Average life span for Carrera distributor cap & rotor, and plug wires
I just checked my distributor cap and found carbon on the terminals after 30,000mi. How do you know when it's time to replace? Rotor doesn't look too worn after same 30,000mi. Wires seem ok, no miss-fires, and have 127,000mi. but how do you know when they are done?
Old 03-14-2006, 08:43 PM
at 30Kmiles, it's time. There're cheap.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-14-2006, 09:08 PM
captainrb's Avatar
When in any 'doubt' change 'IT' with all that time and wear. The clearence between the rotor and cap could be excessive.
More is better and too much is JUST enough
Old 03-15-2006, 08:51 AM
Friend of Warren
If the wires are stock replace them. The rest of the stuff: plugs, wires, rotor, cap are relatively cheap. I replace mine every winter.
Kurt V
Old 03-15-2006, 09:13 AM
Northern Motorhead
wildcat077's Avatar
Hey Brownman,
Most people on this forum ask intelligent questions ... If you don't have an intelligent answer
please keep your smart ass remarks for yourself ...
16 posts ... Have a great day as well !!!
Cheers !
Phil!
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 05-17-2010, 06:13 PM
Originally Posted by wildcat077 View Post
Hey Brownman,
Cheers !
Phil!
Quick check of the 16 posts--the guy's a troll.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 05-17-2010, 06:25 PM
3.4 Bigger is better
88-diamondblue's Avatar
At 30,000 it is time. Rotor is cheap and distributor cap is not what I call cheap but is definitely time to replace. Just good maintenance to replace them. Plugs while your at it...
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 05-17-2010, 06:53 PM
brads911sc's Avatar
I do my plugs, cap and rotor whenever I adjust the valves. about every 10k. wires.. i dont know... 127k sounds like alot...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 05-17-2010, 06:54 PM
When I first bought my car Magnacor wires were recommended by Steve at Rennsport, I put them on and have had no issues for 50k miles. Spark plug wires are a thing I like to have the best I can make or find. I change plugs, cap and rotor when I get to the point of not remembering when I did it last. The frequency is changing over time so I can't make a good recommendation. I probably over maintain.
Old 05-17-2010, 07:36 PM
I'm here to cause trouble
jimbauman's Avatar
Ya a frickin' carpet salesman. Time to DELETE that account Mr. Moderator....
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 05-17-2010, 07:42 PM
John W
I just replaced mine at 14k miles and said to myself that it looked like it'd be best to replace them at about 10k. I read in Bentley where you can measure the resistance of the rotor and it should be about 1 kohm. I measured mine and it was 1200 ohms so sure enough it was ready to be replaced.
John
89 3.2 Targa 123k miles
Old 05-17-2010, 08:01 PM
brads911sc's Avatar
douche nozzle
Originally Posted by Kwame Brownman View Post
Well, i guess you need the aid of a local mechanic man. You need someone to check your distributor cap. Have a great day!
Old 05-17-2010, 08:06 PM
Its the wires I always wonder about, they are not cheap. Every 60k would seem reasonable?
Old 05-17-2010, 08:36 PM
Beru stranded copper wires and insulation never wear out, but the end terminals tend to corrode and the resistor ends go bad.
Magnacor wires, on the other hand, seem to eliminate all those problems.
Old 05-17-2010, 08:42 PM
Whats the symtoms of the resistors going bad. Is it potential signal breakup at high revs.
Is there any way to detect bad resistors?
Thanks,
Old 05-17-2010, 09:02 PM
A miss is the most common symptom and an ohm meter might be helpful in finding which one has gone bad.
Old 05-17-2010, 09:16 PM
Administrator
Jack Olsen's Avatar
It's deleted.
Old 05-17-2010, 10:13 PM
If the ends unscrew, would disassembly and a cleaning be worth one's while?
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 05-18-2010, 06:34 AM
That can sometimes be a PIA when the corrosion is so bad, they fail to unscrew easily causing the terminals come off the wires. To make things worse, how could you remove the corrosion trapped inside the crimp without cutting off the terminal and re-crimping a new terminal?
Personally, I'm all in favor of eliminating all these problems with the installation of your basic, seemingly everlasting, low maintenance, OEM proven, cost effective carbon core ignition cables.
Cheers,
Joe
Old 05-18-2010, 09:07 AM
dshepp806's Avatar
I change my distributor cap and rotor every 6K,..how's that? So what?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-18-2010, 01:44 PM
