I am looking at these pics of the quad-gauges....why do they have water temp? What would normally go there?
tk 08 911 C2S - Sold 13 Audi A4 14 Jeep SRT 500HP |
Thanks for the feedback on terminal #57.
Pictures are sometimes hard to tell the improvement, do you like this solution? is it worth the effort?
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Happiest when Tinkering
The improvement was dramatic, the solution while not plug and play and took considerable time (I made 15 bulbs instead of 8) I think was worth it. I now can see my gauges at night.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Went out tonight and turned on the dash lights in pitch black, the illumination level is perfect I also got a couple red panel lights and put them in the fresh ait lighting points and they light the fresh air stuff with a warm red glow not the least bit overpowering so now I can see all the controls in the car on a dark night. I took another pic but it didn't do the lights justice so I won't post it.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me Last edited by gsmith660; 02-19-2009 at 08:02 PM.. |
These are a bit more traditional, this guy wanted stock appearance so we went with the warm white. No tricks or high ISO pics, the gauges really do light up that well. We also have a dimmer made for us by a local LED manufacturer There are a couple of quicktime movies of the lighting here: http://community.webshots.com/album/558336473KkVazr?start=192 I can't figure out how to post movies or gifs. Mark Last edited by marks914; 02-21-2009 at 07:50 PM.. |
Forgot to mention that we have a remote dimmer and an "invisible" in-line dimmer in the works
Mark |
a bump for those not wanting LED
member scarceller used Xenon B715205 project can be downloaded here 911 Projects http://members.cox.net/widebody/GaugeLighting/911GaugeLightMod.doc what i couldn't find in his docs is a dimmer he recommended years ago IMTRA Marine Products I think this is a great project
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
I don't use a dimmer. I have the dimer bypassed, as described in an earlier post. My upgraded bulbs have been in my car for over 4 years with no issues. Yes, I love this upgrade!
Mike '84 Grand Prix White RoW Carrera |
Caveman Hammer Mechanic
Hello
If you really want to "fix" the problem, and aren't afraid of a little guage work, here ya go: Remove offending guage Carefully uncrimp the bezel with an 1/8" screwdriver, a little bit at a time. After the bezel comes off carefully remove the guts of the guage. Clean the glass face Rough up the interior of the "can" with 220 grit sandpaper Clean the inside of the body of the instrument with lacquer thinner/acetone. Spray with the whitest white paint you can get. Let dry. Reassemble, using a pair of pliers with tape on the jaws and finish crimp with block of wood covered with a cloth and wood dowel and a hammer. It really sounds like alot of procedures, but its not. Just work slowly and methodically and clean the work area well. The painting of the interior of the can reflects the light really well. The can was originally zinc plated and most have oxidized over the years, mine were a corroded dull grey. I now have to turn my dimmer to the half way point on country roads, and to the 3/4 position on city streets. I would rate this a 2 banana job. eric P.S. If I can remember I will take a flick after dark.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Good thread. Just found it. Hope I didn't waste my money. My order from Autolumination arrived yesterday. I bought 10 (I know, I only need 8) blue Ba7 Superstar LED bulbs at $4.99 each. They're supposed to be 3x brighter than their standard $2.99 LED and fit the existing Porsche socket. Anyone have any history with this company?
Andy Kay Kennedale, TX 817.948.8538 1979 911 SC Euro - Guards Red |
Member 911 Anonymous
None, but would love to see your results, break a LED!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
greetings so you had poor lighting on your 1975 so bad you had to stare at your oil temp gauge etc to see read them and you used high gloss white instead of spray can chrome. What's your thoughts on using chrome paint. sounds like you went from poor to very good with stock bulbs sounds too good to be true but you've been there done that so I'll do it
Just posted mine on my thread, didn't know there was so much info out there.
NH speedo did mine. Robs 911ST Cafe' Racer ![]()
That's what I used. |
So I've gone with 300 milliamp blue LEDs (Ebay) that I mount in the instrument bulb holder. I run them at a maximum of 150 milliamps, 60 ohm 3W resistor in series with each one. The original incandescents draw 150 milliamps so dimmer function is close to normal. |
LED bulb assembly process.
Oh, are those the Luxeon 1 watt LED's? They are definitely bright suckers and 120-130 degree view angle, if I recall.
Break a LED, Jim
Ebay. 300 ma, 2.9 vdc = ~1W Luxeon? No idea. |
Carmagic, LED Lights for Classic Porsches
Went with this company on my previous cars and today on my 1985-911, gives two great options 1) old vintage white 2) Bright white (but not the "in your face illumination")....basically plug and play-very easy, no relays necessary for my set up....fast delivery and comes with instruction, very easy and makes all the difference. |
1984 Targa |
