techweenie's Avatar
Help identifying engine tin
I got this piece with a batch of engine tin, and I don't recognize it. There's some kind of 'scoop' formed on the driver's side up where it mounts against the chain cover. I believe the very early 911s had a fuel pump in that area. Could that be it?
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 11-21-2005, 02:43 PM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
you sure thats not a Corvair part?
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 11-21-2005, 02:59 PM
Grady Clay's Avatar
Yes, that is for a ’65-’66 Type 901/01 engine with Solex carburetors. The clearance was for the two fuel pumps. I think it was also used with the 901/05 engine with Weber carburetors and possibly the very early 901/02 911S and 901/06 911 engines until the parts were used up. The chain cover still had the casting (not machined) for the fuel pumps.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 11-21-2005, 03:19 PM
techweenie's Avatar
Best,
Grady
Thank you.
Kevin, when are you bringing your Corvair out of hiding?
1969 coupe hot rod
Old 11-21-2005, 04:11 PM
1.367m later
KevinP73's Avatar
Originally posted by techweenie
Thank you.
I haven't had time for my own toys. It seems I'm either working my a** off to pay the bills or workin my a** off to get the work done.
I need a machinist to cut an adapter for the V8 to corvair trans not much else needed for that one. The turbo just needs the motor re-installed. I need about another 6 hours in the day then I'd be set.
Old 11-21-2005, 04:20 PM
