Slumlord
Porsche_monkey's Avatar
Originally posted by Craig911
PBH -
Are you referring to the led cluster or the LED orange/red lights?
You need 21 watt bulbs as a load on your turn signal relay in order for the flasher to work properly, not enough load, and it won't work.
If you replace your 21 watt bulbs with 15 watt bulbs (which I did by accident) you will find the flasher circuit doesn't work right. The flasher frequency is wrong, and both turn signals in the dash illuminate. The LED's likely have the same issue.
Old 06-27-2006, 04:56 AM
Me like track days
Craig 930 RS's Avatar
I'd surmise that the brake lights would be fine - would you?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 06-27-2006, 05:41 AM
3 restos WIP = psycho
kenikh's Avatar
Brakes work great. The flashers are said to work fine. The base of the LED bulbs have a circuit board that ensures the correct load and impedance. I am sure you could confirm with any seller.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-27-2006, 05:44 AM
Slumlord
Maybe they add a resistor to increase the draw, but I don't think 21 watts is NA standard, 15W seems to be the standard now, and they would not work on my car.
I guess we need a guinea pig...
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 06-27-2006, 06:32 AM
Me like track days
I'll give them a try when they arrive.......
Old 06-27-2006, 07:01 AM
Me like track days
Since the 930 is sans engine, I won't be testing them in the near future - but they arrived - this is what they look like:
Old 06-28-2006, 06:30 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
I just got back from Autozone. They have the lights Craig is talking about 2 for $8 ! Way cheaper than the evilbay guy!
T
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 06-29-2006, 09:14 PM
Me like track days
Mine *were* about 8 bucks. It's just the 9 bucks screw job shipping that kills ya.....
Old 06-30-2006, 04:51 AM
9dreizig's Avatar
Exactly! and we don't pay sales tax here in NH!!
Hey my trip to Seattle has been pushed out a few weeks. Any chance that beast will be running then ?
Todd
"Todd"
Old 06-30-2006, 04:55 AM
Me like track days
I'd say about mid-July - you here then?
Old 06-30-2006, 05:15 AM
9dreizig's Avatar
Yeah, I should be. Won't be next week, the after at the very earliest and probably the week after. Let's plan on it .
T
"Todd"
Old 06-30-2006, 05:56 AM
Me like track days
Deal. PM me when you are in -
Old 06-30-2006, 06:11 AM
Rick Lee's Avatar
Oooh. I wonder if these will work on the 993. Since I have clear front lenses, I'd need the LED's to be amber. But my Euro tail light lenses should take white LED's. I haffta check the connections and wattage when I get home.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 06-30-2006, 06:23 AM
9dreizig's Avatar
Actually I think I saw them in colors as well at Autozone.
"Todd"
Old 06-30-2006, 06:25 AM
kenikh's Avatar
100% correct. You can get them in any color.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-30-2006, 07:18 AM
MIK911's Avatar
Anyone know off-hand if the 3rd brake light on '86 (mounted high on rear window) will accept this LED clustered bulb base? I'm sure the fitting will work but which direction is the socket facing? The socket would need to be face rearward, in order for these LED's to shine rearward.
thanks
Mike
'86 911 coupe
'85 BMW 535i
'11 Cayenne
Old 06-30-2006, 01:38 PM
rfuerst911sc's Avatar
Can these bulbs be used for running lights,brake lights and turn signals?
Old 07-01-2006, 10:50 AM
scottb's Avatar
That's the question of the hour! There seems to be some dispute about whether they provide sufficient load (15 w v. 21 w) for use as turn signal bulbs.
Do we have an answer from any of those that have installed these bulbs?
1984 Targa
Old 07-01-2006, 11:35 AM
Typical light output from LEDs is pretty much on one axis with lots of light fallout off-axis. The result, decent light output and reception directly in back of a vehicle - not so good off to the sides.
Not sure if any of the links provided this info, but the latest versions of LED brake lamps mount some of the LEDs in the cluster at various angles to compensate for the off-axis light reduction.
Sherwood
Old 07-01-2006, 12:44 PM
Hey fellas
I have a bit of experience here AND I'm an electronics guy by profession, so theoretically I know of what I speak. Below is a view of one rear corner of my '66.
The LEDs came from the local truck stop store. I ordered a set of LED lights with the housings I bought (from MotoMotions--GREAT service and price!!), but I didn't like the LED assemblies that came with. Kinda clunky to me...these on the other hand are the spittin' image of the original Type R setup but with modern performance. They are BRIGHT. Here's my lowdown on the performance/adaptability issue: And the caveat is that my observations are based on an older (1966), relay-based turn signal flasher design. I'll bet, though, that almost all of our car vintages/technologies are close enough that this will apply.
With a set of LED lights in the back for both stop and turn, and standard front incandescent assemblies, no resistors, adapter, or anything are needed. You will need a bit of electronics so that the red lights cover both running and brake. Let me know if you want to try this, I'll be happy to show any of you how it works. Turn signal flash rate appears the same and the instrument panel indicators work normally. Add LEDs as the front turn signals (all are now LED--hey, they were 6 bucks, so I bought extra!)) and you need more load on the turn signal flasher. All this means is a 10 watt, 10 Ohm resistor hooks across the wires.
I recommend this to anyone willing to fool around with the idea. It works great!
Adam912. Out.
Old 07-01-2006, 01:45 PM
