not a bad idea to disconnect the battery.
As to the DME box...I recall it was easier if you first remove the hold-down nuts...then you can get better access / leverage on the big multi-pin connector. It is captured on one side and clippped on the other, so it rotates / clicks into place. Make sense? Having the stiff wiring harness and module together with the nuts first removed makes this a bit easier. The DME box will have metal tabs that need to be bent straight ( bottom side) to remove the cover. Once you do that the box opens like a book. A search here ( Chris Bennet?) may show pics on the hazrds of doing this wrong...the box has small leg "stand-offs" that need to snap open, and then the "ribbon" side of teh box acts as a hinge for a book. You'll then see the chip. You may ( instead) ask Steve Wong for a install sheet with pics...which would help you now ahead of time. Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
durn for'ner
Thanks guys,
Great tips Wil !
Using the Pelican Parts BBS and not ordering from Pelican.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Bill Verburg; 11-12-2005 at 10:18 AM.. |
Slippery Slope Victim
Just work like you are doing open heart surgery Work slow, clean and gentle like.
Remove the mounting nuts on the DME, and push the teats that secure the pin connector and gently pull the connector off the DME. Be aware that the connector is hinged at one side, looking at it it is hinged on the inboard side. Take the DME to your kitchen table and use a CLEAN, DRY towel to lay the DME upside down to protect both the DME and table. Very important....make sure there is no static electricity present!!!!! I ground myself and everything used to the faucet to eliminate static. Get a small thin blade flat screwdriver and gently but firmly pry the tabs up so they stand vertical. Gently wiggle the board "book" out of the metal case. You will see that the circuit boards are in book form, with the flat ribbon wire connecting the two of them. Use a miniature srewdriver and you insert the blade into the two stands that seperate the boards and genly twist and pull the boards apart. Locate the chip and again with the mini screwdriver VERY GENTLY AND CAREFULLY pry the chip out if it does not pull out with your fingers, (probably will not.) Insert new chip, again...VERY GENTLY AND CAREFULLY into the socket. The pins or teeth looking pins are very easy to bend. Repeat steps in reverse. The idle might have to be adjusted. The little screw on the AFM looking right at you might have to be turned out to increase (pretty sure it's out). Technically you are supposed to jump out two terminals on the rear electrical panel. I can't remmember which off hand, the info is in Wayne's 101 project book. Instructions will come with the chip, very east after you have done it one time. Good Luck, you will not be disappointed! Looks like we are being watched
Mike² 1985 M491 |
durn for'ner
Look who´s talking. Thanks for the friendly input, Loren !!
I wanted the chip manufacturer´s own opinion on putting his chip in my particular Euro car. He was swift in replying, very nice and helpful and I would feel awful not ordering from him after such great reception. Sorry, Wayne. And Loren - you are just amazing.. I have tried to give you a fair, non-biased judgment in previous threads. Calling me a loser for no reason is totally unjustified. Mike, great - thanks a lot !
And vendors that supply to Pelican & promote via Pelican, but take the
business direct!
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Bill Verburg; 11-12-2005 at 10:19 AM.. |
Hey Livi, when you were a kid in school don't you remember the smart ass that always talked about and made fun of others?
FWIW.......If Loren has a "stock" DME in his car why don't we set up a drag race with someone who has installed a chip. I mean if dyno runs are not good enough empirical data then how about some head to head data? Loren, with all due respect. I understand that you are a respected authority on DME's, electronics and etc. I have no doubt of your intelligence, abilities or knowledge, but come on! Flinging juvenile remarks is.....well juvenile. .................................................. .................................................. .... The following is directed to all on the BBS.....IMHO Whether we are right or wrong is not the point, we argree to disagree.....understood. I feel that ALL of us on this board, not anyone in particular must cool this behavior of one upsmanship BS. I have been out of elementary school a LONG time, and no longer have fun poking fun and calling others names. Aren't we all hopefully adult....let us all act as such. Respectfully sbmitted. Cheers
Mike² 1985 M491 Last edited by NY65912; 11-11-2005 at 11:28 AM.. |
Warren Hall Student
Lorens' point may be a valid one but it's really Steve and Waynes' business. They both need to and do figure out how to run their businesses. Stifling this board would hurt both of them and I'm sure both are aware of it.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
( Ignoring a certain person...as we all should when it gets this way...)
-- when you look at the chip..be careful not to put it in backwards. One side will have a semi-circle notch....don't get the notch on the wrong ( opposite) side. Get the "install" sheet from Steve W...it has pictures ! Wil
durn for'ner
I am probably missing something here, for lack of knowledge regarding American business culture.
No matter from whom I purchase the chip - looks like I will be offending either Steve or Wayne. Might as well keep the stock chip and avoid stepping on anyones toes from my apparent ignorance. Edit: Thanks again Wil !
Buy from either...since either seems to allow it to go both ways...
As someone else said..it's a point that needs to be discussed only between Steve and Wayne.... Wil
Agreed. Loren, run your own show and let the responsible parties run theirs. "Loser" seems more appropriate for those who wait for a chance to pounce only to find they look even more ridiculous after the fact.... go away now Markus, get the chip, you will be happy. -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
Markus I opened up my 84 euro and the chip was soldered down
It can still be changed but it's not quite plug and play. Hope you get lucky. Keep us posted.
1984 3.2 Carrera Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o |
3.4 Bigger is better
Loren has been banned for this behavior before both here and at Rennlist. It appears than he needs to be reminded of that. It appears that he needs another timeout.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
RETIRED
Just doan cut the blue wire....
HI Loren....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
It's all about supporting Pelican Parts. They provide this BBS without any
costs to the many users. Many users fail to consider this when they make purchasing decisions which can benefit both the vendor AND Pelican Parts, if one just gives the decision a little thought.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
RETIRED
Geeez, Loren...bad day?
